Link to this comparison view
Next revision
Previous revision
indigo_2022.1_documentation:insteon_specific_commands [2022/03/11 20:28] – external edit 127.0.0.1indigo_2022.1_documentation:insteon_specific_commands [2025/04/14 20:10] (current) – external edit 127.0.0.1
Line 1: Line 1:
 +====== INSTEON Commands (indigo.insteon.*) ======
 +Commands that are specific to INSTEON devices.
 +==== Send Scene Decrease ====
 +This command will send an INSTEON Scene Decrease (dim on dimmable loads) command to the specified PowerLinc scene. The value will decrease by 3% for each call.
 +^  Command Syntax Examples  ^
 +|<code>indigo.insteon.sendSceneDecrease(11)</code>|
 +|<code>indigo.insteon.sendSceneDecrease(11, repeatCount=5)</code>|
 +|<code>indigo.insteon.sendSceneDecrease(11, suppressLogging=True)</code>|
 +|<code>indigo.insteon.sendSceneDecrease(11, updateStatesOnly=True)</code>|
 +|<code>indigo.insteon.sendSceneDecrease("working in office scene")</code>|
 +^  Parameters  ^^^^
 +^  Parameter  ^  Required  ^  Type  ^  Description  ^
 +|direct parameter|  Yes  |  integer or string  |either the scene number or the scene name - we encourage numbers since they won't change and the scene names can.|
 +|//''repeatCount''// No  |  integer  |a value from 1-32 for the number of times to repeat the decrease (default is 1)|
 +|//''suppressLogging''// No  |  boolean  |True if entries in the event log should be suppressed (default is False)|
 +|//''updateStatesOnly''// No  |  boolean  |use if you only want Indigo's internal device state representation to be updated - no actual INSTEON command will be sent on RF or the power line (default is False)|
 +==== Send Scene Increase ====
 +This command will send an INSTEON Scene Increase (brighten on dimmable loads) command to the specified PowerLinc scene. The value will increase by 3% for each call.
 +|<code>indigo.insteon.sendSceneIncrease(11)</code>|
 +|<code>indigo.insteon.sendSceneIncrease(11, repeatCount=5)</code>|
 +|<code>indigo.insteon.sendSceneIncrease(11, suppressLogging=True)</code>|
 +|<code>indigo.insteon.sendSceneIncrease("working in office scene")</code>|
 +^  Parameters  ^^^^
 +|//''repeatCount''// No  |  integer  |a value from 1-32 for the number of times to repeat the increase (default is 1)|
 +==== Send Scene ON ====
 +This command will send an INSTEON Scene ON command using the specified PowerLinc scene.
 +|<code>indigo.insteon.sendSceneOn(11)</code>|
 +|<code>indigo.insteon.sendSceneOn(11, sendCleanUps=False)</code>|
 +|<code>indigo.insteon.sendSceneOn(11, suppressLogging=True)</code>|
 +|<code>indigo.insteon.sendSceneOn(11, updateStatesOnly=True)</code>|
 +|<code>indigo.insteon.sendSceneOn("working in office scene")</code>|
 +|<code>indigo.insteon.sendSceneOn("working in office scene", sendCleanUps=False)</code>|
 +^  Parameters  ^^^^
 +|//''sendCleanUps''// No  |  boolean  |True if cleanup messages should be sent to each device in the scene after the scene command - this will have the PowerLinc send each device a message to make sure it received the command. You might want to stop cleanup messages from being sent because it involves adding a lot of INSTEON traffic and might affect performance (particularly if a group has a lot of responders). But, of course, disabling it may reduce reliability of some modules receiving the scene command so it's usually best to ignore this setting. (default is True)|
 +==== Send Scene OFF ====
 +This command will send an INSTEON Scene OFF command using the specified PowerLinc scene.
 +|<code>indigo.insteon.sendSceneOff(11)</code>|
 +|<code>indigo.insteon.sendSceneOff(11, sendCleanUps=False)</code>|
 +|<code>indigo.insteon.sendSceneOff(11, suppressLogging=True)</code>|
 +|<code>indigo.insteon.sendSceneOff(11, updateStatesOnly=True)</code>|
 +|<code>indigo.insteon.sendSceneOff("working in office scene")</code>|
 +|<code>indigo.insteon.sendSceneOff("working in office scene", sendCleanUps=False)</code>|
 +^  Parameters  ^^^^
 +==== Send Scene Fast ON ====
 +This command will send an INSTEON Scene Fast ON command using the specified PowerLinc scene.
 +|<code>indigo.insteon.sendSceneFastOn(11)</code>|
 +|<code>indigo.insteon.sendSceneFastOn(11, sendCleanUps=False)</code>|
 +|<code>indigo.insteon.sendSceneFastOn(11, suppressLogging=True)</code>|
 +|<code>indigo.insteon.sendSceneFastOn(11, updateStatesOnly=True)</code>|
 +|<code>indigo.insteon.sendSceneFastOn("working in office scene")</code>|
 +|<code>indigo.insteon.sendSceneFastOn("working in office scene", sendCleanUps=False)</code>|
 +^  Parameters  ^^^^
 +==== Send Scene Fast OFF ====
 +This command will send an INSTEON Scene Fast OFF command using the specified PowerLinc scene.
