Link to this comparison view
Next revision
Previous revision
api_release_notes:2.2 [2019/09/30 19:51] mattbapi_release_notes:2.2 [2026/04/07 18:27] (current) – external edit 127.0.0.1
Line 1: Line 1:
 +====== API v2.2 Release Notes ======
 +This version of the API shipped with Indigo 7.4.0 - check the [[:API Version Chart]] to see what version of the API is available in which Indigo versions.
 +  * Added device property //''SupportsOnState''// with value of True to relay and dimmer class devices. This allows for device UI filtering using //''props.SupportsOnState''//, which will select all relays, dimmers, and sensors that have an on/off state.
 +  * Removed ability to execute embedded AppleScripts in actions and added conditional Python support to Triggers and Schedules. This is not an API or Indigo Object Model change, but if a plugins requires Indigo Server python conditional support they can set their ServerApiVersion to 2.2 and Indigo will only install/enable the plugin if the user is running Indigo 7.4.0+.
