First, you'll need the Indigo software. Indigo comes in two versions: Indigo Pro, our full product, and Indigo Lite, a version that supports more modest automation needs. There are several places in the documentation where you'll see (Pro only feature) - that indicates that the feature/function being described is only available to Indigo Pro users. The primary difference is 3rd party plugin support which is limited to Indigo Pro. See our version comparison chart for details on the differences.
To install the latest Indigo software, you'll need a Mac that meets these OS and hardware requirements:
Additionally, you may use Indigo 6.0.21 on the following systems (just keep in mind that we are no longer supporting Indigo 6.0.x so newer devices may not work):
Out of the box, Indigo (both Pro and Lite) supports the following Home Automation protocols (simultaneously) via a separate hardware interface device:
Z-Wave is a very popular home automation technology that's used worldwide. There are many different manufacturers of Z-Wave devices so the selection is quite good. To use Z-Wave with Indigo, you'll need a Z-Wave interface (often referred to as a dongle): Indigo supports Z-Wave via the Aeotec Z-Stick Series 2 interface or the EZController / Z-Troller interfaces. Other USB and serial Z-Wave interfaces may work as well but we've concentrated our efforts on the Z-Stick / EZController / Z-Troller.
Other device types will be added over time. Check our Supported Z-Wave Module List to see if a specific module has been tested. Note however that just because a module isn't listed doesn't mean that it won't work - Z-Wave is architected such that devices that correctly support Z-Wave features should automatically work. There are so many different devices from many different manufacturers that we will never be able to test them all. If you have a device that isn't listed but works, please feel free to report it to us and we'll add it to the list. There is a very simple mechanism to report devices, described in Editing a Z-Wave Device's Properties towards the end of that section.
INSTEON is a protocol developed by SmartLabs, parent company of Smarthome.com, which is widely used in North America and is moving into other markets as well. There are a few 3rd party vendors that make INSTEON hardware but most devices are made by SmartLabs. To use INSTEON with Indigo, you'll need an INSTEON interface. These are the INSTEON interfaces that Indigo supports:
We also support the following discontinued INSTEON interface:
Indigo supports the vast majority of INSTEON devices - see our Supported INSTEON Devices List for a complete list.
X10 is a legacy technology that works primarily over the power line though some devices are wireless (using the X10 RF protocol). We don't recommend anyone start a new home automation system using X10 because of it's poor reliability - however, if you have existing X10 devices you can definitely use them with Indigo if you have a compatible X10 interface. These are the X10 interfaces that Indigo supports:
We also support the following discontinued X10 interfaces:
If you don't have any of the above hardware, you can still install and use Indigo - particularly if you have hardware supported by one of the many 3rd party plugins (requires Indigo Pro). For instance: RFXtrx433 with support for Home Easy/Chacon, X10 RF, LightwaveRF, and many different types of sensors; Nest and Aprilaire Thermostats; Alarm Panels; A/V equipment; etc. See our plugin list for all available 3rd party plugins. Indigo Pro also ships with some useful plugins out of the box.
Indigo can run as a standalone application on a single Mac or can be run in a client/server mode on two or more Macs. In either case, you must first run the Indigo installer on the main Mac (also referred to as the server Mac) to which the home automation interface hardware (Z-Stick, EZController / Z-Troller, PowerLinc, CM11, etc.) will be connected. Just download the latest Indigo installer. This should download the disk image. In Safari, click the downloads button (the down arrow to the right of the URL/search bar). You should see an entry titled “Indigo.dmg”. Double-click that and you should get switched to the Finder and a dialog will show that the disk image is being mounted. Once it's mounted, a window will open with the following files:
The Indigo 6 application can be found here:
/Applications/Indigo 6
/Library/Application Support/Perceptive Automation/Indigo 6/
Database files are stored in the Database
folder in that folder.
Note: this is the Library folder at the top level of your hard drive, not the one in your User folder. Lion and greater hide these folders by default, but if you select the “Go→Go to Folder…” menu item in the Finder and paste in the path above it will open that folder in a Finder window.
Note: this is the Library folder at the top level of your hard drive, not the one in your User folder. Use the Go→Go to Folder… menu item in the Finder and paste in the path above to get there easily).
Time Machine will do this by default. To recover, just recover that directory and then run the Indigo 6 installer again (which will repair any permission issues that Time Machine may have introduced).
Scripts:
/Library/Application Support/Perceptive Automation/Indigo 5/Scripts/
Control Page Images:
/Library/Application Support/Perceptive Automation/Indigo 5/IndigoWebServer/images/
Web Server Plugins:
Scripts:
Web Server Plugins:
NOTE: Do not replace the Indigo 6 versions of any file with your Indigo 5, 4, 3, or 2 files. They have been modified to run optimally under Indigo 6.
[~your user home folder]/Documents/Indigo User Data/Scripts/
) to the new folder specified above if you modified or added new script or script attachment files.NOTE: Do not replace the Indigo 6 versions of any file with your Indigo 1.x files. They have been modified to run optimally under Indigo 6.
NOTE: this is not the Library folder that's in your home directory - it's the one at the top level of your hard drive. The easiest way to get there is to select the “Go→Go To Folder…” menu item in the Finder and paste in this:
To uninstall Indigo, make sure that you have the server and client completely shut down (select Stop Server
from the Indigo 6
menu before you quit the Indigo Mac Client). Then, delete the following files:
The first three directories are at the top level of your hard drive. The last four are in the Library folder that's in the home directory of the account Indigo runs under. In Mac OS X Lion and higher, the Library folder is hidden in the Finder so you'll have to use the Go to Folder…
menu item in the Finder and type in the path (“~/Library/Preferences”) - that will open a Finder window to the Preferences folder. The last three aren't really required to uninstall but they are included for completeness.
Indigo 6
application (/Applications/Indigo 6).Indigo 6
button in the connection status window.Indigo 6→Start Local Server…
menu item.
If you only have one Mac and do not wish to remotely access Indigo from a Web browser, iPhone, or iPod Touch, then you can choose the Run client/server as single application
radio button. This will automatically run the client/server as a single application. This requires that the Indigo UI always be running on your Mac - when you quit the Applications→Indigo 6 application all Indigo event processing (triggers, schedules, scripts, etc.) will cease processing. This is not our recommended configuration.
Choose the Start and connect to Indigo Server
Use the Allow remote access
checkbox to enable remote access from other Macs and Web browsers.
Use the Enable iPhone, iPod Touch, and remote Web browser access
checkbox to allow Indigo Touch (must be downloaded from the iTunes App Store) and remote Web browser access from other computers. Any modern Web browser (Safari, Firefox, Opera) on any computer that has internet access to your server Mac will be able to control and check the state of your home.
Use the Enable remote RSS feeds
checkbox to turn on the RSS and Atom server feeds, giving you RSS/Atom access to the last modified time stamp of all Indigo Devices.
Use the Require authentication
checkbox to enable password protection for both remote Indigo Clients and Web browser access. It is highly recommended that you enable authentication and assign a strong password.
Use the Enable anywhere secure access
checkbox for secure Web browser access from anywhere. This option requires a subscription to the Prism Reflector service, which handles maintaining the secure connection to Indigo Server automatically.
checkbox to allow remote Indigo Clients on other Macs to connect to the Indigo Server (Pro only feature).
checkbox to change the TCP/IP port number that the Mac OS X client uses to connect to the server (Pro only feature).
Use the Log Device state history to SQLite or PostgreSQL
checkbox to efficiently save Indigo Device state changes, Variable value changes, and Event Log messages to a SQLite or PostgreSQL database. Visit the online support forum for installation and configuration instructions (Pro only feature).
Press the Start Server
button, or the Restart Server
If this is the first time you've started the server, you'll be prompted first to click through our Enduser License Agreement (EULA), then you'll see the server registration dialog:
Enter you name and registration code exactly as they appear in your registration email (copy/paste works best) and click OK. The server will continue to start up.
If you purchased a retail disk, you should enter your full first and last name along with the registration code exactly as it appears on the label on the disk sleeve. When you click OK you'll be prompted to register your copy on our website.
