Airfoil Pro
Note: this plugin requires v1.5 or later of the Airfoil API. This was delivered in Airfoil 5 for Mac and Windows. If you need support for earlier versions of Airfoil for Mac, please see the legacy Airfoil plugin that we open-sourced. Note, however, that it may not work with Indigo 7.
Airfoil Device Types
Airfoil Instance
Adding an Instance
  • mechineIconAndScreenshot.png - a screenshot from the host computer with the machine icon overlayed (though this functionality seems to be missing in Airfoil versions through v5.1.0 - you just get the same image as the machine icon)
States available to Scripts
Notes
Speaker
volume number If the source is iTunes and you've selected an iTunes server as the source in this device's config, this will mirror that device's playState
Airfoil Actions
If you examine the example scripts below, you'll note that each action call will return a result (which is new in Indigo 7). Unless otherwise specified, it's just a boolean indicating if the action correctly ran.
Speaker Actions
Connect Speaker
Scripting details
Action id: connect
airfoilPlugin = indigo.server.getPlugin("com.perceptiveautomation.indigoplugin.airfoilpro")
if airfoilPlugin.isEnabled():
        result = airfoilPlugin.executeAction("connect", deviceId=135305663, waitUntilDone=True)  # ID of Speaker device
    except Exception, e:
        print "Exception occurred: %s" % unicode(e)
Disconnect Speaker
Scripting details
Action id: disconnect
        result = airfoilPlugin.executeAction("disconnect", deviceId=135305663, waitUntilDone=True)  # ID of Speaker device
Toggle Speaker
Scripting details
Action id: toggle
        result = airfoilPlugin.executeAction("toggle", deviceId=135305663, waitUntilDone=True)  # ID of Speaker device
Save Current Speaker States
Scripting details
Example 1 (no groups):
        result = airfoilPlugin.executeAction("saveCurrentSpeakerStates", deviceId=135305663, waitUntilDone=True)  # ID of Airfoil device
Example 2 (include groups):
        result = airfoilPlugin.executeAction("saveCurrentSpeakerStates", deviceId=135305663, props={"includeAirfoilGroups": True}, waitUntilDone=True)
Restore Saved Speaker States
Scripting details
        result = airfoilPlugin.executeAction("restoreSavedSpeakerStates", deviceId=135305663, waitUntilDone=True)  # ID of Airfoil device
Set Volume
Scripting details
Action id: setVolume
        result = airfoilPlugin.executeAction('setVolume', deviceId=135305663, props={'volume': 50}, waitUntilDone=True)  # ID of Speaker device
Increase Volume
Scripting details
Action id: increaseVolume
        result = airfoilPlugin.executeAction('increaseVolume', deviceId=135305663, waitUntilDone=True)  # ID of Speaker device
Example 2 (specifying delta):
        result = airfoilPlugin.executeAction('increaseVolume', deviceId=135305663, props={'volume': 15}, waitUntilDone=True)  # ID of Speaker device
Decrease Volume
Scripting details
Action id: decreaseVolume
        result = airfoilPlugin.executeAction('decreaseVolume', deviceId=135305663, props={'volume': 15}, waitUntilDone=True)  # ID of Speaker device
Airfoil Instance Actions
Disconnect All Speakers
Scripting details
        result = airfoilPlugin.executeAction('disconnectAllSpeakers', deviceId=12345678, waitUntilDone=True)  # ID of Airfoil device
Change Source
Scripting details
Action id: changeSource
        props = {"sourceGroup": "systemAudio", "source": "com.rogueamoeba.source.systemaudio"}
        result = airfoilPlugin.executeAction("changeSource", deviceId=1346588091, props=props, waitUntilDone=True)
Save Current Source
Scripting details
Action id: saveCurrentSource
        result = airfoilPlugin.executeAction("saveCurrentSource", deviceId=1346588091, waitUntilDone=True)
Restore Saved Source
Scripting details
Action id: restoreSavedSource
        result = airfoilPlugin.executeAction("restoreSavedSource", deviceId=1346588091, waitUntilDone=True)
Toggle Play/Pause
Scripting details
Action id: playPause
        result = airfoilPlugin.executeAction('playPause', deviceId=12345678, waitUntilDone=True)
Next Track
Scripting details
Action id: nextTrack
        result = airfoilPlugin.executeAction('nextTrack', deviceId=12345678, waitUntilDone=True)
Previous Track
Scripting details
Action id: prevTrack
        result = airfoilPlugin.executeAction('prevTrack', deviceId=12345678, waitUntilDone=True)
Airfoil Scripting Actions
getSources
Action id: getSources
        result = airfoilPlugin.executeAction('showSources', deviceId=12345678)  # deviceId is the Indigo ID of the Airfoil device
     audioDevices : (list)
          Item : (dict)
               icon : [SNIP]
          Item : (dict)
               icon : [SNIP]
          Item : (dict)
               icon : [SNIP]
     recentApplications : (list)
          Item : (dict)
               icon : [SNIP]
          Item : (dict)
               icon : [SNIP]
    systemAudio : (list)
    	  Item : (dict)
    	  	   icon : [SNIP]
indigo_7_documentation/plugins/airfoilpro.txt · Last modified: 2017/01/17 17:14 by jay
