Link to this comparison view
indigo_2022.2_documentation:rest_to_http_api_conversion_examples [2023/02/28 20:33] davel17indigo_2022.2_documentation:rest_to_http_api_conversion_examples [2024/06/27 00:08] (current) – external edit 127.0.0.1
Line 1: Line 1:
 +====== REST API Conversion Examples ======
 +If you're using the old REST API (which has been deprecated), here are some examples of how you might convert your REST usages to the HTTP API.
 +The first thing you'll want to understand is how to use [[api#authentication1|authentication with the HTTP API]]. The examples below use both headers and query args for authentication. You can use whichever works for you. You should replace ''YOUR-API-KEY'' with [[https://www.indigodomo.com/account/authorizations|your actual API Key]].
 +Second, all replies to the API will be [[api#api_messages|JSON messages]].
 +In the following examples, we'll be using a mix of authentication headers and the API Key as a query arg. You can use either. We mark the examples **REST** (old REST API) and **HTTP** (newer HTTP API).
 +===== Device Access =====
 +==== Getting Devices ====
 +=== get device list ===
 +== REST ==
 +<code>http://username:[email protected]:8176/devices.json</code>
 +== HTTP ==
 +<code>http://127.0.0.1:8176/v2/api/indigo.devices?api-key=YOUR-API-KEY</code>
 +This will return a JSON list of [[indigo_2022.2_documentation:api#device_objects|Device Objects]].
 +=== get single device ===
 +== REST ==
 +<code>http://username:[email protected]:8176/devices/office-lamp.json</code>
 +== HTTP ==
 +<code>http://127.0.0.1:8176/v2/api/indigo.devices/123456789?api-key=YOUR-API-KEY </code>
 +Insert the ID of the ''office-lamp'' device rather than the name. Note you can quickly copy the device ID to the clipboard by right-clicking on the device in Indigo app's main window and choosing the ''Copy ID'' context menu.
 +This will return a single [[indigo_2022.2_documentation:api#device_objects|Device Object]].
 +==== Device Commands ====
 +Sending commands to devices requires that you POST a JSON message to the ''**/v2/api/command**'' URL.
 +=== set brightness ===
 +== REST ==
 +<code>''curl -X PUT -u user:password --digest -d brightness=27 http://127.0.0.1:8176/devices/office-lamp''</code>
 +== HTTP ==
 +<code>curl -X POST -H "Authorization: Bearer YOUR-API-KEY" -d '{"message":"indigo.device.setBrightness","objectId":123456789,"parameters":{"value":27}}' http://127.0.0.1:8176/v2/api/command</code>
 +Insert the ID of the ''office-lamp'' device as the objectId.
 +=== turn on/turn off ===
 +== REST ==
 +<code>''curl -X PUT -u user:password --digest -d isOn=1 http://127.0.0.1:8176/devices/office-lamp''</code>
 +<code>''curl -X PUT -u user:password --digest -d isOn=0 http://127.0.0.1:8176/devices/office-lamp''</code>
 +== HTTP ==
 +<code>curl -X POST -H "Authorization: Bearer YOUR-API-KEY" -d '{"message":"indigo.device.turnOn","objectId":123456789}' http://127.0.0.1:8176/v2/api/command</code>
 +<code>curl -X POST -H "Authorization: Bearer YOUR-API-KEY" -d '{"message":"indigo.device.turnOff","objectId":123456789}' http://127.0.0.1:8176/v2/api/command</code>
 +=== toggle ===
 +== REST ==
 +<code>''curl -X PUT -u user:password --digest -d toggle=1 http://127.0.0.1:8176/devices/office-lamp''</code>
 +== HTTP ==
 +<code>curl -X POST -H "Authorization: Bearer YOUR-API-KEY" -d '{"message":"indigo.device.toggle","objectId":123456789}' http://127.0.0.1:8176/v2/api/command</code>
 +=== change speed index (fan) ===
 +These examples will set device ''office-ceiling-fan'' to 0 (off), then set to 3 (high), then decrease back to 0 (off).
