Indigo Plugin Developer's Guide v1.0
Indigo Plugins and APIs
Indigo has a long history of extensibility - AppleScript Attachment scripts were available from the start. Later, the Indigo Web Server was added along with the IWS plugin and the ability to add custom images.
With Indigo 5.0, we wanted to add a new server plugin API that would allow 3rd party developers to more natively add devices, triggers, and actions to Indigo. This new server API would allow users and 3rd party vendors to implement their own functionality in Python with full access to all the objects and events that Indigo understands (referred to as the Indigo Object Model, or IOM). Finally, users wouldn’t have to wait for us to add support for, say, the Global Caché IR devices, the THUM devices from Practical Design, etc. Someone with sufficient skills could implement support for those devices, have them integrated into the Indigo UI as first-class citizens. No strange variable state hacks, fake X10 devices, etc. - these new devices are actually recognized as real devices in Indigo.
What’s more, we wanted to ensure that Python programmers have complete access to everything that AppleScript scripts have access to. While AppleScript is a good language for a lot of things (and we aren’t dropping support for it) we believe that using a more modern, standard, capable, and platform agnostic scripting language is much better for our users in the long run.
To deliver this additional functionality, we've introduced a new concept: the Indigo plugin bundle. First, let’s look at the new Application Support folder structure.
Back to Top
Indigo has always supported customization by the user via various folders in the main Indigo directory located here:
/Library/Application Support/Perceptive Automation/Indigo 4
Located inside this folder were several sub-folders where users could put various scripts, web plugins and images. In Indigo 5.0, we changed the folder structure such that it looks like this:
in this location:
/Library/Application Support/Perceptive Automation/Indigo 5
Notice are the two new folders: Plugins and Plugins (Disabled). These two folders are where the new plugin bundles are stored (see the next section for details). Plugins that are enabled from the UI are located in the Plugins folder and when a user disables a plugin it’s moved to the Plugins (Disabled) folder.
Back to Top
The Indigo Plugin Bundle
One of the biggest problems with extending Indigo was that there were pieces/parts all over the Application Support folder. As the developer of a solution, you often had to tell people to put various parts of your solution in various places, which of course has a huge margin for user error. To address that problem, we’ve created a new bundle type, the Indigo plugin bundle (.indigoPlugin), which has a very specific structure:
The first thing you’ll notice is that this is actually a real Finder bundle - so it appears to be a single file called Example.indigoPlugin. It’s moved around and treated as a single file, and all the user has to do to install your solution is to drag the plugin file (bundle) to the Plugins folder.
First, though, you can see that there is only one top-level folder in the bundle - Contents. All other files/folders are inside that folder. This is the standard Mac OS bundle construction, so we decided to follow the pattern.
So, why did we go to the trouble of using the bundle format when there's just a file and a couple of folders? Because in future versions, we're going to add capabilities to the plugin bundle (AppleScript Attachments, AppleScript background scripts, shared images, IWS plugins, etc). We didn't quite get to them for 5.0, but expect them to follow very soon after the 5.0 release.
The Info.plist File
Editing a plist file isn’t difficult, but it’s much easier using the Property List Editor application that Apple ships with the Xcode tools. However, it is just a text XML file that looks like this:
<plist version="1.0">
<dict>
    <key>PluginVersion</key>
    <string>1.0</string>
    <key>ServerApiVersion</key>
    <string>1.0.0</string>
    <string>Example Indigo Plugin</string>
    <key>CFBundleIdentifier</key>
    <string>com.yourdomain.plugin</string>
    <key>CFBundleVersion</key>
    <key>CFBundleURLTypes</key>
    <array>
        <dict>
            <key>CFBundleURLName</key>
            <string>http://www.yourdomain.com/plugin/</string>
        </dict>
    </array>
</dict>
</plist>
In Property List Editor, it looks like this:
  • PluginVersion - this is the version number for your plugin - it’s shown to the user in the UI and will help you when supporting your plugin users. This key is required.
  • ServerApiVersion - this is the version of the server plugin API as defined by us - for Indigo 5.0, it is 1.0.0. While we hope to keep API changes to a minimum, it’s prudent to version the server API used. This key is only required if your plugin implements a server plugin.
