Deletion Dependencies
If you double-click on the dependency, the edit dialog for that object will open so you can change/remove it. If you want the dependent objects to be deleted, just click the Delete button.
indigo_7_documentation/deletion_dependencies.txt · Last modified: 2019/01/26 00:10 (external edit)
