Triggers
Trigger Base Class
globalProps dictionary No an indigo.Dict() representing all name/value pairs associated with this trigger - each plugin will have it's own dictionary (globalProps[pluginId]) - see About Plugin Properties below for details
id integer No a unique id of the trigger, assigned on creation by IndigoServer - not available in AppleScript
Triggers have properties - some are class properties, defined by the class itself. One of the biggest requests we've gotten in the past is some way to add arbitrary properties to an object - so that you could store your own data with the object in the database. And with plugin defined triggers, we needed a place to store the properties that you need to operate the trigger. That's what the pluginProps and globalProps represent - the additional properties that are not defined by the class. globalProps is a dictionary of every additional property defined for the trigger - each plugin has it's own dictionary of props in here which are readable by anyone. pluginProps is a shortcut to get to your plugin's props and are only writable by your plugin.
trigger=indigo.triggers[123]
Commands (indigo.trigger.*)
indigo.trigger.delete(123)
Enable/Disable Trigger
duration No integer number of seconds before the trigger is switched back to it’s original state
Execute Trigger
DeviceStateChangeTrigger
In AppleScript (which will be deprecated in Indigo 7.2 and later), we didn’t describe them particularly well, but basically we use a 1-based index into an array of possible values. So, for an I/O device, for instance, you’d refer to “binaryInput1”, “binaryInput2”, etc. Or for a sprinkler with multiple zones, it would be “zone1”, “zone2”, etc. In the Python API, we’ve made it easier when referencing these events with the introduction of the stateSelectorIndex. It’s the index into list of available “things” represented by the device’s state.
State Change Type Enumeration
indigo.kStateChange
AnalogInput
BrightnessLevel
HumidityInput
SensorInput
SetpointCool
SetpointHeat
TemperatureInput
BinaryOutput
HvacCoolerIsOn
HvacFanIsOn
HvacFanModeIsAlwaysOn
HvacFanModeIsAuto
HvacHeaterIsOn
HvacOperationModeIsAuto
HvacOperationModeIsCool
HvacOperationModeIsHeat
HvacOperationModeIsOff
OnOffState
Zone
BrightnessLevel
HumidityInput
SensorInput
SetpointCool
SetpointHeat
TemperatureInput
BrightnessLevel
HumidityInput
SensorInput
SetpointCool
SetpointHeat
TemperatureInput
AnalogInput
BrightnessLevel
HumidityInput
SensorInput
SetpointCool
SetpointHeat
TemperatureInput
BinaryOutput
HvacCoolerIsOn
HvacFanIsOn
HvacFanModeIsAuto
HvacHeaterIsOn
OnOffState
Zone
AnalogInput
AnalogInputsAll
BinaryInput
BinaryInputsAll
BinaryOutput
BinaryOutputsAll
BrightnessLevel
HumidityInput
HumidityInputsAll
HvacCoolerIsOn
HvacFanIsOn
HvacFanMode
HvacFanModeIsAuto
HvacHeaterIsOn
OnOffState
SensorInput
SensorInputsAll
SetpointCool
SetpointHeat
TemperatureInput
TemperatureInputsAll
Zone
State Selector Enumeration
indigo.kStateSelector
Value Description
BinaryOutputsAll
HumidityInputmonitor (one of) the humdity sensor(s) available on the device for =, !=, <, >, and any change - stateSelectorIndex is required to be in the range of available inputs
KeypadButtonLedFIXME
    folder=1234)
Python AppleScript (which will be deprecated in Indigo 7.2 and later)
theTrigger.deviceId = 738
theTrigger.stateValue = 80
theTrigger.replaceOnServer()
set theTrigger to make new trigger action with properties {name:"Temp exceeds 80 degrees"}
set theTrigger's trigger type to deviceChanged
set theTrigger's device name to "Main Thermostat"
set theTrigger's state change type to becomesGreaterThan
set theTrigger's state selector to "TemperatureInput1"
set theTrigger's state value to 80
EmailReceivedTrigger
Email Filter Enumeration
indigo.kEmailFilter
Value Description
Commands (indigo.emailRcvd.*)
    folder=1234)
set theTrigger to make new trigger action with properties {name:"Emails from some@body.com"}
set theTrigger's trigger type to emailReceived
set theTrigger's email filter to matchEmailFields
set theTrigger's email from to "some@body.com"
InsteonCommandReceivedTrigger
INSTEON Command Enumeration
indigo.kInsteonCmd
Value Description
Dimwhen a dim command begins
indigo.kDeviceSourceType
Value Description
    folder=1234)
Python AppleScript
theTrigger.buttonOrGroup = 1
(Can't be created in AppleScript)
InterfaceFailureTrigger
    folder=1234)
set theTrigger to make new trigger action with properties ¬
    {name:"Any Interface Failed", trigger type:interfaceFailure}
InterfaceInitializedTrigger
    folder=1234)
    {name:"Any Interface Initialized", trigger type:interfaceInitialized}
PluginEventTrigger
    folder=1234),
    pluginTypeId="myEvent",
PowerFailureTrigger
    folder=1234)
    {name:"Any Interface Detected Power Failure", trigger type:powerFailure}
ServerStartupTrigger
    folder=1234)
    {name:"Startup", trigger type:startup}
X10CommandReceivedTrigger
X10 Command Enumeration
indigo.kX10Cmd
Value Description
X10 A/V Button Enumeration
indigo.kX10AvButton
Value Value
0 Left
1 Menu
2 Mute
3 Pause
4 PC
5 Play
6 Power
7 Recall
8 Record
9 Return
AB Rewind
ChannelDown Right
ChannelUp Stop
Display Title
Down Up
Enter VolumeDown
Exit VolumeUp
Forward
    folder=1234)
myTrigger.address = "F7"
myTrigger.replaceOnServer()
VariableValueChangeTrigger
indigo.kVarChange
Value Description
    folder=1234)
set theTrigger to make new trigger action with properties {name:"Var Changed to True"}
set theTrigger's trigger type to variableChanged
set theTrigger's variable change type to varBecomesEqual
set theTrigger's variable name to "SomeVarWhoseIdIs9283749872"
set theTrigger's variable value to "True"
indigo_7_documentation/trigger_class.txt · Last modified: 2022/04/30 22:35 by mattb
