Indigo 7 Documentation
Welcome to the Indigo 7 Documentation pages. We've separated the docs into three areas, each focusing on some different part of Indigo 7.
Indigo User Documents
Concept Overview - What are Devices, Triggers, Schedules, Action Groups, Control Pages, and Variables?
If you have Z-Wave® devices, read through the
Managing Your Z-Wave Network document. Also, our
Z-Wave wiki article discusses, in general terms, what Z-Wave is and how it works.
If you have INSTEON devices, read through the
Managing Your INSTEON Network document. For some background on INSTEON links, we have put together a separate page that discusses
INSTEON Scenes. We highly recommend that you read through that page as it will give you a better understanding of what links are and how they work.
The
Virtual Devices Interface provides several different devices that help you integrate Z-Wave, INSTEON, and 3rd party devices together and even create your own devices.
Other Help Pages
There are other help documents available below and from the purple question mark icon in the UI for the less frequently used dialogs in Indigo.
The
Event Log Window - this is where you can see a history of what Indigo is doing (among other things)
Indigo Plugin Documents
Airfoil Pro - allows users to fully control Airfoil 5 and later to direct audio output.
Growl - adds the ability to alert you of special events via the Growl library. Growl 2.1, 2.2, and 3.0 are supported.
iCal Alarm Processor - a plugin that will monitor an
IMAP email account for iCal alarm email messages and do some post-processing for you.
iTunes - makes iTunes information available for use in Indigo and allows you to control iTunes.
NOAA Weather - makes weather data from the National Oceanic and Atmospheric Administration available for use in Indigo.
SQL Logger - a replacement for the built-in SQL logging functionality of previous versions. More robust and useful.
Timers and Pesters - this plugin provides a more direct mechanism to create simple timer objects. It also provides a flexible reminder/notification mechanism called a pester.
Deprecated Plugins
With Indigo 7, we no longer ship the following plugins.
Airfoil - this plugin was replaced by the Airfoil Pro plugin listed above, so you'll need to create Airfoil devices and update your old Airfoil actions to use the new plugin. If you need to use the old plugin, you can get it on our
Github repo.
DIRECTV DVR Control - this plugin, which allows Indigo to control some DIRECTV set-top boxes, is now in our
Github repo to allow community improvements.
Vera Bridge - this plugin, which integrates with the Vera controller, is no longer needed since Indigo now supports Z-Wave locks directly. It is still available in our
Github repo.
WeatherSnoop - the WeatherSnoop development team has taken over management of this plugin. Indigo 7.1.2 is the last version that will install the plugin automatically. Beginning with 7.2.0, you'll need to get the plugin from the
Plugin Store.
Indigo How-To Wiki
Technical Documents
We provide several powerful yet easy to use ways to extend Indigo. We support a Python-based API that allows 3rd parties to integrate devices, events, and actions natively into Indigo without sacrificing speed and stability of the core server. We also support a legacy AppleScript API (which will be deprecated in Indigo 7.3 and later) that allows you to integrate with other Mac applications. This section provides links to all the documentation needed to develop scripts and plugins for Indigo.
The Indigo Plugin
SDK (
available here) includes example plugins with full
XML and python source. They are a great place to start when developing new plugins.
RESTful API - an API that can be easily used from any other device/application to get data to/from Indigo.
Indigo AppleScript Dictionary - this is a text version of the AppleScript dictionary found in Script Editor.
Warning: AppleScripts that target the Indigo Server using this dictionary will stop working in Indigo v7.3.0 and above.
