Link to this comparison view
Next revision
Previous revision
indigo_2023.2_documentation:overview [2025/04/14 20:10] – external edit 127.0.0.1indigo_2023.2_documentation:overview [2025/10/21 22:04] (current) – [Insert Event Data into Variable] davel17
Line 508: Line 508:
 Click the ''**Edit Action Settings...**'' button and it will open a dialog (shown above). Here you will select the variable and, optionally, the format string as defined in the [[http://docs.python.org/2/library/datetime.html#strftime-and-strptime-behavior|Python datetime string formatting]] documentation (see the chart at the bottom for format specifiers). The format in the **''Format string''** field is the default format. Click the ''**Edit Action Settings...**'' button and it will open a dialog (shown above). Here you will select the variable and, optionally, the format string as defined in the [[http://docs.python.org/2/library/datetime.html#strftime-and-strptime-behavior|Python datetime string formatting]] documentation (see the chart at the bottom for format specifiers). The format in the **''Format string''** field is the default format.
 === Toggle Variable === === Toggle Variable ===
  • /www/perceptive/wiki/data/attic/indigo_2023.2_documentation/overview.1744661437.txt.gz
