| indigo_2024.2_documentation:managing_insteon_devices [2025/04/14 20:10] – created - external edit 127.0.0.1 | indigo_2024.2_documentation:managing_insteon_devices [2025/08/13 22:19] (current) – [Set OutletLinc Load Sense] jay | ||
| Line 342: | Line 342: | ||
| This action will allow you to turn the load sense feature of the dual outlet OutletLinc on and off (on either the top or bottom outlet). | This action will allow you to turn the load sense feature of the dual outlet OutletLinc on and off (on either the top or bottom outlet). | ||
| + | ====Troubleshooting==== | ||
| + | If you can't get a device to sync, follow these steps: | ||
| + | - Hold down the shift & option keys while selecting the **Interfaces-> | ||
| + | - In the resulting dialog, check the box next to **LILO debug logging** (leave the dialog open) | ||
| + | - Switch back to the home window and try the define and sync with the AL again - you'll see a lot of debugging information show up in the Event Log window. | ||
| + | - Starting with the first part of the define and sync, copy/paste all the event log lines into an email to [email protected]. | ||
| + | - Switch back to the INSTEON Debugging window and uncheck the **LILO debug logging** checkbox (and close the dialog) | ||
