The primary place that you'll manage links between devices is in the Manage INSTEON Device Links dialog. Select Manage INSTEON Device Links
from Interfaces→INSTEON/X10 Power Line
, and the dialog will popup:
Manage INSTEON Device Links…
from the Interface
menu.Show links used by device
popup control.If the module you selected is a controller (RemoteLinc, KeypadLinc, SwitchLinc, etc.), then you can add or edit responders:
New Link to Responder
button. If you want to change the settings (brightness, ramp rate duration, etc.) of an existing responder module in the scene, then select that module's link in the table with the Link to Responder Device
column title.broadcast of button/group number
popup control.cool
and heat
setpoint temperatures.Persistent
checkbox to force this link to automatically be restored whenever either the responder module or controller module is synced. If the modules are ever reset, replaced, or have this link modified, then Indigo will automatically rewrite the original link on the next sync operation.If the module you selected is a responder (LampLinc, Thermostat Adapter, KeypadLinc, SwitchLinc, etc.), then you can add or edit controllers:
New Link to Controller
button. If you want to change the settings (brightness, ramp rate duration, etc.) used by the selected module in a controller's scene, then select the controller module's link in the table with the Link to Controller Device
popup control.cool
and heat
setpoint temperatures via those text boxes.Persistent
button to close the link editor window and write the changes to the modules at a later time. When you are ready to write the changes to the remote modules, select Start Sync INSTEON Device Links…
button.
action.
Manage INSTEON PowerLinc Links…
menu.PowerLinc Group/Scene
number to use for the scene. Use 1 if this is your first scene.PowerLinc Group/Scene
name in the edit field (ex: “reading in bed”).Next, create a new link for every responder module in the scene:
button. If you want to change the settings (brightness, ramp rate duration, etc.) of an existing responder module in the scene, then select that module's link in the table in the top-half of the window.responder
popup control.cool
and heat
setpoint temperatures using the text boxes.Persistent
checkbox to force this link to automatically be restored whenever the responder module is synced. If the responder module is ever reset, replaced, or has this link modified, then Indigo will automatically rewrite the original link into the device when it is next synced.
button to close the link editor window and write the changes to the modules at a later time. When you are ready to write the changes to the PowerLinc and remote modules select Start Sync INSTEON Device Links…
button.
Actions
tab inside the edit window.Type
popup item.Send
will turn off all of the modules immediately, ignoring any ramp rate duration.Scene
popup item.
Make sure all devices are properly wired or plugged in. Select Start Sync INSTEON Device Links… from the Interface menu. Press the Sync All Devices button. Watch the Event Log window to see when the synchronization process is complete. The batch synchronization process can be canceled at any time.
Select Stop Sync INSTEON Device Links from the Interface menu. Watch the Event Log window to see when the synchronization process is canceled.
If your PowerLinc is ever replaced, then you must re-sync all of your devices. This will ensure that all devices have their internal links updated to reflect the new PowerLinc's INSTEON address.
