Link to this comparison view
Next revision
Previous revision
indigo_2023.2_documentation:overview [2025/10/21 21:49] – [Insert Event Data into Variable] davel17indigo_2023.2_documentation:overview [2025/10/21 22:04] (current) – [Insert Event Data into Variable] davel17
Line 509: Line 509:
 Click the ''**Edit Action Settings...**'' button and it will open a dialog (shown above). Here you will select the variable and, optionally, the format string as defined in the [[http://docs.python.org/2/library/datetime.html#strftime-and-strptime-behavior|Python datetime string formatting]] documentation (see the chart at the bottom for format specifiers). The format in the **''Format string''** field is the default format. Click the ''**Edit Action Settings...**'' button and it will open a dialog (shown above). Here you will select the variable and, optionally, the format string as defined in the [[http://docs.python.org/2/library/datetime.html#strftime-and-strptime-behavior|Python datetime string formatting]] documentation (see the chart at the bottom for format specifiers). The format in the **''Format string''** field is the default format.
-=== Insert Event Data into Variable ===
-{{:indigo_2023.2_documentation:insert_event_data_into_variable.png?600|}}
-Click the ''**Edit Action Settings...**'' button and it will open a dialog (shown above). Here you will select the variable and, optionally, the ''**Path specifier**'' if you want to access specific parts of the event data.
-Path specifiers use a specific syntax and require knowledge of the event data you'll be receiving from the event. For example, given this Indigo event data:
-<code>
-    "foo": 1234567890,
-    "bar": "Baz",
-    "data": ["Thing 1", "Thing 2"],  # a list
-    "more_data": {'a': 1, 'b': 2},  # a dictionary
-    "timestamp": "2025-08-07T14:32:21",
-</code>
-You could use path specifiers like these to have the associated data inserted into the variable you chose:
-<code>
-"source" equals "server"
-"data" equals ["Thing 1", "Thing 2"]
-"more_data['b'] equals {'a': 1, 'b': 2}
-</code>
-If you want to go deeper into the payload, the path specifiers can be chained together like this:
-<code>
-    "bar": "Baz",
-    "data": [
-        "Thing 1",
-            "Thing A",
-            "Thing B",
-            "Thing C"
-    "more_data": {
-        "a": 1,
-        "b": 2,
-        "c": [
-            1,
-            2,
-            3,
-            4,
-            5
-</code>
-You can go deeper like this:
-<code>
-"data[0]" equals "Thing 1"  # The index of the list element, the index starts at zero
-"data[1][2]" equals "Thing C" # The second element (index 1) of "data" is a list and the third element (index 2) of that list is "Thing C"
-"more_data.a" equals 1  # The value of key "a" is 1
-"more_data.c[3] equals 4  # The value of key "c" is a list and the fourth element (index 3) of that list is 4
-</code>
-You can chain these path specifiers as needed, such as //''some_json[3].a.foo[9]''//
 === Toggle Variable === === Toggle Variable ===
 {{toggle_variable_action.png?nolink|Toggle Variable Action Image}} {{toggle_variable_action.png?nolink|Toggle Variable Action Image}}
  • /www/perceptive/wiki/data/attic/indigo_2023.2_documentation/overview.1761083391.txt.gz
  • Last modified: 2025/10/21 21:49
  • by davel17
