When you double click on the Indigo 7
icon in the Applications
folder, you're actually starting the Indigo Mac Client, which will start up the Indigo Server process according to the options selected in the Start Server dialog.
The Home Window is in 4 areas:
To create a new folder, select the main object type in the list then click the plus (+
) button at the lower-left corner of the outline view. A new folder will appear and you can just start typing it's new name. To delete a folder, select it, then click on the gear icon or right-click the folder (bring up the contextual menu). The resulting menu will allow you to select Delete Folder
then delete it. If the folder isn't empty, it will show you a sheet with 3 options: Cancel
(do nothing), Delete Items
(delete the items in the folder along with the folder), or Move Items
(move the items to the parent first then delete the folder).
From the same menu, you can select Rename Folder…
to rename it, Enable/Disable Remote Display (for devices, action groups, and control pages) to show/hide it in remote clients (like Indigo Web Server (IWS) pages or Indigo Touch), or copy the unique folder ID for use in Python scripts.
The buttons above the table view perform actions on items in the list - the buttons will work on whatever list is displayed in the Item List. So, if you have DEVICES (or a device folder) selected in the Outline View, the item list will show devices and the buttons will operate on that list - New…
device, Edit…
the selected device, Duplicate
the selected device, or Delete
the selected device(s). The search bar will filter the list.
This menu will:
indigo.devices[91776575] # “Living Room Switch”
device named “Living Room Switch”
trigger action named “Motion Sensor Dawn Triggered”
action group named “Toggle Variable”
The information in the tile will be specific to the device type. For instance, battery powered devices (that report their battery status) will show the battery level. For sensor devices, the sensor reading will show (temp, humidity, etc. for instance). All devices, regardless of type, will show Last Update
- the last date/time that the device was changed in any way.
Plugin devices, regardless of whether they implement one of the built-in device types below or if they are completely custom devices, will also have a Custom States
tile that will show all of the device's custom states. This tile is always below the first row of tiles so you may need to scroll or resize the Item Detail area to see it:
For lights (dimmers) and appliance modules (relays or On/Off devices), you see On/Off/Brightness Controls
tile:
If the device doesn't support dimming, those controls will be hidden. You'll also notice that in the Device Details tile, On State
and Brightness
(if it's a dimmer) will show the current values.
Also, some energy monitoring devices, such as the iMeter, keep running totals of energy usage that can be reset by the user. For those, a Reset
button will be placed next to the Total Usage in the Device Details
tile.
Output Controls tile shows the state of all the output states available for the device and you can update them immediately using the Send Status Request
button. The button grid shows all available outputs and their status. Use the Turn Off All Outputs
button to turn off all binary outputs.
Enabled and Upload
- this means that it will be processed both while Indigo Server is running and it will be uploaded to your standalone controller (if it supports uploading).Enable
- this means that it will be processed while Indigo Server is running, and mirrors the Enabled column in the list if it's visible.Upload
- this means that it will only be uploaded and executed by your standalone controller (if it supports uploading) - while Indigo Server is controlling the logic it will not be enabledDisabled
- this means that it's completely disabled - it also mirrors the Enabled column in the list if it's available.
The Execute Actions Now
button will do exactly that - execute all the actions associated with the object. NOTE: just as the triggering event will be ignored, so will any conditions associated with the object.
The action group detail shows a list of all the actions in the group. The Execute Actions Now
button will do exactly that - execute all the actions associated with the action group.
The only thing in the detail area for a control page is the Show in Browser
button, which will open the selected page in the default browser.
Click the Clear Window
button to clear the log entries. Click on Show Event Logs Folder
to open the Logs folder in the Finder. Here you will find one file for each day's events. You can change how many day's worth of event log files are stored by selecting Indigo 7→Preferences…
and then selecting the General
tab. There, you can enter the number of days of event log files that you want to keep. Indigo Server will delete all files outside of that period of time.
About Indigo 7
- this will show the About window which will show what client and server versions you're running and will show your registration codeStart Local Server…
- this will open the Start Server dialogStop Server
- this will stop the Indigo ServerConnect to Remote Server…
- this option will allow you to connect to a different Indigo server or a server running on another MacClose Connection
- this will close the connection to the serverPreferences…
- this opens the preferences dialogLicense Details…
- this opens the Subscription Status window that will show you the status of your License and it's associated Up-to-Date Subscription:
Check for Updates…
- this will have the server your connected to contact us to see if there is an update availableNew Database…
- this will close the current database and create a new one - you'll be prompted for a name and save locationSelect Database…
- this will allow you to switch to a different databaseClose Window
- this will close the frontmost windowNew Device…
- this will switch the Home Window to the devices view and open the new device dialogNew Trigger…
- this will switch the Home Window to the triggers view and open the new trigger dialogNew Schedule…
- this will switch the Home Window to the schedules view and open the new schedule dialogNew Action Group…
- this will switch the Home Window to the action groups view and open the new action group dialogThe Edit menu has the standard options on it that you would expect any Mac app to have. Note that the Delete and Duplicate options are available for most items in the user interface.