  • Bundle display name (CFBundleDisplayName) - this is a standard Mac OS X key, and its value represents the name of your plugin. It’s used in a bunch of places in the UI, so make sure that it appropriately identifies your plugin. This key is required.
  • Bundle identifier (CFBundleIdentifier) - this is another standard Mac OS X key, and it represents a unique string that represents your plugin. This is used for namespacing where necessary in the code, so it is critical that it is unique. The standard reverse DNS naming scheme is what should be used, although if you aren’t a company you’ll need to figure something out (maybe your blog, etc.). You should limit your bundle id to standard alphanumerics as special/extended characters may cause problems. This key is required.
  • Bundle version (CFBundleVersion) - another standard Mac OS X key, and it represents the layout of the bundle. This is controlled by us, and for Indigo 5.0 it will be 1.0.0. This key is required.
  • URL types (CFBundleURLTypes) - you must specify one URL that represents a web page where your user can get support. Your plugin will have a menu item called “About [PLUGIN NAME]” - when the user selects this menu item, the default browser will open to this URL. Note - this can be a forum topic in the “User Contributions” section of our user forums if you don’t have any other place to host the support page. This key is required.
We want the user experience to be very similar for plugins, at least until it comes to configuration and use of the plugin, so you should be careful to get the Info.plist correct. Use the IndigoPluginTester Mac application to do error checking on your Info.plist and bundle construction as well as other formatting checks.
You can drop Python scripts and AppleScripts into this folder and they will show up in your plugin's sub-menu on the new “Plugins” menu. When the user selects the menu item, the script is executed. This is a really simple way of giving your plugin some visible UI. In Indigo 4, if you had loose scripts in the “Scripts” folder, they showed up under the “Scripts” menu item in the Indigo Mac Client. This is no longer the case - if you want scripts to show up in a menu somewhere, you'll need to create a plugin bundle with the scripts you want in the “Menu Items” folder. You don't need to implement a Server Plugin to do this - only have a valid Info.plist file and a Menu Items folder with your scripts.
Indigo Server Plugins
An important note here: Indigo uses Python v2.5. Python 2.6 is the default installation on Snow Leopard (2.5 is default on Leopard), and there are differences, so make sure that you're using Python 2.5 for your development or you could get a nasty surprise when you turn your code into a plugin (if you're developing code outside of the plugin architecture). Snow Leopard does have 2.5 installed, it's just not the default install. It's in this directory:
Back to Server Plugins
The IOM is used for two similar purposes: scripting Indigo and building Server Plugins. They aren’t mutually exclusive, but they serve different needs. For instance, you may just want to write an embedded Python script action vs building a full Server Plugin. Likewise, you may be interested in building a Server Plugin that doesn’t actually create any new device types, but simply adds events, actions, and menus to Indigo. This is fundamentally different from how AppleScript works with the IndigoServer.
FIXME here, we need to describe the old AppleScript embedded vs File concept and how it’s no longer necessary for IOM since IOM scripts will be run in a different process anyhow and the fact that Python scripts have to be executed within a specific environment to get access to IOM.
Indigo Plugin Host
More specifically, the IOM is presented to your plugin as a module, indigo, that all plugins automatically import. Every object that represents an Indigo object and every command that you use to communicate with Indigo is done through the indigo module. For example, to write something to the Indigo Log, you would do this:
Server Plugin Folder
Indigo Plugin XML Conventions
  • id's cannot contain spaces
Configuration Dialogs
<ConfigUI>
    <Field id="autoLabel"
            type="label"
            visibleBindingValue="false">
    </Field>
    <Field id="exampleButton"
            type="button"
        <Title>Find Node ID</Title>
    </Field>
    <Field id="nodeID"
            type="textfield"
            readonly="YES"
        <Label>Node ID:</Label>
    </Field>
    <Field type="checkbox"
            id="manualEntry"
            defaultValue="false">
    </Field>
    <Field id="manualNodeID"
            type="textfield"
            visibleBindingValue="true">
        <Label>Enter Node ID:</Label>
    </Field>
</ConfigUI>
Text Field
    <Label>Text Field:</Label>
</Field>
Attribute Required Notes
defaultValue No You can enter a default value here.