While this isn't required, it's highly recommended. If you don't, we won't be able to locate your registration code in the future should you need it again - and you will to get discounted upgrades to major new releases and access to dot releases.
If you desire easy remote Indigo Server access from outside your home, then you may want to subscribe to the Prism Reflector service, which provides secure Indigo Touch and remote Web browser access from anywhere with no network configuration needed. A free trial subscription is available for all Indigo customers.
In order to remotely access the Indigo Server we must enable the ports Indigo Server uses in the system's network firewall. Follow these steps on the Mac running Indigo Server if you are running Mac OS X 10.7 or earlier (later systems will automatically prompt you if required so you shouldn't need to adjust any settings).
Indigo 6→Stop Server
menu item.Apple Menu→System Preferences
menu item.Security
preference panel.Firewall
tab.Set access for specific services and applications
radio button.Indigo 6→Start Local Server…
menu item and pressing the Start Server
button.IndigoServer.app
and Python.app
. Press the Allow
button for each.The Indigo Web Server advertises itself via Bonjour, so Indigo Touch and Safari (by clicking on the bookmarks icon, then selecting Bonjour) will automatically find any local servers. In addition to that, when connecting to a local server for the first time, Indigo Touch will also automatically fetch Prism Reflector settings for that connection so that you'll be able to connect outside your LAN via LTE/4G/3G/Edge.
For other browsers to remotely access the Web server, we need to know the network IP address for the Mac running Indigo Server. This address will be used on the remote Mac or Web browser when connecting to the Indigo Server. Follow these steps on the Mac running Indigo Server.
menu item.Sharing
preference panel.File Sharing
is not turned on, then temporarily enable it.IP address
is the number portion of the URL (ex: 192.168.1.4
).System Preferences
window.You now have the IP address for the Mac running Indigo Server. Depending on your home network setup, this IP address may change periodically, such as when the Indigo Server Mac or router is restarted. If this happens, then you can use the steps above to discover the IP address again, or you can configure a static (not dynamic) IP address for the Mac running Indigo Server.
Indigo 6
application (inside /Applications/Indigo 6
) on the remote Mac.Indigo 6
on this remote Mac, then press the Connect to Remote Server… button in the connection status window.Indigo 6→Connect to Remote Server…
menu item.IP address
button.NOTE: the Indigo Mac Client doesn't use the Prism Reflector service. Connecting an Indigo Mac Client to a server over the internet is a complex topic that is well beyond this document – we suggest you search our online forums for others that have configured this type of access.
Indigo Touch, the iPhone and iPod Touch application from Perceptive Automation, allows the user to view and control Devices, activate Action Groups, view Variables, and access custom Control Pages (Pro only feature). One of the best features of Indigo Touch is it's ability to automatically detect and configure network connections. If your iPhone (or iPod Touch) is connected to your local wireless LAN, then it should automatically discover your server. In Indigo Touch, tap the Settings
At this point, Indigo Touch will also query the server to see if you have a Prism Reflector account set up for the server. This makes connecting to your home server via Indigo Touch completely seemless. If you have a reflector set up and running, then Indigo Touch will automatically attempt to connect no matter where you are or how you're connected. If you're local, it will use the local wireless LAN, If you're on a remote wireless LAN, it will attempt to use the reflector account. If you're iPhone is on LTE/4G/3G/Edge, it will also attempt to connect via your reflector account. This makes Indigo Touch truly location agnostic!
on the Settings
Indigo, when run in client/server mode, will automatically start its built-in Web server on launch. This allows access from remote Macs, PCs, and other internet devices like the iPhone, iPod Touch, Nokia 770 and PepperPad. Any device that can run a modern Web browser (Safari, Firefox, Opera) will work.
http://192.168.1.23:8176/
Alternatively, if you already have the Indigo Client on a remote Mac connected to the Indigo Server, then you can use Indigo's Go→Browser…
menu items to open a new browser page pointing to the built-in Web server.
The Aeotec Z-Stick Gen5 uses a built-in driver included with Mac OS X (AppleUSBCDC Modem), so you don't need to install any drivers for it.