Browser Devices Page
- this will open your default web browser to the built-in devices listBrowser Actions Page
- this will open your default web browser to the built-in actions listBrowser Variables Page
- this will open your default web browser to the built-in variable listBrowser Control Pages
- this will open your default web browser to the control page list (this option is only available in Indigo Pro)Event Logs Folder
- this will open the Event Logs folder in the FinderPurchase Hardware
- this will open your default web browser to our online store (the Indigo Store) – if you are running a trial copy this item will be called “Purchase Indigo” and will take you to the Indigo purchase pageOnline Support Forum
- this will open your default web browser to our online support forums
The Go
menu may have some other options in it as well - if you're using a trial or Indigo Lite it will give you the option to enter new codes and to purchase a license.
The Z-Wave interface menu has several options:
Enable/Disable
- toggles the interface on and offReload
- will cause the interface to restartConfigure…
- opens the configuration preferences for the Z-Wave interfaceHelp with Z-Wave networks…
- opens a browser window to the help page for managing your Z-Wave Network.Manage Associations…
- opens the dialog where you can manage device associations and scenesRemove Failed Modules from Controller…
- use this menu item remove any Z-Wave nodes that may no longer exist on the network.Reset Z-Wave Interface…
- use this menu to completely reset your Z-Wave interface. You should only do this if Indigo support instructs you to.Enable/Disable
- toggles the interface on and offConfigure…
- opens the configuration preferences for this interfaceUpload Settings…
- opens the upload dialogManage PowerLinc Links…
- opens the PowerLinc link editor windowManage Device Links…
- opens the device link editor windowStart Sync Device Links…
- starts any pending link sync operationsStop Sync Device Links
- stops any ongoing linking operationsFor Indigo Pro users, there are some other menu items added to this menu. Those are described in the Managing Your INSTEON Network in Indigo document.
Enable/Disable
- opens the configuration preferences for this interfaceHelp with X10 RF Interfaces…
- opens a browser to the documentation for configuring this type of interface.Enable/Disable
- will cause the interface to restartHelp with Virtual Devices…
- opens a browser window to the documentation page for Virtual Devices.Update Device Group Saved States…
- will allow you to update the stored states for each device in the specified Device Group.Toggle Debugging
- toggles debugging information in the Event Log on and off. Used primarily for technical support.
Selecting the Interfaces→Manage Interfaces…
menu item will open the interface preferences dialog.
The Plugins menu (Indigo Pro Only) will adjust based on the what plugins you have installed. These menu items will always be present:
Reload Libraries and Attachments
- this will reload all the attachment AppleScripts that are in the Scripts/Attachments directory of the Indigo system directory (/Library/Application Support/Perceptive Automation/Indigo 7/). It will also reload the various Python library directories (i.e. /Users/usernamehere/Library/Python/2.7/site-packages/) so that if you add Python libraries while the server is running your scripts can immediately access those librariesManage Plugins…
- this item will open the preferences window to the Plugins tabPlugin Store
- opens a browser to the Plugin Store on our website so you can easily find plugins for other devices and additional functionalityOpen Scripting Shell
- this will open a terminal window and start the interactive Python shell with the Indigo module loaded - see the Scripting Tutorial for more information
For information about the plugins, see the About…
menu item for each plugin.
Home Window
- this will show/bring to front the Home WindowEvent Log
- this will show/bring to front the Event Log WindowVariable List
- this will show/bring to the front the Variable List WindowHelp for XXXX
- this will change slightly based on what window is selected and what's selected in that window - but it will open the default browser to the page in the help documentation for that particular itemHow-To Wiki
- this will also change slightly based on what's selected - it will open to the How-To wiki for the selected item (if a device is selected it will go to the wiki for that device, otherwise it will just go to the landing page)Email Log…
- this option will email some of your event log data to the specified email address. Particularly useful for technical supportIndigo 7 Documentation
- this will open your browser to the landing page for all Indigo 7 documentationGetting Started Guide
- this will open your browser to the Getting Started Guide, the place where everyone new to Indigo should startManaging a Z-Wave Network
- opens a browser window to the Managing Your Z-Wave Network document in our Documentation wikiManaging an INSTEON Network
- opens a browser window to the Managing Your INSTEON Network document in our Documentation wikiOnline Support Forum
- this will open your browser to our support forum - it's very active and is the primary place where you should seek help - we answer questions there very quickly and in fact we have many helpful users that can help as wellSupported Built-in Device List
- opens a browser window on our new Supported Devices web application that shows which devices and interfaces have been tested with IndigoUser Contribution Library
- this will open your browser to our file library - where anyone can contribute apps, images, scripts, plugins, etc. that others may find usefulZ-Wave® is a registered trademark of Sigma Designs, Inc. Indigo's support of Z-Wave hardware is neither endorsed nor certified by Sigma Designs.
