The old iTunes AppleScripts are included by the installer for backwards compatibility.
The iTunes Plugin allows you to create iTunes Server devices. To create a new one, switch to the device view and click the New…
button. This will bring up the device edit dialog:
As shown above, select Plugin
from the Type:
popup. Select iTunes Plugin
from the Plugin:
popup, and select iTunes Server
from the Model:
button and you'll see the iTunes Device Config UI:
This dialog tells you what to do next. You must pair this new device with the iTunes Server that you intend to control. Switch to iTunes - if you're using iTunes 11, you'll see a button titled Remote
in the upper right corner next to the iTunes Store
button:
Select Indigo Remote Control
Enter 0 0 0 0 for the passcode (or anything actually) - you'll see a message that says “Your Remote is now able to control iTunes” and an OK
button. Click OK
, then switch back to Indigo and click the Save
button. That should save your device and you should start seeing state updates.
If you use the Pause Playback and Speak Text action and iTunes is running on a remote Mac and/or you are using Airfoil to direct sound to other devices, you may notice that the speaking and iTunes music overlap somewhat. That's what the other setting in the device config UI above is for (# of seconds of latency
) - just increase that incrementally until the spoken text no longer overlaps the iTunes music. You may not need any latency adjustment.
Player Status Changed
- any change to the play state of iTunesPlayer Status is Playing
- iTunes is playingPlayer Status is Paused
- iTunes is pausedPlayer Status is Stopped
- iTunes is stoppedPlayer Status is Unavailable
- iTunes is unavailable - it's probably not runningPlayer Status is Error
- this iTunes device has an unknown error - look in the Event Log for detailsCurrent Playlist Name
- the current playlist that's selected in iTunesCurrent Album
- the current album nameCurrent Artist
- the current artist nameCurrent Track
- the current track nameCurrent Volume
- the current volume levelRepeating Changed
- any change in repeat statusRepeating None
- iTunes is not repeatingRepeating Song
- iTunes is repeating the current songRepeating Playlist
- iTunes is repeating the current playlistShuffling
- iTunes is shuffling songsThe actions provided by the plugin are as follows:
Play
- start iTunes playingPause
- pause iTunesToggle Play/Pause
- toggle between playing and pausedNext Track
- move to the next trackPrevious Track
- go back to the previous trackRestart Track
- restart the current trackPause iTunes and Say
- pause iTunes (if it's running) and speak the supplied text. Restart only if it was paused to begin with.Set Volume
- set the volume to a specific level (0-100)Increase Volume
- increase the volume by a specific amount (0-100)Decrease Volume
- decrease the volume by a specific amount (0-100)Set Repeat
- set iTunes to repeat (or not)Set Shuffle
- set/unset shufflingNOTE: you can use the special variable substitution fields in the Pause iTunes and Say text field - see Variable Substitution for more information.
Action id: play
itunesPlugin = indigo.server.getPlugin("com.perceptiveautomation.indigoplugin.itunes") if itunesPlugin.isEnabled(): itunesPlugin.executeAction("play", deviceId=135305663)
Action id: pause
itunesPlugin = indigo.server.getPlugin("com.perceptiveautomation.indigoplugin.itunes") if itunesPlugin.isEnabled(): itunesPlugin.executeAction("pause", deviceId=135305663)
Action id: playPause
itunesPlugin = indigo.server.getPlugin("com.perceptiveautomation.indigoplugin.itunes") if itunesPlugin.isEnabled(): itunesPlugin.executeAction("playPause", deviceId=135305663)
Action id: nextTrack
itunesPlugin = indigo.server.getPlugin("com.perceptiveautomation.indigoplugin.itunes") if itunesPlugin.isEnabled(): itunesPlugin.executeAction("nextTrack", deviceId=135305663)
Action id: prevTrack
itunesPlugin = indigo.server.getPlugin("com.perceptiveautomation.indigoplugin.itunes") if itunesPlugin.isEnabled(): itunesPlugin.executeAction("prevTrack", deviceId=135305663)
Action id: restartTrack
itunesPlugin = indigo.server.getPlugin("com.perceptiveautomation.indigoplugin.itunes") if itunesPlugin.isEnabled(): itunesPlugin.executeAction("restartTrack", deviceId=135305663)
Action id: pauseAndSay
Properties for scripting:
itunesId = "com.perceptiveautomation.indigoplugin.itunes" itunesPlugin = indigo.server.getPlugin(itunesId) if itunesPlugin.isEnabled(): myWeatherStation = indigo.devices[1798384204] outsideTemp = myWeatherStation.states['temperatureF'] currentCondition = myWeatherStation.states['currentCondition'] spokenString = "The current temperature is %s degrees. Current condition is %s." % (outsideTemp, currentCondition) itunesPlugin.executeAction("pauseAndSay", deviceId=135305663, props={'message':spokenString}) itunesPlugin.executeAction("pauseAndSay", deviceId=135305663, props={'speakLastMessage':True})
Action id: setVolume
itunesPlugin = indigo.server.getPlugin("com.perceptiveautomation.indigoplugin.itunes") if itunesPlugin.isEnabled(): itunesPlugin.executeAction("setVolume", deviceId=135305663, props={'volume':50})
Action id: increaseVolume
itunesPlugin = indigo.server.getPlugin("com.perceptiveautomation.indigoplugin.itunes") if itunesPlugin.isEnabled(): itunesPlugin.executeAction("increaseVolume", deviceId=135305663, props={'volume':25})
Action id: decreaseVolume
itunesPlugin = indigo.server.getPlugin("com.perceptiveautomation.indigoplugin.itunes") if itunesPlugin.isEnabled(): itunesPlugin.executeAction("decreaseVolume", deviceId=135305663, props={'volume':25})
Action id: setRepeat
itunesPlugin = indigo.server.getPlugin("com.perceptiveautomation.indigoplugin.itunes") if itunesPlugin.isEnabled(): itunesPlugin.executeAction("setRepeat", deviceId=135305663, props={'repeat':0})
Action id: setShuffle
itunesPlugin = indigo.server.getPlugin("com.perceptiveautomation.indigoplugin.itunes") if itunesPlugin.isEnabled(): itunesPlugin.executeAction("setShuffle", deviceId=135305663, props={'shuffle':True})