The Aeotec Z-Stick Series 2 interface requires that you install the Silicon Labs VCP Driver Kit for Mac OS X. Make sure you have restarted after the installation process. If you reinstall your OS, then you will need to rerun the driver installer.
The Z-Troller (EZController) is a serial interface so it will require the use of a serial-to-USB adaptor. You'll need to install the appropriate drivers for your adaptor. We highly recommend getting an adaptor that uses the FTDI chipset as they seem to be the most reliable virtual comm port drivers for Mac OS X.
As mentioned before, other Z-Wave Interfaces that support the Z-Wave Serial API may be compatible and those may require other drivers. See the vendor for more information.
Interfaces→Z-Wave→Enable
menu item. This should cause the Configure Z-Wave
dialog to open automatically (but only the first time you enable Z-Wave - you can select the Interfaces→Z-Wave→Configure…
menu item to get back to the configuration dialog later): Connection Type
of Local (physical)
is correct (assuming you've plugged your Z-Stick directly into your Mac).Serial Port
popup, you should select the serial port titled SLAB_USBtoUART
(for Z-Stick Series 2) or one that starts with usbmodemfd
(for Z-Stick Gen5), depending on which Z-Stick version you have. If you have two serial ports that start with SLAB_USBtoUART
that means that you have multiple devices that use the Silicon Labs VCP driver - you'll just need to try each one to determine which is the correct port if you don't know beforehand. Unfortunately, that driver doesn't handle multiple devices using the Silicon Labs chip very well, and that number may change when you reboot. Show debug logging of interface communication
checkbox unchecked.Configure Z-Wave
dialog.
Choose the Interfaces→Z-Wave→Disable
(or Enable
The PowerLinc 2412U, 2413U, and 2448A7H interfaces should be plugged directly into one of your Mac's USB ports (preferably not into a USB hub port) and require the FTDI Virtual COM Port (VCP) driver to be installed. If you are using Mac OS X 10.9 (Mavericks) or better, it has the driver already installed.
For earlier versions of the OS, you can get the driver installer at FTDI's web site - be sure to get the installer that's appropriate for the architecture of your machine (Intel or PowerPC). If you select PowerLinc 2412U/2412S/2413U/2413S/2448 from the Interface type
with a separate USB to serial adapter, you can ignore that warning alert.
Plug the interface directly into an outlet (with the exception of the PowerLinc 2448). Do not plug the interface into your computer's power strip because many power strips contain filters that will severely degrade the INSTEON / X10 signal quality being received and transmitted by the interface. Additionally, uninterruptible power supplies (UPSs) can cause signal quality problems. If at all possible plug the interface into a different outlet than used by power strips and UPSs. Signal filters are available to isolate computer power strips and UPSs as well.
Indigo is pre-configured to recognize and use the PowerLinc 2414U/1132CU/1132U interfaces but not the other PowerLinc models. If you are using the PowerLinc 2414U/1132CU/1132U, then you can skip to the Enabling and Disabling Communication section below by choosing the Interface→Connect
menu item. Depending on the PowerLinc, Indigo may have to upload information and synchronize with it, which can take a couple of minutes. If you receive an error or are using a different interface model, then manually configure the interface.
Indigo 6→Preferences…
menu, then make sure the Interfaces
tab is selected.Enabled
checkbox next to the INSTEON / X10 Powerline Interface
item.INSTEON/X10 Power Line Interface
line in the table (you can also get to this dialog by selecting the Interfaces→INSTEON/X10 Power Line→Configure…
menu item)Interface type
in the popup menu.Serial port:
popup menu will be enabled and the FTDI driver (see Install the Correct Drivers above) will create a new Serial port:
popup menu item that looks like usbserial-XXXXXXXX
. Select that item. NOTE: you must have the FTDI driver installed already.Serial port:
popup menu will be disabled because these interfaces do not use a virtual serial port driver.Serial port:
popup menu will be enabled and you should choose which serial port adapter name the interface is connected to in the Serial port:
popup menu. NOTE: if no names are listed in the Serial port:
popup menu, then you probably do not have the proper driver installed for your USB serial adapter. Download your adapter's driver from the driver manufacturer's website.Group addresses on transmission
checkbox to combine like-command transmissions together. For example A1-On, A3-On, A4-On, would be transmitted as A1, A3, A4, On.
