menu item. See connecting the Interface in the Getting Started guide for more details.
TIP: You may also need to bridge the two phases of your power line to get reliable communication. Search for “X10 signal bridge” in your favorite search engine for details.
To add an X10 device, select DEVICES
in the outline view (or one of it's sub-folders) and click the New…
button. Select X10
from the Type:
popup and you'll see the following:
However, you may have a device module not currently listed in the Type popup menu. To use devices that are not defined in the device Type popup, you can click the Definition…
button you will be shown the Module Definition
dialog:
