KeypadLinc buttons, and how you use them, is a pretty complex topic for a variety of reasons. One, while the buttons are directly addressable from Indigo on newer KeypadLincs, doing so is quite expensive in terms of INSTEON traffic. So if you're doing a lot of button LED manipulation it's often better to do it in a more efficient manner (explained below).
Another complexity is how to keep buttons on multiple KPLs in sync when they are representing the same state. There are a variety of ways of doing this (again, see below for another option), but you can use INSTEON links to link those buttons together so that when, say, button 4 is pressed on KPL#1, button 5 on KPL#2 lights up as well. You can link those buttons together via the KPL instructions, or you can use Indigo's remote link management feature to do the linking.
One thing to keep in mind about KPLs: they come in 6 and 8 button configurations. On an 8 button KPL, Indigo refers to the buttons like this:
When you refer to a button on a 6 button KPL in Indigo, you refer to the buttons like this:
Note - the KPL will never send a button 2 or 8 in 6 button configuration.
There are two major tasks that you'll likely find yourself wanting to do: execute Indigo actions when a button is pressed and manage the state of a button (on/off) with Indigo.
OK, so, you just bought a KeypadLinc (KPL for short). And, you've got it wired up and controlling the load. Now, how the heck do you use those wonderful extra butons? Having Indigo execute commands when a KeypadLinc button is pressed is quite simple (for example, looking for button 3):
TRIGGERS
from the outline view on the leftNew…
buttonInsteon Command Received
from the Type:
popupDevice
radio buttonOn
from the popup labeled Received:
Button/Group 3
Actions
tab and add any actions you want to perform
That would execute whenever button 3 is pressed and turns ON. Create a similar trigger that fires when the button goes OFF to perform some other set of actions. If you don't want the button to toggle between ON and OFF (but rather just always perform the same action) then you can set the button's toggle mode (select Interfaces→INSTEON/X10 Power Line→Set KeypadLinc Button Toggle Mode…
Managing the button states from Indigo is a more complex task, though not significantly so. First thing you're gonna want to do is carefully read INSTEON Button Basics. It's critical that you understand how INSTEON Groups/Scenes work before you continue.
Woohoo, you're now done with that. Head spinning? You might want to stew on that for a few minutes before you proceed. Grab a cup of tea. Achieve a nice Zen state.
So, let's walk through a couple of scenarios, each building on the last and each becoming more complex. These How-To's assume you've already defined the KPL in Indigo.
DEVICES
(or a subfolder) in the Outline ViewEdit…
buttonEdit Device
dialog, click on the Manage Links…
buttonManage INSTEON Device Links
dialog, click New Link to Responder
- in this situation, the KPL is the controller and your device will be the responderSync Now
button
OK, so, now, when you press the button on the KPL, it should control the device as you specified. Hold the button down to dim/brighten the light. Double tap the button to do an instant on/instant off. Pretty cool. And, if you watch the log, you'll notice that Indigo sees all this traffic. In fact, you can create trigger actions that do other things in conjunction with the KPL directly controlling the linked device. For instance, if you also want an X10 light to come on/go off, you can create trigger actions that look for an on/off from that button and issue the on/off X10 command to that light. Heck, you can even have the X10 device match the brightness of the other device (Pro only - requires writing some AppleScript).
Now, the KPL is directly controlling a device, and Indigo can see those button presses. On to the next scenario.
Before we jump in, let's discuss why one would want to have Indigo turn on/off a button on a KPL. There are several possible reasons:
Anyway, now that you have some ideas. Indigo 5 introduced a new, simpler way to manage buttons. If you're using Indigo 5 or greater (and have a newer KPL), here's what you'll want to do if you want to control, say, button 3 on your KPL:
Control Light/Appliance
Turn On Keypad Button
in the Action
menuDevice
popupButton 3
from the popup below the Device
popup
This action will turn on the LED for that button. To turn it off instead, select Turn Off Keypad Button
in the Action
menu instead. If you see a warning that it won't work for your KPL (or you try it and it doesn't work), never fear. The next option will work.
If you're using Indigo 4 or greater (yes, it works equally well in Indigo 5+ and is in fact a bit faster), here's what you'll want to do:
Manage PowerLinc Links
from the Interface
menuPowerLinc Group/Scene
popup, and give it a name (I use “KPL button 3” as my naming scheme)responder
popupcontrols 3rd button LED
from the popup next to the responder
popupSync Now
button, and when that's done, click the Close (Sync Later)
buttonGreat! Now, you can send the PowerLinc Group named “KPL button 3” an ON command to turn on the led behind KPL's button 3 and OFF to turn it off. Repeat these steps with any button whose status you want to control via Indigo. NOTE: for the buttons that control the load (1 on an 8 button KPL or 1/2 & 7/8 on a 6 button KPL), you don't need to do that - you can simply send an ON/OFF to the KPL directly.
Now you have a couple of options for controlling the KPL from Indigo.
This scenario assumes you have already defined an iTunes Server device (provided by the iTunes plugin included with Indigo).
So, here's the scenario: you want to have a button on your KPL that toggles iTunes play/pause, and that stays in sync with the current state of iTunes regardless of how it was changed (paused at the computer, via Apple's Remote iPhone App, etc.) There are a bunch of different ways to do this, and it's pretty easy. The iTunes Server device has a state, so a couple of Variable Changed triggers should do the trick:
TRIGGERS
(or a subfolder) in the outline viewNew…
to create a new triggerDevice State Changed
from the Type
popupDevice
popupPlayer Status is Playing
Becomes True
radio buttonActions
tabSend INSTEON Group / Scene Command
from the Type
popupGroup On
selected from the Send
popupOK
That trigger will now turn on the button's LED when your iTunes Server device starts playing. Now, create another, just like it, except trigger it on Becomes False
and send Group Off
. That should keep the buttons in sync with the actual state of iTunes.
Next is the easy part - making the button play/pause iTunes:
TRIGGERS
from the Type:
popupOn
Device
radio buttonActions
tabExecute Script
from the Type
popupEmbedded:
radio button is checkedPython
from the popupEmbedded: Python
: itunesId = "com.perceptiveautomation.indigoplugin.itunes" itunesPlugin = indigo.server.getPlugin(itunesId) if itunesPlugin.isEnabled(): itunesPlugin.executeAction("play", deviceId=1234567890) # use the device id of your iTunes device
OK
(You've just created the trigger that will start iTunes playing - now, let's create the trigger that will pause iTunes)New…
button againInsteon Command Received
from the Type:
popupOff
Device
radio buttonActions
tabExecute Script
from the Type
popupEmbedded:
: itunesId = "com.perceptiveautomation.indigoplugin.itunes" itunesPlugin = indigo.server.getPlugin(itunesId) if itunesPlugin.isEnabled(): itunesPlugin.executeAction("pause", deviceId=1234567890) # use the device id of your iTunes device
OK
That's it! Now, you have a button that controls iTunes Play/Pause, and always reflects the state of iTunes regardless of where it was last controlled from.
