| Next revision | Previous revision | ||
| api_release_notes:1.18 [2014/11/03 14:17] – created mattb | api_release_notes:1.18 [2026/04/07 18:27] (current) – external edit 127.0.0.1 | ||
| Line 1: | Line 1: | ||
| + | ====== API v1.18 Release Notes ====== | ||
| + | This version of the API shipped with Indigo 6.0.19 - check the [[:API Version Chart]] to see what version of the API is available in which Indigo versions. | ||
| + | * Added new device instance attribute //'' | ||
| + | ^ Example | ||
| + | dev.updateStateImageOnServer(indigo.kStateImageSel.SprinklerOff) | ||
| + | dev.updateStateImageOnServer(indigo.kStateImageSel.SprinklerOn) | ||
| + | dev.updateStateImageOnServer(indigo.kStateImageSel.HvacCooling) | ||
| + | dev.updateStateImageOnServer(indigo.kStateImageSel.PowerOn) | ||
| + | dev.updateStateImageOnServer(indigo.kStateImageSel.SensorOn) | ||
| + | dev.updateStateImageOnServer(indigo.kStateImageSel.TimerOn)</ | ||
| + | * Added support for configuration UI to show error alerts (via //'' | ||
| + | ^ Example | ||
| + | errorDict = indigo.Dict() | ||
| + | errorDict[" | ||
| + | return (valuesDict, | ||
