is generally considered to be Python (or in the various example sections, AppleScript) code and represents the exact code needed. You'll also see code blocks like this:
You should be able to tell from the context if it's Python code or, sometimes, AppleScript, if we're comparing how to do something.
NOTE: Indigo uses Python v2.5. Python 2.6 is the default installation on Snow Leopard and 2.7 is the default installation on Lion (2.5 is default on Leopard), and there are differences, so make sure that you're using Python 2.5 for your development or you could get a nasty surprise when you turn your code into a plugin (if you're developing code outside of the plugin architecture). Both Lion and Snow Leopard do have 2.5 installed, it's just not the default install. It's in this directory:
If you execute “python2.5” at the command line instead of “python” you'll get the installed 2.5 version.
Term | Meaning |
From an architectural perspective, the most fundamental design point that needs to be understood is that the host process that executes python scripts is a separate process from the IndigoServer process - which where the objects actually reside. We do this so that a single script or plugin can't bring down the entire IndigoServer.
For Scripters and Developers:
myObject.replaceOnServer()
myObject.refreshFromServer()
method.For Developers:
A couple of notes to help you understand these rules. First, the IOM allows Server Plugins to attach arbitrary attributes to any object. We call these plugin properties, or just props. Currently, those properties are only available through Python (they aren't exposed in the UI and they aren't exposed in AppleScript). They are only read-write for Server Plugin, but are readonly for all Python scripts.
Devices | ||
RelayDevice (indigo.RelayDevice) | indigo.relay.* | manipulate a relay device |
SpeedControlDevice (indigo. SpeedControlDevice) | indigo.speedcontrol.* | manipulate a speed control/motor device |
Schedule | ||
Schedule (indigo.Schedule) | indigo.schedule.* | manipulate a scheduled event not yet implemented |
Triggers | ||
VariableChangeETrigger (indigo.VariableChangeETrigger) | indigo.varValueChange.* | manipulate a variable changed trigger |
Action Groups | ||
Variables | ||
General Commands | ||
and delete()
. Every top-level object in Indigo (action group, device, folder, schedule, trigger, variable) now has a globally unique integer ID associated with it. For those who never used AppleScript with the IndigoServer, the only way to reference an object in AppleScript is via the object’s name. This presents a problem: what if the name you stored in your script changes?
is visible in the various lists throughout the UI. You can also select any object in the GUI and right click it to get it’s contextual menu where you'll find a new Copy ID (123)
If you are a user of the Indigo AppleScript Dictionary, you may have certain expectations set about how you would use the IOM in Python. While there are similarities, there are also some non-trivial differences. Most of these will become apparent in the following sections, but we’d like to outline a few here.
First, and most obvious, is the nature of most objects in the IOM as we discussed earlier - using copies and updating the server when you change the properties. In AppleScript, when you alter an object’s property the change in instantaneous since the script is running in the IndigoServer process. That significant architectural difference is what led us to the split between objects and the commands that work on them.
The next difference that you’ll notice is that there are many more classes in the IOM than there are in AppleScript. That’s because in AppleScript the classes are very flat: a device contains all possible properties for all devices. The same applies to the action step
(Action
in the IOM) class: in AppleScript it contains all possible properties for every action type. In the IOM, we broke these out into an object hierarchy in which a base class is defined that contains the common properties, then subclasses add the specifics for each type. Check out the figure in the next section for a graphical depiction of the object hierarchies in the IOM.
item 1 of myArray
myArray[0]
and indigo.List()
and list
The behavior of indigo.Dict
and indigo.List
Object | Description |
Each of the objects above corresponds to one of the high-level objects in Indigo. In the UI, you know that you can create folders for each of those object types. To access the folders available for each type, you can reference the “folders” property: i.e. indigo.devices.folders
is a shortcut to get the string name of the item. Normally you would need to get a copy of the object (which would pull the entire object from the IndigoServer) then get the name, but this method is more efficient since it only gets the name from the IndigoServer rather than the whole object. So, an easy way to get a variable folder's name (maybe for logging) would be to do this: indigo.variables.folders.getname(1234)
at plugin start so that you'll always be notified when any device changes - you can then determine if your scene “state” has changed and act accordingly. Note that subscribeToChanges() only reports actual changes to devices - so for instance when a light turns ON you'll get a notification. If the light is commanded to turn ON again, you won't get the notification because the device state didn't change. Use the lower-level subscribeToIncoming()
and subscribeToOutgoing()
methods in the indigo.insteon
and indigo.x10
command spaces to see commands regardless of their effect on device state.