enabledBindingId No If you want to conditionally enable/disable this field based on the value of a checkbox, set this value to the id of that field.
hidden No If this attribute is set to true then the field will never be displayed regardless of what other options you have set for it. It’s useful if you need to contain some kind of state variables for the dialog that are controlled by button presses rather than controlled directly by the user.
id Yes This is a unique identifier for this Field within the context of this ConfigUI element.
readonly No This attribute will make the field readonly - useful to show the user data that changes in some other way rather than being manipulated directly by the user - in the example above clicking the Find Node ID button will populate the ID field.
tooltip No Unfortunately, enabled text fields won’t show tooltips (Cocoa limitation), so your tooltip should probably tell the user why it’s disabled (since that’s the only time it’ll show) if the field is ever disabled.
type Yes This must be textfield.
visibleBindingId No If you want to conditionally show/hide this field based on the value of another field, set this value to the id of another field. If you set this, you must also include a visibleBindingValue
visibleBindingValue No If you specify a visibleBindingId, you must specify the value(s) here. For instance, if you are binding to a checkbox, setting this to false will mean the text field is visible only when the checkbox is unchecked, and a true means the opposite. To make the field dependent on a list or menu, set this value to a comma separated list of option values (item1, item2). You can even bind it to the value in another text field, but that’s probably of limited use.
Back to Configuration Dialogs
	<Label>Popup Menu:</Label>
</Field>
defaultValue No You can enter a default value here. The value must be one of the values from the List element described below.
hidden No If this attribute is set to “true” then the field will never be displayed regardless of what other options you have set for it. It’s useful if you need to contain some kind of state variables for the dialog that are controlled by button presses rather than controlled directly by the user.
readonly No This attribute will make the field readonly - useful to show the user data that changes in some other way rather than being manipulated directly by the user.
tooltip No Unfortunately, enabled menus won’t show tooltips (Cocoa limitation), so your tooltip should probably tell the user why it’s disabled (since that’s the only time it’ll show) if the field is ever disabled.
type Yes This must be “menu”.
visibleBindingValue No If you specify a visibleBindingId, you must specify the value(s) here. For instance, if you are binding to a checkbox, setting this to false will mean the menu field is visible only when the checkbox is unchecked, and a true means the opposite. To make the field dependent on a list or another menu, set this value to a comma separated list of option values (“item1, item2”). You can even bind it to the value in a text field, but that’s probably of limited use.
</Field>
    return valuesDict
List
	<Label>List:</Label>
</Field>
defaultValue No You can enter a default value here. The value must be a comma separated list of values, each value must be listed as an option in the List element.
tooltip No The tooltip will be shown when you hover over the actual list control.
type Yes This must be list.
visibleBindingValue No If you specify a visibleBindingId, you must specify the value(s) here. For instance, if you are binding to a checkbox, setting this to false will mean the menu field is visible only when the checkbox is unchecked, and a true means the opposite. To make the field dependent on another list or menu, set this value to a comma separated list of Option values (item1, item2). You can even bind it to the value in a text field, but that’s probably of limited use.
Static list fields are constructed almost identically to static popup menu fields - with a Label element and a List element which contains multiple Option elements. Each Option element must have a value attribute and that attribute is what is what will be passed back to your plugin when the dialog is validated; it may not contain comma characters. The text inside the Option element is what is displayed for each line in the user interface.
Dynamic Lists
</Field>
Class: indigo.devices
Optional Filters Description
indigo.relayrelay devices
indigo.dimmerdimmer devices
indigo.sprinklersprinklers
indigo.thermostatthermostats
Class: indigo.triggers
indigo.varChange variable changed triggers
</Field>
def myListGenerator(self, filter="", valuesDict=None, typeId="", targetId=0)
	# From the example above, filter = “stuff”
	# Create an array where each entry is a list - the first item is
	myArray = [(“option1”, ”First Option”),(“option2”,”Second Option”)]
	return myArray
</Field>
</Field>
Serial Port
Checkbox
	<Label>Checkbox:</Label>
</Field>
type Yes This must be “checkbox”.
defaultValue No You can enter a default value here. The value must be either true or false.
visibleBindingValue No If you specify a visibleBindingId, you must specify the value(s) here. For instance, if you are binding to a checkbox, setting this to false will mean the menu field is visible only when the checkbox is unchecked, and a true means the opposite. To make the field dependent on another list or menu, set this value to a comma separated list of option values (item1, item2). You can even bind it to the value in a text field, but that’s probably of limited use.
