This plugin allows you to get data from the WeatherSnoop application into Indigo. You may create as many “Weather Station” devices as you like - one for each instance of WeatherSnoop that you have (WeatherSnoop 2.x only supports one station at a time, WeatherSnoop 3 can have multiple stations known as agents). WeatherSnoop, with it's ability to connect to local weather station hardware (it supports a wide variety of hardware) and to Weather Underground, is a great way to get weather data into Indigo for use in your home automation logic. You can start with using a local Weather Underground station and add weather hardware later if you want more accurate data.
Each station will have a variety of device states that hold information that can be used in triggers, conditions, and on control pages.
For WeatherSnoop 3, we decided to follow the developer of WeatherSnoop's lead: each agent exposes only the fields that can be supplied by the particular hardware or source that the agent uses. So, a Davis weather station hardware may have different fields available than WeatherUnderground. The plugin will just pass through the data that the agent supplies unmodified in any way. This will make updates seamless - if the guys at Tee-Boy decide to add fields to an existing agent, they will just automatically show up as a custom state - no need to update the plugin. We think this is a much better approach in the long run.
In WeatherSnoop 3, make sure that you have “Serve my weather data via HTTP on port” checkbox selected in the Preferences.
WeatherSnoop 3 has many great features, one of which is Bonjour discovery which makes device creation a snap:
DEVICES
(or one of it's subfolders) from the Outline ViewNew…
buttonCreate New Device
dialog, select WeatherSnoop
from the Type:
popupWeatherSnoop 3 Agent
from the Model:
menuConfigure WeatherSnoop 3 Agent
dialog, you have some options:Select WeatherSnoop instance
popup. This popup shows all WeatherSnoop 3.x instances running on your local network. If you don't see your WeatherSnoop or if it's on a different network, click the Manually enter network address
checkbox, enter the host and port and click Scan for Agents
.Select WeatherSnoop agent
popup list should show all agents that WeatherSnoop has open. If there are none in the list, make sure WeatherSnoop is configured to share data and that it has at least one open agent. You can click Scan for Agents
if you made any changes in WeatherSnoop.State
column of the Device List. Most people will probably select the temperature but you can select whatever you want.Save
Create New Device
dialogAs stated above, the device states presented in the device will vary based on what's provided by the selected agent. Contact Tee-Boy about any data you believe should be available for your agent type that doesn't show up.
For WeatherSnoop 2, we attempted to create a common set of data for all supported weather stations and weather underground. This means that some information may not be available for any given station - if the data isn't available from WeatherSnoop, the value of that particular state will be “- data unavailable -”. There are some exceptions to this rule: specifically, the rain* fields will always be numeric (so that can be safely used in calculations, conditions, etc.). Here's how they work - when a weather station device is first created, these fields will be set to 0. Then based on what rain information we get, they will be set/calculated appropriately. If no rain data is ever received, they will all continue to be 0.
And, while we're on the topic, any value set to “- data unavailable -” that's used in a numeric device state condition (say, a temperature sensor that isn't working), will always return False thus aborting your trigger/schedule. So be careful about using those fields in conditions unless you're positive that they will always be available OR that triggers/schedules that depend on them firing actions won't if the data becomes unavailable.
In WeatherSnoop 2.x, make sure that you have HTTP
enabled under the Sharing
tab on the Weather Agent
configuration window.
The WeatherSnoop Plugin allows you to create Weather Station devices. To create a new one, switch to the device view and click the New…
button. This will bring up the device edit dialog. Select Plugin
from the Type:
popup. Select WeatherSnoop
from the Plugin:
popup, and select WeatherSnoop 2 Weather Station
from the Model:
button (if it doesn't open by itself) and you'll see the Configure Weather Station dialog. Enter the hostname or IP address and port of the computer running WeatherSnoop 2.x (if it's running on the same server as the Indigo server and you haven't changed the default port in WeatherSnoop, then you can just accept the defaults).
Forecast
- A word or two that describes conditions as supplied by the weather stationOutdoor Temperature °F
- Outdoor temperature in FahrenheitOutdoor Temperature °C
- Outdoor temperature in CelsiusIndoor Temperature °F
- Indoor temperature in FahrenheitIndoor Temperature °C
- Indoor temperature in CelsiusTemperature Sensor # °F
- Up to 10 different external temperature sensors in FahrenheitTemperature Sensor # °C
- Up to 10 different external temperature sensors in CelsiusOutdoor Relative Humidity
- The relative humidity outsideIndoor Relative Humidity
- The relative humidity insideHumidity Sensor #
- The relative humidity for up to 10 external humidity sensorsOutdoor Dew Point °F
- Outside dew point in FahrenheitOutdoor Dew Point °C
- Outside dew point in CelsiusIndoor Dew Point °F
- Inside dew point in FahrenheitIndoor Dew Point °C
- Inside dew point in CelsiusOutdoor Heat Index °F
- Outside heat index in FahrenheitOutdoor Heat Index °C
- Outside heat index in CelsiusIndoor Heat Index °F
- Inside heat index in FahrenheitIndoor Heat Index °C
- Inside heat index in CelsiusWind Degrees
- Wind direction in degreesWind MPH
- Wind speed in miles per hourWind KPH
- Wind speed in kilometers per hourWind Knots
- Wind speed in knotsWind Gust MPH
- Wind gust speed in miles per hourWind Gust KPH
- Wind gust speed in kilometers per hourWind Gust Knots
- Wind gust speed in knotsWind Chill °F
- Outside wind chill in FahrenheitWind Chill °C
- Outside wind chill in CelsiusPressure Trend
- A word or two describing the pressure trendPressure (inches)
- Pressure in inchesPressure (mbar)
- Pressure in millibarsRain Rate Inches per Hour
- The current rain rate in inches per hourRain Rate Millimeters per Hour
- The current rain rate in millimeters per hourRain Today Inches
- Today's rain total in inchesRain Today Millimeters
- Today's rain total in millimetersRain Yesterday Inches
- Yesterday's rain total in inchesRain Yesterday Millimeters
- Yesterday's rain total in millimetersRain Two Day Inches
- Today's + Yesterday's rain total in inches (useful for sprinkler watering logic)Rain Two Day Millimeters
- Today's + Yesterday's rain total in millimeters (useful for sprinkler watering logic)Rain Month Inches
- This month's rain total in inchesRain Month Millimeters
- This month's rain total in millimetersRain Year Inches
- This year's rain total in inchesRain Year Millimeters
- This year's rain total in millimetersRain Total Inches
- The rain total in inches for the life of this station (or it's last reset)Rain Total Millimeters
- The rain total in millimeters for the life of this station (or it's last reset)Location
- The name of the station as specified in WeatherSnoopLatitude
- Latitude of the station as specified in WeatherSnoopLongitude
- Longitude of the station as specified in WeatherSnoopHere's the plugin ID in case you need to programmatically restart the plugin:
Plugin ID: com.perceptiveautomation.indigoplugin.weathersnoop
