Link to this comparison view
Next revision
Previous revision
indigo_2025.1_documentation:device_class [2026/03/10 22:07] – [Get Dependencies] davel17indigo_2025.1_documentation:device_class [2026/03/10 22:43] (current) – [Ungroup With Device] davel17
Line 676: Line 676:
 |//''value''// No  |  boolean  |//''True''// to enable, //''False''// to disable| |//''value''// No  |  boolean  |//''True''// to enable, //''False''// to disable|
-=== Get Group List ===
-<color blue>API v1.14+ only:</color> Return an indigo.List with all device IDs in a device group.
-^  Command Syntax Examples  ^
-|<code>indigo.device.getGroupList(123)</code>|
-^  Parameters  ^^^^
-^  Parameter  ^  Required  ^  Type  ^  Description  ^
-|direct parameter|  Yes  |  integer  |id or instance of any device that belongs to a device group.|
-getGroupList() is useful to get the main/root device of a device group. Some properties, such as batteryLevel, only exist on the main/root device. In this example we log the batteryLevel for a module given any devices that belong to its group:
-<code>groupList = indigo.device.getGroupList(devIdOrInstance)
-rootDevice = indigo.devices[groupList[0]]
-indigo.server.log('battery level is: ' + str(rootDevice.batteryLevel))</code>
-See also ''//indigo.device.groupWithDevice()//'' and ''//indigo.device.ungroupDevice()//''.
 === Get Dependencies === === Get Dependencies ===
Line 724: Line 706:
 So, the dictionary will have 5 top-level keys: "actionGroups", "controlPages", "devices", "schedules", "triggers", and "variables". Each one of those keys will return a list object. Inside that list object will be multiple dicts, one for each dependency (or an empty list if there are none). Each dependency dictionary has two keys: "ID" which is the unique id and "Name" which is the name of the object. So, the dictionary will have 5 top-level keys: "actionGroups", "controlPages", "devices", "schedules", "triggers", and "variables". Each one of those keys will return a list object. Inside that list object will be multiple dicts, one for each dependency (or an empty list if there are none). Each dependency dictionary has two keys: "ID" which is the unique id and "Name" which is the name of the object.
 +=== Get Group List ===
 +<color blue>API v1.14+ only:</color> Return an indigo.List with all device IDs in a device group.
 +^  Command Syntax Examples  ^
 +<code>indigo.device.getGroupList(123)  # returns an indigo.List of all devices grouped with dev</code>
 +^  Parameters  ^^^^
 +^  Parameter  ^  Required  ^  Type  ^  Description  ^
 +|direct parameter|  Yes  |  integer  |id or instance of any device that belongs to a device group.|
 +getGroupList() is useful to get the main/root device of a device group. Some properties, such as batteryLevel, only exist on the main/root device. In this example we log the batteryLevel for a module given any devices that belong to its group:
 +<code>groupList = indigo.device.getGroupList(devIdOrInstance)
 +rootDevice = indigo.devices[groupList[0]]
 +indigo.server.log('battery level is: ' + str(rootDevice.batteryLevel))</code>
 +See also ''//indigo.device.groupWithDevice()//'' and ''//indigo.device.ungroupDevice()//''.
 === Group With Device === === Group With Device ===
-indigo.device.groupWithDevice(devsomeOtherDev)  # group dev with another device +To group two or more devices together, use the ''//indigo.device.groupWithDevice()//'' command. The parameters are the Indigo Device object IDs of the devices to be grouped. **Note if you have the device dialog UI open, it will not dynamically update, and you shouldn’t call either method if the device factory UI is open.**
-indigo.device.ungroupDevice(dev)  # ungroup dev +
-indigo.device.getGroupList(dev # returns an indigo.List of all devices grouped with dev+^  Command Syntax Examples
 +<code>indigo.device.groupWithDevice(dev_1dev_2)  # group dev with another device</code>
 +^  Parameters  ^^^^
 +|direct parameter (dev_1)|  Yes  |  integer  |id, name or instance of a device that will belong to the group.
 +|direct parameter (dev_2) Yes  |  integer  |id, name or instance of another device that will belong to the group.|
 +For example, if you want to group devices 123 and 456, you would use ''//indigo.device.groupWithDevice(123, 456)//''There is no message printed to the events log if the devices grouped together successfully. If you want to add device 789 to the group, you would use ''//indigo.device.groupWithDevice(456, 789)//''. This is a great way to bring together different devices that have a common thread, but bear in mind that it's best not to try to group too many devices together. See also ''//indigo.device.ungroupDevice()//'' and ''//indigo.device.getGroupList()//''.
 === Move To Folder === === Move To Folder ===
Line 847: Line 855:
 |//''duration''// No  |  integer  |number of seconds delay before the device turns back off| |//''duration''// No  |  integer  |number of seconds delay before the device turns back off|
 +=== Ungroup With Device ===
 +If you want to remove a device from a group, use the ''//indigo.device.ungroupDevice()//'' command. Use this command with the ID of the device you want removed from the group.**Note if you have the device dialog UI open, it will not dynamically update, and you shouldn’t call either method if the device factory UI is open.**
 +<code>
 +  indigo.device.ungroupDevice(dev)  # ungroup dev
 +</code>
 +^  Parameters  ^^^^
 +|direct parameter|  Yes  |  integer  |id, name or instance of the device to be removed from the group.|
 +If successful, nothing will be printed to the events log. See also ''//indigo.device.groupWithDevice()//'' and ''//indigo.device.getGroupList()//''.
 === Unlock === === Unlock ===
  • /www/perceptive/wiki/data/attic/indigo_2025.1_documentation/device_class.1773180427.txt.gz
  • Last modified: 2026/03/10 22:07
  • by davel17