</Field>
    return valuesDict
Label
<Field id="exampleLabel" type="label"
	</Label>
</Field>
type Yes This must be label.
Separator
<Field id="simpleSeparator1"
		type="separator"
		visibleBindingValue="1"/>
type Yes This must be separator.
Button
		type="button"
		visibleBindingValue="1">
</Field>
type Yes This must be button.
The process flow is this:
    <Name>Music Server</Name>
    <ConfigUI>
            <Title>Begin Pairing</Title>
        </Field>
<!-- SNIP -->
</Device>
    return valuesDict
Validation Methods
action validateActionConfigUi(self, valuesDict, typeId, actionId) typeId - action type specified in the type attribute
actionId - the unique action ID for the action being edited (or 0 of it's a new action)
def validateEventConfigUi(self, typeId, eventId, valuesDict):
    return True
    return (True, valuesDict)
  3. An error dictionary. The keys will be the fieldId and the value will be the error string. When the dialog receives this return, it will turn each field with an error red and add a tooltip to the label part of the field so the user can mouse over the label to see what’s wrong.
    errorDict = indigo.Dict()
Validating serialport Fields
	errorsDict = indigo.Dict()
	if len(errorsDict) > 0:
Notice that at the top of the validation method after we define the errorsDict, we call self.validateSerialPortUi(). This method will look for the fields that make up the specified field (“devicePortFieldId” in this case). It will make sure that a valid serial port is selected if it's a physical connection or that the address field is formatted properly if it's one of the network connections. If not, it will automatically add the appropriate errors to the errorsDict and will attempt to correct any URL prefix errors (“socket://” or “rfc2217://”). You can then continue to validate the rest of the fields in your dialog and use the length check on errorsDict to see if there were any errors discovered. If so, return False along with both dicts. If it's empty, just return true with the valuesDict.
Dialog Close Notification
Dialog Type Method Signature
PluginConfig.xml
<?xml version="1.0"?>
<PluginConfig>
</PluginConfig>
/Library/Application Support/Perceptive Automation/Indigo 5/Preferences/Plugins/
Devices.xml
Name Type Required Notes
type Attribute Yes This must be one of: relay, dimmer, or custom. We’ll discuss each below.
States Element No This element is only used for custom device types. It describes all the possible states for the device. See the description below for more details.
In this first iteration of our plugin API, we are going to allow you to define three types of devices: relay, dimmer, and custom. Relay and dimmer devices will share the common UI, states, actions that the corresponding INSTEON and X10 devices do.
FIXME: describe type and how it effects the control UI for the device
Relay Device Type
Relay devices are functionally equivalent to appliance modules - they support only one state: on state. They also support a status request. The definition of a relay device is pretty simple:
<Device type="relay" id="appliance">
    <Name>Appliance Module</Name>
    <ConfigUI>
        <SupportURL>http://www.yourdomain.com/plugin/relay.html</SupportURL>
        <Field id="autoLabel" type="label"
        </Field>
        <Field id="exampleButton" type="button" >
        </Field>
        <Field id="nodeID" type="textfield">
        </Field>
        <Field id="simpleSeparator1" type="separator"
                visibleBindingId="manualEntry" visibleBindingValue="0"/>
        <Field type="checkbox" id="manualEntry" defaultValue="no">
        </Field>
        <Field id="manualNodeID" type="textfield"
                visibleBindingId="manualEntry" visibleBindingValue="1">
        </Field>
    </ConfigUI>
</Device>
The device definition above will show the user the following when a new device is created in Indigo:
When the user selects “Plugin” from the “Type:” menu, the “Plugin” and “Device” popups will be shown. When the user selects your plugin from the “Plugin” popup, a list of all the device types you’ve defined will be populated in the “Device” popup. The string in the <Name> element (see above) is what’s used for the menu items.
