One of the biggest uses of HA is to control multiple lights from one switch, to create a mood or “scene” in HA speak. There are a LOT of ways to do this, some of which don't even involve Indigo (using INSTEON to directly connect devices, for instance). In this How-to, we'll describe how to create a scene in Indigo that can be used for any type of device using any technology, without using any features that are specific to a technology. There are two slightly different scenarios listed below: one that uses an INSTEON ControlLinc as the controller, and another that uses an X10 PalmPad. They both use INSTEON AND X10 devices for illustration purposes, but as you'll see they are interchangeable. This How-to level of difficulty is Simple. A more complex How-To that restores the device states is also available: note that it requires 4.0 Pro or better.
Here's the scenario we're going to address in this How-to: Joe has some nice wall sconce lights in his TV room that are controlled by a SwitchLinc and a table lamp connected through an ICON Lamp Module. He also has just installed some X10 controllable window shades (an X10 ON command lowers them, an X10 OFF command raises them in this example). He has a ControLinc (but could just as easily be a KeypadLinc, RemoteLinc, etc.) that he wants to set up so that when he hits Button 1 On, the sconces dim to 20%, the table lamp turns off, and the window shades go down. When he hits Button 1 Off, the sconces brighten to 100%, the table lamp turns on, and the window shades go up. This way, when he want's to watch a movie, the room gets dark enough to really enjoy the film, but still has a little light from the sconces.
So, how would Joe accomplish the task above? It's actually pretty simple - after making sure that he had the devices defined in Indigo, he'd just follow these steps:
So, now we need to create 2 trigger actions so that when Joe presses the right buttons on his ControLinc, the actions listed in the scenario above happen correctly. The first one will be for the On command:
TRIGGERS
in the outline view on the left side (we're going to make theseNew…
button above the trigger listINSTEON Command Received
from the Type:
popupDevice
radio button beside From:
if not already checkedDevice
On
on the popup next to Received:
, and Button/Group 1
on the popup next to thatActions
tab (you can skip Condition
for this example)Control Light / Appliance
from the Type:
popupSet Brightness
from the Action:
popupDevice:
popupAmount:
Add New
button at the lower left side of the dialog - don't worry, the one you just created isn't gone, it's just hidden - you can see all actions by clicking the Show All
button and you can cycle through all actions using the Prev
and Next
buttons next to Show:
, and you can see from the text that we're now on action 2 of 2.Control Light / Appliance
from the Type:
popupTurn Off
from the Action:
popupDevice:
popupAdd New
button againControl Light / Appliance
from the Type:
popupTurn On
from the Action:
popupDevice:
popupThat's it! So, to recap, what we did was create a trigger action that will fire when Button 1 ON on the ControLinc is pressed. It executes 3 actions: set's the brightness of the sconces to 20%, turns off the table lamp, and lowers the blinds by sending them an ON command. So, how do we reverse the process? Read on…
As you may have guessed, we need to create another trigger like the one above, except it reverses the process:
TRIGGERS
from the Type:
popupDevice
Off
tab (again, skip Condition
from the Type:
popupSet Brightness
from the Action:
popupDevice:
popupAmount:
Add New
button to add another actionControl Light / Appliance
from the Type:
popupTurn On
from the Action:
popupDevice:
popupAdd New
from the Type:
popupTurn Off
from the Action:
popupDevice:
popupHere's the scenario we're going to address in this How-to: Joe has some nice wall sconce lights in his TV room that are controlled by an SwitchLinc and a table lamp connected through an ICON Lamp Module. He also has just installed some X10 controllable window shades (an X10 ON command lowers them, an X10 OFF command raises them in this example). He has a PalmPad that he wants to set up so that when he hits Button 1 On, the sconces dim to 20%, the table lamp turns off, and the window shades go down. When he hits Button 1 Off, the sconces brighten to 100%, the table lamp turns on, and the window shades go up. This way, when he want's to watch a movie, the room gets dark enough to really enjoy the film, but still has a little light from the sconces. I'm assuming that the PalmPad is set to house code “P” and the unit code slider is set to 1-8. So, Button 1 is equal to “P1”.
TRIGGERS
button above the trigger listX10/RF Command Received
from the Type:
popupAddress
radio button below From:
Address
On
,Actions
from the Type:
popupSet Brightness
from the Action:
popupDevice:
popupAmount:
Add New
and Next
from the Type:
popupTurn Off
from the Action:
popupDevice:
popupAdd New
from the Type:
popupTurn On
from the Action:
popupDevice:
popupThat's it! So, to recap, what we did was create a trigger action that will fire when Button 1 ON on the PalmPad is pressed. It executes 3 actions: set's the brightness of the sconces to 20%, turns off the table lamp, and lowers the blinds by sending them an ON command. So, how do we reverse the process? Read on…
TRIGGERS
from the Type:
popupAddress
Address
Off
,Actions
from the Type:
popupSet Brightness
from the Action:
popupDevice:
popupAmount:
Add New
from the Type:
popupTurn On
from the Action:
popupDevice:
popupAdd New
from the Type:
popupTurn Off
from the Action:
popupDevice:
popupYou've now created two scenes for Joe's TV room: one he'll use when watching a movie and another that lightens up the room completely. As you can probably see, there are other things you can do to make this scene even more useful: if you have an Infrared receiver, you could program a button on your current IR remote to trigger the actions. If you have an Infrared transmitter, you could add extra actions that would set your A/V equipment up so that it's ready to watch a movie. The possibilities boggle the mind!
In a simple trigger action, there is probably only one action that you want to take. In the scenario that we just finished, though, we have several actions we want to perform (adjust 2 different lights and the window shades). Indigo let's you specify multiple actions in the “Create New Trigger Action” dialog, and that's how we did it here. If, however, you had multiple ways you wanted to trigger these actions (besides just buttons on a single ControLinc), then you would implement the actions in Action Groups. Feel free to read up on those at your leisure!
