A pretty frequent request is to have an I/O Linc Garage Door Kit controlled by a KeypadLinc button and for the button to show the status of the garage door. This How-to level of difficulty is Moderate. The only reason it's moderate is because you need to manually set one of the KeypadLinc (KPL) features.
The approach we're going to take in this scenario is using INSTEON links to do all the work. We'll use Indigo to create the links and change some settings but after that Indigo won't be involved at all during normal operation. In this tutorial we're going to assume that we're linking to button 3 on your KPL (see KeypadLinc Buttons for details). So, first thing we want to do is configure some options on the I/O Linc and the KPL:
Input sensor opened sends INSTEON ON command (uncheck to send OFF)
button. Some garage door sensors send ON when they open and others send OFF. If, after you get it all set up, the light on the KPL is opposite of what you want, switch that checkbox and click “Upload Settings”.Set KeypadLinc Button Toggle Mode…
menu item on the Interfaces→INSTEON/X10 Power Line
submenu. The same menu item can be found in Indigo 5 on the Plugins→INSTEON Commands
submenu.At this point, you have your I/O Linc and your KPL button configured correctly. Now, we want to link the devices using INSTEON links:
Edit Device
dialog.Manage Links…
buttonNew Link to Responder
buttonEdit selected link:
section, select your KPL after responder
then controls 3rd button LED
from the next popup. This creates a link between the I/O Linc's input sensor to your KPL button so that when the sensor changes state the button LED will change as well.New Link to Controller
section, select your KPL after On controller
then 3
after broadcast of button/group number
. This creates a link between the KPL button and the I/O Linc such that when the KPL button is pressed (always sending on as set above) the I/O Linc will turn ON it's output (momentarily as set above). This will start the door opening/closing.Sync Now
buttonThat's it. The button LED may be incorrect now because it hasn't synced, so just press the button and let the door complete it's cycle. Then do it one more time and let the door complete it's cycle. The button state should now mirror the door state. If it's opposite from what you want (LED is ON when the door is open for example), then just switch the checkbox referenced above in the I/O Linc configuration section then run the cycle again and it should be in sync.
