We also have a Plugin List so you can quickly check to see if there's a plugin for some specific device or service you're interested in. If one isn't there for something you'd like to see, just post an idea for a plugin on the forums and we'll add it. Maybe some developer out there will think your idea is a good one and will build it.
start.txt · Last modified: 2018/02/21 18:13 by jay
