menu item. See connecting the Interface in the Getting Started guide for more details.
Additionally, make sure you have Insteon Repeaters, Access Point RFs, or other dual-band modules correctly installed on opposite power legs. If the Repeaters/Access Point RFs or other dual-band devices are improperly installed or missing, then you may not be able to control some of your Insteon devices. See the instructions included with your Access Point RF pair for installation details.
To add a new Insteon device:
New…
button at the top of the Home window.Here's the INSTEON device dialog:
The Define and Sync…
dialog:
The Re-Sync Links…
dialog:
The primary place that you'll manage links between devices is in the Manage INSTEON Device Links dialog. Select the Interfaces→INSTEON/X10 Power Line→Manage Device Links
menu item.Show links used by device
popup control.If the module you selected is a controller (RemoteLinc, KeypadLinc, SwitchLinc, etc.), then you can add or edit responders:
New Link to Responder
button. If you want to change the settings (brightness, ramp rate duration, etc.) of an existing responder module in the scene, then select that module's link in the table with the Link to Responder Device
column title.broadcast of button/group number
popup control.cool
and heat
setpoint temperatures.Persistent
checkbox to force this link to automatically be restored whenever either the responder module or controller module is synced. If the modules are ever reset, replaced, or have this link modified, then Indigo will automatically rewrite the original link on the next sync operation.If the module you selected is a responder (LampLinc, Thermostat Adapter, KeypadLinc, SwitchLinc, etc.), then you can add or edit controllers:
New Link to Controller
button. If you want to change the settings (brightness, ramp rate duration, etc.) used by the selected module in a controller's scene, then select the controller module's link in the table with the Link to Controller Device
popup control.cool
and heat
setpoint temperatures via those text boxes.Persistent
button to close the link editor window and write the changes to the modules at a later time. When you are ready to write the changes to the remote modules, select Start Sync Device Links…
button.
action.
Manage PowerLinc Links…
menu.PowerLinc Group/Scene
number to use for the scene. Use 1 if this is your first scene.PowerLinc Group/Scene
name in the edit field (ex: “reading in bed”).Next, create a new link for every responder module in the scene:
button. If you want to change the settings (brightness, ramp rate duration, etc.) of an existing responder module in the scene, then select that module's link in the table in the top-half of the window.responder
popup control.cool
and heat
setpoint temperatures using the text boxes.Persistent
checkbox to force this link to automatically be restored whenever the responder module is synced. If the responder module is ever reset, replaced, or has this link modified, then Indigo will automatically rewrite the original link into the device when it is next synced.
button.
Actions
tab inside the edit window.INSTEON Actions→Execute INSTEON Scene
from the action Type
popup item.Send
will turn off all of the modules immediately, ignoring any ramp rate duration.Scene
popup item.
menu itemInterfaces→Insteon/X10 Power Line→Enable
menu itemInterfaces→Insteon/X10 Power Line→Configure…
menu itemInterface Options…
buttonSync Links
buttonThe last step will take a while, so watch the Event Log window for progress.
submenu contains a collection of miscellaneous INSTEON commands that will help you manage specific aspects of devices as well as do so low-level INSTEON commands not directly supported in the UI. Note that these are also actions available in the Insteon Brand Specific submenu.
, Turn Off
, Leave Alone
