Defining an INSTEON device is quite simple:
DEVICES
selected in the outline view (or a sub-folder of DEVICES
), click the New…
button above the device list.Name:
field.Define and Sync…
button.Start
or you can put the device into link mode, and Indigo will usually discover the device address automatically. Entering link mode is device specific, but it usually requires pressing the set button (or, for a switch, the paddle up) for 10 seconds. It would probably be helpful to read the INSTEON links discussion.Start
button, you'll see the progression of green check marks in the window while Indigo links the device with the Powerlinc, figures out the device type, etc. Once the last checkmark appears (beside “Wait several seconds for Indigo to add the Powerlinc's address to the device's internal link database”) you can close the window.That's it, you're done! The device should be available in Indigo with all its options.
