The INSTEON specification allows devices to be linked together for various purposes. Generally, you want to link a responder (for instance, a light switch) to a controller (for instance, a RemoteLinc remote control), so that when a button is pressed on a controller, the light responds to the command. This linking may be done manually by following the directions that come with the devices or they may be managed in Indigo. We're going to focus on the latter.
Scenes (or Groups - in INSTEON terminology, they are the same) generally correspond to a button/switch/toggle on a controller. So, for instance, a RemoteLinc is capable of controlling 6 Scenes - one for each button (ALL ON/OFF and BRIGHT/DIM are special purpose buttons)and a ControLinc can control 5, etc.
Indigo can remotely create and edit scenes (also called groups) between multiple remote modules. For example, you can use Indigo to remotely program button #1 on a RemoteLinc to: set the thermostat to 68°, turn off the bathroom light, brighten the bedroom sconces to 75%, dim the bedroom overhead fixture down to 35%, and turn off the hallway light.
Indigo automatically creates the links to define the scene in most remote modules. This means you do not have to press-and-hold the set button or up paddle on most remote modules. Indigo will do it all remotely for you with a single press of the Sync Now button. See the Remote INSTEON Linking option on the detail page for any supported INSTEON device linked from our INSTEON Module compatibility table - that will indicate whether Indigo can remotely manage it's links.
You can also define Indigo initiated scenes to control multiple remote modules in unison. See defining Indigo INSTEON scenes for more information on this capability.
This How-to level of difficulty is Moderate.
  1. Choose Manage INSTEON Device Links… from the Interface menu.
  1. If you want to add a new responder module to the scene, then press the New Link to Responder button. Or, if you want to change the settings (brightness, ramp rate duration, etc.) of an existing responder module in the scene, then select that module's link in the table with the Link to Responder Device column title.
  4. When responding to a scene command, most modules will control the main load (light or appliance) connected to that module. For these modules (SwitchLinc, ToggleLinc, LampLinc, etc.) you can specify the exact brightness you want for that module as well as a duration for how quickly the module should go to that brightness. Some modules will have different options. For example, when a KeypadLinc is responding to a scene command, it can turn one of the secondary button LEDs on instead of controlling the main load, or the thermostat module can respond to a scene command by changing both the thermostat operation mode and the current cool and heat setpoint temperatures.
  1. If you want to add a controller of the selected responder module, then press the New Link to Controller button. Or, if you want to change the settings (brightness, ramp rate duration, etc.) used by the selected module in a controller's scene, then select the controller module's link in the table with the Link to Controller Device column title.
Last, have Indigo write all of your link changes to the remote modules:
  • Press the Sync Now button to have Indigo immediately write all changed links to the remote modules.
OR
  • Press the Close (Sync Later) button to close the link editor window and write the changes to the modules at a later time. When you are ready to write the changes to the remote modules, select Start Sync INSTEON Device Links… from the Interface menu, and then press the press the Sync Changes Only button.
inst_remote_device_links.txt · Last modified: 2019/01/26 00:10 (external edit)