 +== REST ==
 +<code>''curl -X PUT -u user:password --digest -d speedIndex=0 http://127.0.0.1:8176/devices/office-ceiling-fan''</code>
 +<code>''curl -X PUT -u user:password --digest -d speedIndex=3 http://127.0.0.1:8176/devices/office-ceiling-fan''</code>
 +<code>''curl -X PUT -u user:password --digest -d speedIndex=dn http://127.0.0.1:8176/devices/office-ceiling-fan''</code>
 +== HTTP ==
 +<code>curl -X POST -H "Authorization: Bearer YOUR-API-KEY" -d '{"message":"indigo.speedcontrol.setSpeedIndex","objectId":123456789,"parameters":{"value":0}}' http://127.0.0.1:8176/v2/api/command</code>
 +<code>curl -X POST -H "Authorization: Bearer YOUR-API-KEY" -d '{"message":"indigo.speedcontrol.setSpeedIndex","objectId":123456789,"parameters":{"value":3}}' http://127.0.0.1:8176/v2/api/command</code>
 +<code>curl -X POST -H "Authorization: Bearer YOUR-API-KEY" -d '{"message":"indigo.speedcontrol.decreaseSpeedIndex","objectId":123456789}' http://127.0.0.1:8176/v2/api/command</code>
 +Insert the ID of the ''office-ceiling-fan'' device as the objectId.
 +=== change sprinkler zones ===
 +These examples will change device ''irrmaster-pro'' active sprinkler zone to 3 and all off.
 +== REST ==
 +<code>''curl -X PUT -u user:password --digest -d activeZone=3 http://127.0.0.1:8176/devices/irrmaster-pro''</code>
 +<code>''curl -X PUT -u user:password --digest -d activeZone=0 http://127.0.0.1:8176/devices/irrmaster-pro''</code>
 +== HTTP ==
 +<code>curl -X POST -H "Authorization: Bearer YOUR-API-KEY" -d '{"message":"indigo.sprinkler.setActiveZone","objectId":123456789,"parameters":{"index":3}}' http://127.0.0.1:8176/v2/api/command</code>
 +<code>curl -X POST -H "Authorization: Bearer YOUR-API-KEY" -d '{"message":"indigo.sprinkler.setActiveZone","objectId":123456789,"parameters":{"index":0}}' http://127.0.0.1:8176/v2/api/command</code>
 +Insert the ID of the ''irrmaster-pro'' device as the objectId.
 +=== set thermostat setpoints ===
 +These examples will set device ''thermostat'''s heat and cool setpoints
 +== REST ==
 +<code>''curl -X PUT -u user:password --digest -d setpointCool=76 http://127.0.0.1:8176/devices/thermostat''</code>
 +<code>''curl -X PUT -u user:password --digest -d setpointHeat=70 http://127.0.0.1:8176/devices/thermostat''</code>
 +**Increase Heat Setpoint**
 +<code>''curl -X PUT -u user:password --digest -d setpointHeat=up http://127.0.0.1:8176/devices/thermostat''</code>
 +== HTTP ==
 +<code>curl -X POST -H "Authorization: Bearer YOUR-API-KEY" -d '{"message":"indigo.thermostat.setCoolSetpoint","objectId":123456789,"parameters":{"value":76}}' http://127.0.0.1:8176/v2/api/command</code>
 +<code>curl -X POST -H "Authorization: Bearer YOUR-API-KEY" -d '{"message":"indigo.thermostat.setHeatSetpoint","objectId":123456789,"parameters":{"value":70}}' http://127.0.0.1:8176/v2/api/command</code>
 +<code>curl -X POST -H "Authorization: Bearer YOUR-API-KEY" -d '{"message":"indigo.thermostat.increaseHeatSetpoint","objectId":123456789}' http://127.0.0.1:8176/v2/api/command</code>
 +Insert the ID of the ''thermostat'' device as the objectId.