 +|<code>indigo.insteon.sendSceneFastOff(11)</code>|
 +|<code>indigo.insteon.sendSceneFastOff(11, sendCleanUps=False)</code>|
 +|<code>indigo.insteon.sendSceneFastOff(11, suppressLogging=True)</code>|
 +|<code>indigo.insteon.sendSceneFastOff(11, updateStatesOnly=True)</code>|
 +|<code>indigo.insteon.sendSceneFastOff("working in office scene")</code>|
 +|<code>indigo.insteon.sendSceneFastOff("working in office scene", sendCleanUps=False)</code>|
 +^  Parameters  ^^^^
 +==== Send Scene Start Change ====
 +This command will tell the specified PowerLinc scene to begin increasing/decreasing in value. It will continue to ramp each device in the scene until either the corresponding [[#Send Scene Stop Change]] command is called or until the devices are at 100% for increase ramping or 0% for decrease ramping.
 +|<code>indigo.insteon.sendSceneIncrease(11, increase=True)</code>|
 +^  Parameters  ^^^^
 +|//''increase''// Yes  |  boolean  |True if you want to ramp up, False if you want to ramp down  |
 +==== Send Scene Stop Change ====
 +This command will tell the specified PowerLinc scene to stop any ramping activity started by a [[#Send Scene Start Change]] command.
 +^  Parameters  ^^^^
 +==== Send Status Request ====
 +This command will send an INSTEON Status Request command to the specified address.
 +|<code>reply = indigo.insteon.sendStatusRequest("0A.B9.DC")
 +indigo.server.log("reply success: %d, ack value: %02X" % (reply.cmdSuccess, reply.ackValue))</code>|
 +^  Parameters  ^^^^
 +|direct parameter|  Yes  |  string  |the target INSTEON address as a hexadecimal string.|
 +|//''waitUntilAck''// No  |  boolean  |true if the caller wants to wait for the result. (default is True)|
 +==== Send Raw ====
 +This command will send a raw INSTEON standard command.
 +|<code>reply = indigo.insteon.sendRaw("0A.B9.DC", [0x10, 0x00])
 +^  Parameters  ^^^^
 +|//''cmdBytes''// Yes  |  list  |a list of 2 integer bytes that represent the command to be sent.|
 +|//''waitUntilAck''// No  |  boolean  |True if the caller wants to wait for the result. (default is True)|
 +|//''waitForStandardReply''// No  |  boolean  |True if the caller wants to wait for a follow-up direct standard reply. (default is False)|
 +|//''waitForExtendedReply''// No  |  boolean  |True if the caller wants to wait for a follow-up direct extended reply. (default is False)|
 +==== Send Raw Extended ====
 +This command will send a raw INSTEON extended command (command payload can be between 2 and 16 bytes).
 +|<code># Get KeypadLinc info (LED states, brightness, etc.)
 +reply = indigo.insteon.sendRawExtended("11.7B.2E", [0x2E, 0x00], waitForExtendedReply=True)
 +if reply.cmdSuccess:
 + indigo.server.log("     backlight brightness: %d" % (reply.replyBytes[10],))
 + indigo.server.log("button toggle mode bitmap: 0x%02X" % (reply.replyBytes[11],))
 + indigo.server.log("     button states bitmap: 0x%02X" % (reply.replyBytes[12],))</code>|
 +|<code># Change the Keypad LED brightness from dim to bright
 +setKeypadLedBrightness = [
 + 0x2E, 0x00,
 + 0x00, # unused
 + 0x07, # change LED backlight brightness
 + 0x11, # brightness between 0x11 and 0x7F
 + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00
 +for brightness in [0x07, 0x44, 0x66, 0x7F]:
 + setKeypadLedBrightness[4] = brightness
 + indigo.insteon.sendRawExtended("11.7B.2E", setKeypadLedBrightness)</code>|
 +^  Parameters  ^^^^
 +|//''cmdBytes''// Yes  |  list  |a list of 2 to 16 integer bytes that represent the command to be sent.|
 +|//''calcCrc''// No  |  boolean  |automatically calculate 8 bit CRC byte for message (used by i2CS firmware). (default is True)|
 +|//''calc16bitCrc''// No  |  boolean  |automatically calculate 16 bit CRC byte for message (used by specific modules). (default is False)|
 +==== Send PowerLinc SET Button Press Message ====
 +This will command the PowerLinc to send its SET Button Press Message, which can be useful in some linking scenarios.
 +|<code>reply = indigo.insteon.sendPowerLincSetButtonPress()</code>|
 +^  Parameters  ^^^^
 +==== Subscribe to Events ====
 +Use the lower-level //''subscribeToIncoming()''// and //''subscribeToOutgoing()''// methods in the //''indigo.insteon''// command space to see commands regardless of their effect on device state.
 +^  Low Level Commands  ^
 +|indigo.insteon.subscribeToIncoming()|
 +|indigo.insteon.subscribeToOutgoing()|
 +For example,
 +<code>
 +    def startup(self):
 +        self.logger.debug("startup called -- subscribing to all INSTEON commands")
 +        indigo.insteon.subscribeToIncoming()
 +        indigo.insteon.subscribeToOutgoing()
 +    def insteonCommandReceived(self, cmd):
 +        self.logger.debug(f"insteonCommandReceived: \n{str(cmd)}")
 +    def insteonCommandSent(self, cmd):
 +        self.logger.debug(f"insteonCommandSent: \n{str(cmd)}")
 +</code>
