  2. Unplug the PowerLinc 2413S from the wall outlet.
  3. Hold down the SET button on the device for 20 seconds.
  4. While still holding the SET button plug it back into the wall and keep holding the SET button for 20 additional seconds, then release.
  5. Install the USB to serial adapter driver, plug the adapter into the 2413S and your Mac, then select the correct Serial Port in the interface settings for the device.
indigo_6_documentation/powerlinc2413s.txt · Last modified: 2019/01/26 00:10 (external edit)
