Indigo can remotely create scenes in the computer interface (PowerLinc) that control multiple remote modules. Indigo automatically creates the links to define the scene in both the PowerLinc and most remote modules. This means you do not have to press-and-hold the button on either the PowerLinc or most remote modules. Indigo will do it all remotely for you with a single press of the Sync Now
button.
Once Indigo writes the links defining the scene to the PowerLinc and remote modules, you can execute the scene from any Trigger Action, Time/Date Action, or Action Group using a Send INSTEON Group / Scene Command
action. In this respect, the PowerLinc is acting as a Controller with 250 buttons, and Indigo is actually performing the equivalent of pressing the PowerLinc's buttons.
This How-to level of difficulty is Moderate.
Manage PowerLinc Links…
from the Interface menu.PowerLinc Group/Scene
number to use for the scene. Use 1 if this is your first scene.PowerLinc Group/Scene
name in the edit field (ex: “reading in bed”).
New Link to Responder
button. Or, if you want to change the settings (brightness, ramp rate duration, etc.) of an existing responder module in the scene, then select that module's link in the table in the top-half of the window.responder
popup control.cool
and heat
setpoint temperatures.Persistent
checkbox to force this link to automatically be restored whenever the responder module is synced. If the responder module is ever reset, replaced, or has this link modified, then Indigo will automatically rewrite the original link into the device when it is next synced.
Last, have Indigo write all of your link changes to both the PowerLinc and the remote modules:
Sync Now
button to have Indigo immediately write all changed links to the PowerLinc and remote modules.OR
Close (Sync Later)
from the Interface
button.
You can test the scene after the links are written by using the Send On
and Send Off
buttons.
The Indigo scene can now be executed from any Trigger Action, Time/Date Action, or Action Group:
Actions
panel inside the edit window.Send INSTEON Group / Scene Command
from the action Type
popup item.Send
will turn off all of the modules immediately, ignoring any ramp rate duration.Group/Scene
popup item.
Note you can press the Add/Edit Device to this Group/Scene
button to add a new responder module to the currently selected scene, or you can double-click a device in the scene list to edit its settings (brightness, ramp rate duration, etc.).
