Virtual Devices Interface
Indigo 7 provides a Virtual Devices Interface type that provides users with several new device types, each discussed below. If you want to use Virtual Devices, make sure to enable them by selecting the Interfaces→Virtual Devices→Enable menu item.
Device Groups
Sprinkler Group
Virtual On/Off Devices
Execution Models
Automatic State Maintenance
indigo_7_documentation/virtual_devices_interface.txt · Last modified: 2019/01/26 00:10 (external edit)