 +=== set thermostat mode ===
 +These examples will set device ''thermostat'''s mode to "cool on" and "auto on"
 +== REST ==
 +<code>''curl -X PUT -u user:password --digest -d hvacCurrentMode="cool on" http://127.0.0.1:8176/devices/thermostat''</code>
 +<code>''curl -X PUT -u user:password --digest -d hvacCurrentMode="auto on" http://127.0.0.1:8176/devices/thermostat''</code>
 +== HTTP ==
 +<code>curl -X POST -H "Authorization: Bearer YOUR-API-KEY" -d '{"message":"indigo.thermostat.setHvacMode","objectId":123456789,"parameters":{"value":"indigo.kHvacMode.Cool"}}' http://127.0.0.1:8176/v2/api/command</code>
 +<code>curl -X POST -H "Authorization: Bearer YOUR-API-KEY" -d '{"message":"indigo.thermostat.setHvacMode","objectId":123456789,"parameters":{"value":"indigo.kHvacMode.HeatCool"}}' http://127.0.0.1:8176/v2/api/command</code>
 +=== set thermostat fan mode ===
 +These examples will set device ''thermostat'''s fan mode to "always on" and "auto on"
 +== REST ==
 +<code>''curl -X PUT -u user:password --digest -d hvacFanMode="always on" http://127.0.0.1:8176/devices/thermostat''</code>
 +<code>''curl -X PUT -u user:password --digest -d hvacFanMode="auto on" http://127.0.0.1:8176/devices/thermostat''</code>
 +== HTTP ==
 +<code>curl -X POST -H "Authorization: Bearer YOUR-API-KEY" -d '{"message":"indigo.thermostat.setFanMode","objectId":123456789,"parameters":{"value":"indigo.kFanMode.AlwaysOn"}}' http://127.0.0.1:8176/v2/api/command</code>
 +<code>curl -X POST -H "Authorization: Bearer YOUR-API-KEY" -d '{"message":"indigo.thermostat.setFanMode","objectId":123456789,"parameters":{"value":"indigo.kFanMode.Auto"}}' http://127.0.0.1:8176/v2/api/command</code>
 +===== Variable Access =====
 +==== Getting Variables ====
 +=== get variable list ===
 +== REST ==
 +<code>http://username:[email protected]:8176/variables.json</code>
 +== HTTP ==
 +<code>http://127.0.0.1:8176/v2/api/indigo.variables?api-key=YOUR-API-KEY</code>
 +This will return a JSON list of [[indigo_2022.2_documentation:api#variable_objects|Variable Objects]].
 +=== get single variable ===
 +== REST ==
 +<code>http://username:[email protected]:8176/variables/sprinklerDurationMultiplier.json</code>
 +== HTTP ==
 +<code>http://127.0.0.1:8176/v2/api/indigo.variables/123456789?api-key=YOUR-API-KEY</code>
 +Insert the ID of the ''sprinklerDurationMultiplier'' variable rather than the name.
 +This will return a single [[indigo_2022.2_documentation:api#variable_objects|Variable Object]].
 +==== Variable Commands ====
 +Sending commands to the server requires that you POST a JSON message to the ''**/v2/api/command**'' URL.
 +=== update variable value ===
 +== REST ==
 +<code>''curl -X PUT -u user:password --digest -d value=1.23 http://127.0.0.1:8176/variables/sprinklerDurationMultiplier''</code>
 +== HTTP ==
 +<code>curl -X POST -H "Authorization: Bearer YOUR-API-KEY" -d '{"message":"indigo.variable.updateValue","objectId":123456789,"parameters":{"value":"1.23"}}' http://127.0.0.1:8176/v2/api/command</code>
 +Insert the ID of the ''sprinklerDurationMultiplier'' variable as the objectId. **Note**: variable values are always strings to make sure to enclose the value in quotes.
 +===== Action Group Access =====
 +==== Getting Action Groups ====
 +=== get action group list ===
 +== REST ==
 +<code>http://username:[email protected]:8176/actions.json</code>
 +== HTTP ==
 +<code>http://127.0.0.1:8176/v2/api/indigo.actionGroups?api-key=YOUR-API-KEY</code>
 +This will return a JSON list of [[indigo_2022.2_documentation:api#action_group_objects|Action Group Objects]].
 +=== get single action group ===
 +== REST ==
 +<code>http://username:[email protected]:8176/actions/party%20scene.json</code>
 +== HTTP ==
 +<code>http://127.0.0.1:8176/v2/api/indigo.actionGroups/123456789?api-key=YOUR-API-KEY</code>
 +Insert the ID of the ''party scene'' action group rather than the name.
 +This will return a single [[indigo_2022.2_documentation:api#action_group_objects|Action Group Object]].
 +==== Action Group Commands ====
 +=== execute action group ===
 +== REST ==
 +<code>''curl -X EXECUTE -u user:password --digest -d value=1.23 http://127.0.0.1:8176/actions/party%20scene''</code>
 +== HTTP ==
 +<code>curl -X POST -H "Authorization: Bearer YOUR-API-KEY" -d '{"message":"indigo.actionGroup.execute","objectId":123456789}' http://127.0.0.1:8176/v2/api/command</code>
 +Insert the ID of the ''party scene'' action group as the objectId.
