Link to this comparison view
Next revision
Previous revision
indigo_2024.1_documentation:plugin_testing_tutorial [2024/10/21 18:49] – [Testing Elements] davel17indigo_2024.1_documentation:plugin_testing_tutorial [2024/10/21 18:51] (current) – [Folder Structure] davel17
Line 18: Line 18:
 === Environment Variables === === Environment Variables ===
-While optional, it is a good idea to create an environment variable framework that allows you to create and make references to elements of your development environment. Once you have installed ''//python-dotenv//'', create a ''//.ENV//'' file at the ''//Server Plugin//'' level of your plugin (or other location that Indigo's environment path search will find it). It is a plain text file. The advantage of using an environment file is that it is a great place to store references that are unique to your system and -- for shared development -- each developer can have their own individual environment. **<color #ed1c24>IMPORTANT!</color> Remember to add the ''//.ENV//'' file to your ''//.gitignore//'' list.**+While optional, it is a good idea to create an environment variable framework that allows you to create and make references to elements of your development environment. Once you have installed ''//python-dotenv//'', create a ''//.ENV//'' file at the ''//Server Plugin//'' level of your plugin (or another location that Indigo's environment path will search). It is a plain text file. The advantage of using an environment file is that it is a great place to store references that are unique to your system and -- for shared development -- each developer can have their own individual environment. **<color #ed1c24>IMPORTANT!</color> Remember to add the ''//.ENV//'' file to your ''//.gitignore//'' list.**
 .ENV file .ENV file
Line 39: Line 39:
      |_ ...      |_ ...
 </code> </code>
-Of course, you can put them anywhere that your plugin can see them. Depending on your development environment, you may also want to add the ''//Tests//'' folder to your ''//.gitignore//'' file to reduce the footprint of your published plugin.+Of course, you can put them anywhere your plugin can see them. Depending on your development environment, you may also want to add the ''//Tests//'' folder to your ''//.gitignore//'' file to reduce the footprint of your published plugin.
 === Main Plugin === === Main Plugin ===
  • /www/perceptive/wiki/data/attic/indigo_2024.1_documentation/plugin_testing_tutorial.1729536585.txt.gz
  • Last modified: 2024/10/21 18:49
  • by davel17
