Welcome to the Indigo 5 Documentation pages. We've separated the docs into three areas, each focusing on some different part of Indigo 5.
This section contains links to documents that apply to the base Indigo product (both Indigo Lite and Indigo Pro). It's the starting point if your new to Indigo. We highly recommend starting with the Getting Started guide then progressing on to the other documents.
There are other help documents available below and from the purple question mark icon in the UI for the less frequently used dialogs in Indigo.
Indigo Pro ships with many extensions to offer greater functionality. In Indigo 5, these are referred to as plugins. This section contains links to the documentation for each plugin that ships with Indigo 5 (the version number after the plugin name indicates which version the plugin began shipping).
With the release of Indigo 5, extending Indigo has become easier than ever. Along with AppleScript, we've introduced a Python-based API that allows even greater ability for 3rd parties to integrate devices, events, and actions more natively into Indigo. This section provides links to all the documentation needed to develop scripts and plugins for Indigo.
