INSTEON Device Support
INSTEON is a home automation hardware standard developed by SmartLabs. It uses dual-mesh technology to send signals over the power line as well as via RF (only available in North America). If you're unfamiliar with INSTEON, you might want to read up on how INSTEON links work. Manufacturers of INSTEON compatible products are:
You may want to check out an overview of how to define an INSTEON device in Indigo. Check out the Insteon section of our supported devices list for a good list of all Insteon devices Indigo supports.
insteon_devices.txt · Last modified: 2019/01/26 00:10 (external edit)
