| Next revision | Previous revision | ||
| indigo_2022.2_documentation:iws_plugin_guide [2023/01/06 20:46] – external edit 127.0.0.1 | indigo_2022.2_documentation:iws_plugin_guide [2025/04/14 20:10] (current) – created - external edit 127.0.0.1 | ||
| Line 1: | Line 1: | ||
| + | ===== Indigo Web Server (IWS) Plugins ===== | ||
| + | IWS Plugins add functionality to the Indigo Web Server. If you’re familiar with how web forms are processed then it should be pretty straight-forward to understand how to develop an IWS plugin. If you’re familiar with Python, then your job will be even easier. It’s important to note, however, that IWS Plugins that show HTML pages aren’t compatible with Indigo Touch - Touch doesn’t render control pages via HTML so if your plugin presents a UI, Indigo Touch will direct any request to your plugin to Safari rather than render your plugin’s UI within the Indigo Touch application. | ||
| + | An IWS Plugin can handle multiple request types (identified on the URL) by defining several handlers: | ||
| + | http:// | ||
| + | http:// | ||
| + | http:// | ||
| + | and so on, and any handler can take parameters either via a POST or a GET: | ||
| + | So, how do you implement an IWS Plugin? An IWS Plugin requires a very specific layout of files/ | ||
| + | A IWS plugin directory is installed into the following location to become active: | ||
| + | The folders in this structure are as follows: | ||
| + | The ''// | ||
| + | Imports are just the imports necessary for your plugin to work. These are standard Python import statements. Some common imports you’ll need are FIXME. | ||
| + | There are five optional static hook methods that get called by IWS for various purposes: | ||
| + | The last, and most important part of the code, is your request handler class. The methods defined in this class are automatically called based on the URL requested. The class itself may be named anything, but must be a subclass of BaseRequestHandler: | ||
| + | The plugin request handler must subclass from BaseRequestHandler and must call the parent class ''// | ||
| + | BaseRequestHandler.__init__(self, | ||
| + | Most plugins will have an index method - this is what’s called when the plugin’s path doesn’t contain an actual handler: | ||
| + | The method should do something for the user - some plugins just call another handler with default values, others will just display a control page like UI, and still other will show a simple text page that tells the user how to use the plugin. This index method, for example, just calls another handler in the class: | ||
| + | thePage = self.getReportForDay() | ||
| + | return thePage | ||
| + | index.exposed = True # exposed = True must be set for handler func to be called</ | ||
| + | You’ll notice that there’s an extra line after the definition of the index handler: | ||
| + | This tells IWS that this method is available as an externally called handler. You can define helper methods in your class that shouldn’t be called directly by the user - adding this line (handlername.exposed) will restrict user access to only those methods which you want the user to use. | ||
| + | That’s the basic structure of the //'' | ||
| + | The first parameter to all methods is always self, and represents your request handler class. Any parameters defined after that will be taken either from the URL (via GET processing) or from the body via a POST. So, from looking at this method, we can see that the handler is looking for 4 parameters. You could call this method like this: | ||
| + | It would also be processed via a POST with those values in the form. Now that you know how to construct request handlers, let’s talk about how the //'' | ||
| + | So, now you know how to receive a request and how to communicate with IndigoServer. The last piece is how to display the page in the user’s browser. The simplest answer is this: return an HTML string. However, generating HTML manually can be pretty ugly depending on how complex the HTML is. We addressed this problem by integrating the Cheetah template engine into IWS. | ||
| + | In a nutshell, a Cheetah template file is an HTML file with markups in it. Cheetah will allow many Python variable types to be embedded in your HTML template. It also offers some basic flow-control statements like IF and FOR. Check the [[http:// | ||
| + | For instance, here is a small snippet of a Cheetah template that generates table rows, with alternating color, one row for each string in an array: | ||
| + | <tr> | ||
| + | <td colspan=2 align=" | ||
| + | #set $i=1 | ||
| + | #for $deviceKey in $totalKeys | ||
| + | #if (($i % 2) != 0) | ||
| + | #else | ||
| + | #end if | ||
| + | #set $i=$i+1 | ||
| + | <td class=" | ||
| + | </tr> | ||
| + | #end for | ||
| + | First we start the table and put in a header row. Then the local variable, //'' | ||
| + | Cheetah templates can contain javascript, CSS, etc. - basically everything a normal HTML page can. lines that start with //''#''// | ||
| + | Now that you have your template defined, how do you get it processed? That’s actually pretty simple. In your request handler method, you do four things: 1) get (and lock) the plugin template, 2) set the variables used in the template, 3) tell the engine to render the template into a full HTML document, 4) unlock the template. | ||
| + | Here’s an example of how you might render the template file that the snippit above came from: | ||
| + | try: | ||
| + | tmpl.totals = totals | ||
| + | tmpl.totalKeys = totalKeys | ||
| + | return tmpl.RenderTemplate() | ||
| + | finally: | ||
| + | tmpl.ReleaseLock();</ | ||
| + | So, the first line gets the template and locks it so that it can’t be altered during the rendering. The next step is to process the template. Notice that we put all the template processing code inside a try block - we have to do that because we must always release the lock on the template no matter what errors might be encountered during the processing of the template. | ||
| + | Inside the try block, we see these lines: | ||
| + | tmpl.totalKeys = totalKeys</ | ||
| + | These two lines set the cheetah template variables (//'' | ||
| + | Next, we want to process the template: | ||
| + | This line calls the Cheetah //'' | ||
| + | The last two lines are critical: | ||
| + | This will ensure that the template is unlocked even if an error occurred during template processing. Not doing so will cause this template to be unavailable until IWS is restarted. | ||
| + | So, that’s how an IWS plugin is built. It’s quite flexible and can be used for a variety of purposes, from getting data into Indigo (have a handler that “catches” a POST or GET from some other system and stored data into Indigo variables) to creating custom web-based UIs. | ||
