Indigo
Indigo is Perceptive Automation's Home Automation software for macOS. Check out the online documentation if you haven't already for the version of Indigo you own:
Indigo 6 natively supports three Home Automation protocols: Z-Wave, INSTEON and X10 The Pro version will also give you access to a Virtual Device interface which allows you to create more complex devices, a large library of 3rd party plugins, and provides you with the ability to integrate with other systems using a variety of methods described in our technical documentation:
Check out the user forum where you can find the release notes for all Indigo releases.
indigo.txt · Last modified: 2017/05/28 18:45 by mattb
