HomeSeer
HomeSeer is the maker of a variety of home automation products. On this page we'll focus on it's Z-Wave devices
SmartStick+
This is HomeSeer's USB Z-Wave interface which supports Z-Wave Plus (Gen5).
It will be found by the built-in macOS modem driver, so no 3rd party drivers need to be installed. It will show up as usbmodemXXXXXXX
where the XXXXXXX is a number derived from the USB port it's plugged into. Note that it will change if you move it to a different USB port so you'll need to reselect in the Z-Wave config dialog if you do.
Device details
HS-WD100+ Dimmer Switch
This switch's basic on/off/dim functionality should work with Indigo 6. Indigo 7+ contains the following device specific support.
Configuration Options
Reverse switch controls - reverses the on/off ends of the paddle
Local dim delta - sets the amount of dim change used for each dim step while being locally controlled
Local dim timer - sets the delay between dim step changes while being locally controlled
On/Off dim delta - sets the amount of dim change used for each dim step when receiving ON/OFF dims
On/Off dim timer - sets the delay between dim step changes when receiving ON/OFF dims
Events
Button pressed
Button double tap
Button triple tap
Button held down
Button released
Device details
HS-WS100+ Relay Switch
This switch's basic on/off functionality should work with Indigo 6. Indigo 7+ contains the following device specific support.
LED mode - changes how the LED on the switch works: Nighlight (on when device is off), Mirrors load (on when device is on), Off (never turns on)
Events
Button pressed
Button double tap
Button triple tap
Button held down
Button released
Device details