FIXME: insert the Python handling code here for turnOn, turnOff, statusRequest
Dimmer Device Type
Like a relay device, a dimmer device type will inherit the UI, actions, etc. that all other dimmer type devices have. They have two states: on state and brightness level. They also have a status query action. The XML for a dimmer device would look exactly the same as the XML for a relay except that the id attribute would be dimmer.
Custom Device Type
The custom device type is where the real action happens. Because it’s completely custom, you must specify everything about the device - it’s states and their types (Integer, Float, String, List (enumeration), Boolean). So, here’s a simple example of the <States> element of a custom device, in this case a thermostat:
    <State id="temperature">
        <ValueType>Float</ValueType>
    <State id="heatSetPoint">
    <State id="coolSetPoint">
    <State id="mode">
TriggerLabel Element Yes When selecting “Device State Changed” type trigger events, you can select your device in the resulting list. A popup below the device will list all of your States using this text. FIXME: Add image below
ControlPageLabel Element Yes In the Control Page Editor, when selecting “Device State” as the display type, then select your device, the next popup will show all your states using this text. FIXME: Add image below
Events.xml
<Events>
    <Event id="updateAvailable">
    </Event>
</Events>
<Event id="sep1"/>
FIXME need to add some Python examples of how to notify the server that one of these events has occurred
Actions.xml
<Actions>
    <Action id="resetInterface">
        <Name>Reset Interface</Name>
    </Action>
</Actions>
As with <Event>, your <Action> elements can define a <SupportURL> element as well - the actions dialog now has a help button on it and if one of your actions is selected clicking on the help button will take your user to the specified URL. If you don’t specify one then the default help page for all trigger events will show. You can specify an Action to be a separator in your action list so that when they're displayed in the UI there is a visual separation. Simply insert an Action defined like this between two other Action elements:
<Action id="sep1"/>
def writeToLog(self, action):
    theMessage = self.substituteVariable(action.props.get("message", ""))
    if theType:
        indigo.server.log(theMessage)
Note: To increase the value of your plugin, you should ensure that you test and document the necessary information so that Python scripters can script your plugin's actions - for instance, a scripter can tell the iTunes to pause playback. You can provide that information in a relatively straight-forward way in your plugin's documentation as we've done with our plugins (check the Airfoil and iTunes docs for examples). You shouldn't really have to do much - but you should test each action. Sometimes you can make assumptions about the data that you get from your action's ConfigUI that you may want to change - for instance you may expect data when it would be advantageous to not include it (optional data) from a scripters perspective.
<MenuItems>
    <MenuItem id="menu1">
    </MenuItem>
    <MenuItem id="menu2">
    </MenuItem>
    <MenuItem id="menu3">
        <ConfigUI>
			<Label>Light:</Label>
		</Field>
        </ConfigUI>
    </MenuItem>
</MenuItems>
CallbackMethod Element No 1.0 This is the name of the method defined in your plugin that will be called when your user selects this menu item.
ConfigUI Element No 1.1 If you want a menu to open an associated dialog, you can include a standard ConfigUI element (see Configuration Dialogs above for details).
def checkForUpdates(self):
plugin.py
There are a few methods that the host process will call at various times during your plugins lifecycle, some required and others are optional:
General Plugin Methods
__init__(self,
         pluginId,
         pluginDisplayName,
         pluginVersion,
         pluginPrefs)
__del__(self)
def __del__(self):
startup(self)
def start(self):
    indigo.server.log(u"Start called")
shutdown(self)
def shutdown(self):
runConcurrentThread(self)
No This method is called in a newly created thread after the Start method finishes executing. It’s expected that it should run a loop continuously until asked to shutdown.
    while True:
        # Do your stuff here
        self.sleep(60) # in seconds
except self.StopThread:
    # do any cleanup here
    pass
stopConcurrentThread(self)
    self.stopThread = True
prepareToSleep(self)
wakeUp(self)
Device Specific Methods
getDeviceStateList(self,
                   dev)
getDeviceDisplayStateId(self,
                        dev)
deviceStartComm(self,
                dev)
No If your plugin defines devices, this is likely the place where you'll want to do the work of starting your device up. For instance, let's say that you have a device somewhere out on the network - the easiest way to “start” your device is to implement this method. You would open the network addrss:port (that's defined in dev.pluginProps), get it's current state(s) and tell the IndigoServer to set those states (using the dev.updateStateOnServer() method).
deviceStopComm(self,
               dev)
                            origDev,
                            newDev)
deviceCreated(self,
              dev)
No This method will get called whenever a new device defined by your plugin is created. In many circumstances, you won't need to implement this method since the default behavior (which is to call the deviceStartComm() method if it's your device and it's enabled) is what you want anyway (see the deviceStartComm() method above for details). However, if for some reason you need to know when a device is created, but before your plugin is asked to start communicating with the device, this method can provide that hook. If you implement this method, you'll need to either call deviceStartComm() or duplicate the functionality here.
You can also have this method called for devices that don't belong to your plugin. If, for instance, you want to know when all devices are created (and updated/deleted), you can call the indigo.devices.subscribeToChanges() method to have the IndigoServer send all device creation/update/deletion notifications. Why? Maybe you're logging all device changes - or maybe you're managing a scene and need to know when the devices in your scene change. Subscribing to changes should be used very sparingly since it's a lot of overhead both for your plugin and, more importantly, for the IndigoServer.
deviceUpdated(self,
              origDev,
              newDev)
deviceDeleted(self,
              dev)
Trigger Specific Methods
triggerStartProcessing(self,
                       trigger)
triggerStopProcessing(self,
                      trigger)
                                   origTrigger,
                                   newTrigger)
triggerCreated(self,
               dev)
triggerUpdated(self,
               origDev,
               newDev)
triggerDeleted(self,
               dev)
Schedule Specific Methods
FIXME add schedule stuff
Action Group Specific Methods
Name Required Notes
FIXME add action group stuff
Variable Specific Methods
Name Required Notes
variableCreated(self, var)
variableDeleted(self, var)
                                bundleID)
browserOpen(self,
            url)
debugLog(self,
         msg)
msg - the string to insert into the event log None If, at any point in your plugin, you set self.debug = True, then any time debugLog is called the string will get inserted into Indigo's event log. If self.debug = False (the default) any call to debugLog does nothing.
errorLog(self,
         msg)
msg - the string to insert into the event log None If you want an error to show up in the event log (in red text), use this log method rather than indigo.server.log().
openSerial(self,
         ownerName,
         portUrl, baudrate, bytesize,
         parity, stopbits, timeout,
         dsrdtr, interCharTimeout)
serial.Serial instance This method is identical to creating a new pySerial Serial object except that it never throws an exception. If the serial connection cannot be openned then None is returned and an error will be automatically logged to the Indigo Server event log.
sleep(self,
         seconds)
substituteVariable(self,
                   inString,
                   validateOnly=False)
String if validateOnly is False
(BOOL, errStr) if validateOnly is True
%%v:VARID%%
FIXME should discuss the plugin flow for several types of plugins: with devices, events, actions - and plugins that use runConcurrentThread and plugins that start up threads, etc., so that it'll be easier to try and envision how to approach thinking about a plugin.
FIXME Discuss the prefs and prefs file (cached and written only periodically or when the plugin quits)
3rd Party Python Libraries
PySerial v2.5 - just “import serial” at the top of your script. PySerial allows your plugins/scripts to access any serial ports on your Mac. The EasyDAQ plugin uses PySerial for it's serial communication so you may find it useful to look at the code for that plugin for examples.
py-appscript v1.0.0 - “import appscript” at the top of your script. Appscript allows you to use apple events to control other applications. Apple events are what AppleScript uses - py-appscript uses the same underlying events. The syntax is obviously Python but it requires a little getting used to. The Airfoil plugin uses py-appscript so you may find it useful to look at the code for that plugin for examples.
simplejson v2.2.1 - simplejson is included in Python v2.6 and higher - but since we're using 2.5 we've included it in the install. Just “import simplejson”.
indigo_5_documentation/plugin_guide.txt · Last modified: 2014/05/28 16:15 (external edit)