Choose the Interfaces→INSTEON/X10 Powerline→Disable
(or Enable
The process for connecting X10 RF Interfaces is basically the same as for power line interfaces - you just need to select the correct serial port. The W800USB will require installing the FTDI drivers mentioned above. You only need to use this interface if you're using a separate X10 RF interface like the W800 or MR26. If you are using a CM15 then enable it in the Connecting INSTEON and X10 Power Line Interfaces section above.
You can also enable/disable and configure the various built-in interfaces by selecting the Interfaces→Manage Interfaces…
menu item or by opening the preferences dialog by selecting the Indigo 6→Preferences…
menu item then clicking on the Interfaces
tab.
Indigo Pro includes the ability to use plugins developed by 3rd party developers (see our plugin list for available plugins). To install a plugin, just download it from the source (wherever that may be) onto your Indigo Server Mac, then in the Finder double-click the .indigoPlugin
file (if the file ends with .zip
, then you will have to unzip it first by double-clicking). This will open the Indigo Mac Client application and ask you if you want to install it. If you agree, the first time you install a plugin it will automatically open the plugin's configuration dialog (if it has one).
You can also open the config window choosing the Indigo 6→Preferences…
tab. Make sure the plugin is enabled (by checking the Enabled
checkbox) then double-click on the plugin's name (or select it and click the Configure…
button).
This will open the configuration dialog for the individual plugin.
You can also enable/disable and configure the various plugins by selecting the Plugins→Manage Plugins…
menu item then clicking on the Plugins
tab.
Indigo has built-in support to both send and scan (Pro only feature) emails. Using this functionality, Indigo can provide remote notification of triggers, such as motion detection or power failures. You can also control Indigo remotely. For example, you could send Indigo an email from your mobile phone to turn on lights or change your home's thermostat temperature.
Typically, ISPs or other email service providers allow multiple email addresses for each customer. We recommend that you create a new email address specifically for Indigo, such as jetsons-house@myisp.com. Using a separate email address for Indigo will eliminate the possibility that Indigo might trigger an action from a personal email not intended for Indigo, and will allow you to use the Delete from server
options shown below to reduce mailbox clutter.
menu item, then make sure the Email
tab is selected.Reply-to email address
field. Note that some SMTP mail servers are configured to not send emails unless the reply-to address specified matches the email address for the account. If mail sending fails, then make sure that the reply-to email address matches the email address for your account.Indigo 6→Preferences…
tab is selected.Check email every
checkbox.Delete from server emails that trigger actions
to have Indigo automatically remove any email messages that cause Indigo to trigger an action from your mail server. You should only use this option if Indigo has a dedicated email account.Delete from server all emails
to have Indigo automatically remove all email messages from your mail server. You should only use this option if Indigo has a dedicated email account.Once the Preferences dialog is closed, Indigo will automatically connect to your mail server to scan messages. This will happen within 10 seconds from the time the Preferences dialog is closed. Watch the progress bar in the main window and look for error messages in the Event Log Window to verify that Indigo was able to correctly connect.
To have Indigo send an email, create a Send Email
action.
To execute an action based on a scanned email, create an Email Received
trigger (Pro only feature).
System Preferences
from the Apple
menu.Date & Time
icon.Time Zone
panel.Closet City
checkbox.Latitude
and Longitude
coordinates.
You can configure other Indigo settings by opening the preferences dialog (selecting the Indigo 6→Preferences…
tab.
You can have Indigo check for updates immediately by selecting the Indigo 6→Check for Updates…
menu item.
System Preferences
from the Apple
menu.Energy Saver
icon.Computer sleep:
slider to Never
checkbox.
Indigo Pro ships with quite a few very useful plugins. We install these plugins disabled so you'll only need to enable the ones you want to use. There are two ways to enable/disable a plugin: select the Enable
(or Disable
as the case may be) menu item under the plugin's submenu on the Plugins
menu. The other is to select the Plugins→Manage Plugins…
menu item which will open the Indigo Preferences window to the Plugins tab. Installing 3rd party plugins is a very simple process as well.