Python | AppleScript |
for dev in indigo.devices: # do stuff with dev here | repeat with dev in every device -- do stuff with dev here end repeat |
Filter | Description |
Triggers also have filters:
Possible Exceptions | |
, MemoryError
, OverflowError
Need more explanation and example of how to handle exceptions here?
# first, let's get an indigo.DimmerDevice like a LampLinc >>> dev = indigo.devices[238621905] >>> dev.__class__ <class 'indigo.DimmerDevice'> >>> hasattr(dev,'onState') True >>> dir(dev) ['__class__', '__delattr__', '__dict__', '__doc__', '__getattribute__', '__hash__', '__init__', '__module__', '__new__', '__reduce__', '__reduce_ex__', '__repr__', '__setattr__', '__str__', '__weakref__', 'address', 'brightness', 'buttonGroupCount', 'description', 'deviceTypeId', 'enabled', 'folderId', 'globalProps', 'id', 'lastChanged', 'model', 'name', 'onState', 'pluginId', 'pluginProps', 'protocol', 'refreshFromServer', 'remoteDisplay', 'replaceOnServer', 'replacePluginPropsOnServer', 'states', 'supportsAllLightsOnOff', 'supportsAllOff', 'supportsStatusRequest', 'updateStateOnServer', 'version'] # Next, an indigo.ThermostatDevice >>> thermo = indigo.devices[171495708] >>> thermo.__class__ <class 'indigo.ThermostatDevice'> >>> dir(thermo) ['__class__', '__delattr__', '__dict__', '__doc__', '__getattribute__', '__hash__', '__init__', '__module__', '__new__', '__reduce__', '__reduce_ex__', '__repr__', '__setattr__', '__str__', '__weakref__', 'address', 'buttonGroupCount', 'coolIsOn', 'coolSetpoint', 'description', 'deviceTypeId', 'enabled', 'fanIsOn', 'fanMode', 'folderId', 'globalProps', 'heatIsOn', 'heatSetpoint', 'humidities', 'humiditySensorCount', 'hvacMode', 'id', 'lastChanged', 'model', 'name', 'pluginId', 'pluginProps', 'protocol', 'refreshFromServer', 'remoteDisplay', 'replaceOnServer', 'replacePluginPropsOnServer', 'states', 'supportsAllLightsOnOff', 'supportsAllOff', 'supportsStatusRequest', 'temperatureSensorCount', 'temperatures', 'updateStateOnServer', 'version'] # Here's a plugin defined device >>> tunes = indigo.devices["Whole House iTunes"] # notice that it only shows the Device base class >>> tunes.__class__ <class 'indigo.Device'> >>> dir(tunes) ['__class__', '__delattr__', '__dict__', '__doc__', '__getattribute__', '__hash__', '__init__', '__module__', '__new__', '__reduce__', '__reduce_ex__', '__repr__', '__setattr__', '__str__', '__weakref__', 'address', 'buttonGroupCount', 'description', 'deviceTypeId', 'enabled', 'folderId', 'globalProps', 'id', 'lastChanged', 'model', 'name', 'pluginId', 'pluginProps', 'protocol', 'refreshFromServer', 'remoteDisplay', 'replaceOnServer', 'replacePluginPropsOnServer', 'states', 'supportsAllLightsOnOff', 'supportsAllOff', 'supportsStatusRequest', 'updateStateOnServer', 'version'] # You can use the deviceTypeId property to get the plugin's defined type >>> tunes.deviceTypeId u'mediaserver'
will test an object to see if it has a specific property. The obj.__class__
property will show you what class the object is. As you explore IOM objects, these methods will help you figure out how to use IOM objects effectively.
