EasyDAQ Relay Card Plugin
Cards Supported
  • USB24MxS (24 relays)
  • USBDIO24 (24 DIO channels)
Adding Cards to Indigo
Controlling Relay and Digital Outputs
Some actions have additional options available via the Edit… button. For example, the Change Multiple Outputs action allows you to control (turn on, turn off, or toggle) all of the outputs with a single, and very fast, action:
Triggering Actions on a Digital Input Change
Preventing Floating Input Problems
Scripting Support
Action specific properties
Turn On Output
Action id: turnOnOutput
Properties for scripting:
if easyDaqPlugin.isEnabled():
Turn Off Output
Action id: turnOffOutput
Toggle Output
Action id: toggleOutput
All Outputs On
Action id: allOutputsOn
All Outputs Off
Action id: allOutputsOff
Action id: changeMultiple
Support and Troubleshooting
indigo_7_documentation/plugins/easydaq_1.txt · Last modified: 2019/01/26 00:10 (external edit)
