To launch the Terminal utility application (inside /Applications/Utilities/
) in an Indigo shell mode choose the Plugins→Open Scripting Shell
menu item.
– or –
If you already have a Terminal shell running, you can launch it directly. The file path to the IPH executable is a bit deep, so create an alias to it inside your .bashrc
(or .bash_profile
) file by copying/pasting this into the Terminal (you only need to do this once!):
echo "alias indigohost='/Library/Application\ Support/Perceptive\ Automation/Indigo\ 5/IndigoPluginHost.app/Contents/MacOS/IndigoPluginHost'" >> ~/.bashrc
Next, close the Terminal window and open a new one to load the shortcut alias to the IPH executable. To start the IPH in interactive mode we pass the -i
flag to it inside the Terminal:
indigohost -i
As shown, the IPH will automatically connect to the IndigoServer running on the same Mac and will show the server's version information. Additionally, you'll notice that Indigo Server logs the connection of the interactive shell plugin.
ssh username@indigo_mac_ipaddr -t "/Library/Application\ Support/Perceptive\ Automation/Indigo\ 5/IndigoPluginHost.app/Contents/MacOS/IndigoPluginHost" -i
indigohost -e 'return indigo.devices["office lamplinc"].brightness'
indigohost -e ' indigo.device.toggle("office lamplinc") indigo.device.toggle("office lamplinc") indigo.device.toggle("office lamplinc") '
Caveat: Each call creates a new IPH (indigohost) process which must establish a connection to the Indigo Server. Although this is relatively fast, calling it multiple times a second is not recommended.
indigohost -x /SomeFolder/indigo_script.py'
In Indigo, if you want to write AppleScript handlers that are shared by any script that Indigo executes, you can just put an AppleScript full of handlers in the /Library/Application Support/Perceptive Automation/Indigo 5/Scripts/Attachments folder. You can do the same thing with Python using a built-in mechanism that Mac OS X supports for Python. There is a folder in the Library folder at the top level of your boot disk that is very similar to the Attachments folder:
/Library/Python/2.5/site-packages
Any Python files in this directory that define methods and/or classes will be loaded by the Python interpreter whenever it's loaded (note that it's the Library directory at the top level of your boot disk, not the one in your user folder). So, you can create files of handlers you want to share between all Python scripts. Files here can also import the entire IOM - IF the script that's actually running is started by Indigo. Here's a simple shell that you can use that will safely import the IOM and will show a specific error when used from a Python script that's not started by Indigo:
#!/usr/bin/env python2.5 """ indigoAttachments.py In this file you can insert any methods and classes that you define. They will be shared by all Python scripts - you can even import the IOM (as shown below) but if you do then you'll only be able to import this script in Python processes started by Indigo. If you don't need the IOM then skip the import and it'll work in any Python script no matter where it's run from. """ try: import indigo except ImportError: print "Attachments can only be used from within Indigo" raise ImportError def specialLog(text): indigo.server.log(text, type="indigoAttachments")
import indigoAttachments indigoAttachments.specialLog("Here's a special sort of log message")
FatMac:testdir jay$ python2.5 testHandlerCall.py Attachments can only be used from within Indigo Traceback (most recent call last): File "testCallingIndigo.py", line 3, in <module> import indigoAttachments File "/Users/jay/Library/Python/2.5/site-packages/indigoAttachments.py", line 14, in <module> raise ImportError ImportError
Indigo plugins are also scriptable. Because plugin-defined devices look almost identical to built-in devices, you can get (but not set) state information from them (see device examples a bit further down for a lot of examples). You can also get some of the other properties for a plugin. Most importantly you can execute plugin-defined actions, which is how you'd set their state values.
pluginDisplayName | The name displayed to users in the clients |
pluginId | The ID of the plugin (same as was passed to the getPlugin() method above) |
pluginSupportURL | The URL supplied by the plugin that points to it's user documentation |
pluginVersion | The version number specified by the plugin |
itunesId = "com.perceptiveautomation.indigoplugin.itunes" itunesPlugin = indigo.server.getPlugin(itunesId) if itunesPlugin.isEnabled(): itunesPlugin.executeAction("playPause", deviceId=135305663)
itunesId = "com.perceptiveautomation.indigoplugin.itunes" itunesPlugin = indigo.server.getPlugin(itunesId) if itunesPlugin.isEnabled(): itunesPlugin.executeAction("setVolume", deviceId=135305663, props={'volume':50})
itunesId = "com.perceptiveautomation.indigoplugin.itunes" itunesPlugin = indigo.server.getPlugin(itunesId) if itunesPlugin.isEnabled(): myWeatherStation = indigo.devices[1798384204] outsideTemp = myWeatherStation.states['temperatureF'] currentCondition = myWeatherStation.states['currentCondition'] spokenString = "The current temperature is %s degrees. Current condition is %s." % (outsideTemp, currentCondition) itunesPlugin.executeAction("pauseAndSay", deviceId=135305663, props={'message':spokenString})
Below are some example you can copy/paste directly into the Terminal application (running the IPH via the indigohost -i
command explained above). Keep in mind these are only examples, so be sure and read over the full Indigo Object Model (IOM) Reference.
Note: For simplicity some of the samples below specify objects based on name (“office desk lamp”
indigo.device.duplicate("office desk lamp", duplicateName="office desk lamp2")
indigo.device.turnOn("office desk lamp", duration=2, delay=4)
indigo.device.allOff()
indigo.devices.len()
lamp = indigo.devices["office desk lamp"] if hasattr(lamp, 'onState'): isOn = lamp.onState
lamp = indigo.devices["office desk lamp"] if lamp.__class__ == indigo.DimmerDevice: theBrightness = lamp.brightness
newVar = indigo.variable.create("fooMonster", "default value") indigo.variable.updateValue(newVar, "asleep") indigo.variable.updateValue(newVar, "awake") indigo.variable.delete(newVar)
myVar = indigo.variables[123] if myVar.value == "true": indigo.server.log("The variable had a value of 'true'")
indigo.server.getTime()
lamp = indigo.devices["office desk lamp"] indigo.server.log(lamp.name + ": \n" + str(lamp))
try: myFolder = indigo.triggers.folder.create("My Triggers") except ValueError, e: if e.message == "NameNotUniqueError": # a folder with that name already exists so just get it myFolder = indigo.triggers.folders["My Triggers"] else: # you'll probably want to do something else to make myFolder a valid folder myFolder = None
# Simple Example indigo.server.sendEmailTo("emailaddress@company.com", subject="Subject Line Here", body="Some longish text for the body of the email") # Putting a variable's data into the subject and body theVar = indigo.variables[928734897] theSubject = "The value of %s" % (theVar.name) theBody = "The value of %s is now %s" % (theVar.name, theVar.value) indigo.server.sendEmailTo("emailaddress@company.com", subject=theSubject, body=theBody) # Putting device data into the subject and body theDevice = indigo.devices[980532604] theSubject = "Summary of %s" % (theDevice.name) theBody = "%s is %s\n%s is %s" % ("onState", str(theDevice.onState), "lastChanged", str(theDevice.lastChanged)) indigo.server.sendEmailTo("emailaddress@company.com", subject=theSubject, body=theBody)
Add examples for:
