Link to this comparison view
Next revision
Previous revision
indigo_2025.1_documentation:device_class [2026/03/10 22:38] – [Ungroup With Device] davel17indigo_2025.1_documentation:device_class [2026/03/10 22:43] (current) – [Ungroup With Device] davel17
Line 727: Line 727:
 === Group With Device === === Group With Device ===
-To group two or more devices together, use the ''//indigo.device.groupWithDevice()//'' command. The parameters are the Indigo Device object IDs of the devices to be grouped.+To group two or more devices together, use the ''//indigo.device.groupWithDevice()//'' command. The parameters are the Indigo Device object IDs of the devices to be grouped. **Note if you have the device dialog UI open, it will not dynamically update, and you shouldn’t call either method if the device factory UI is open.**
 ^  Command Syntax Examples  ^ ^  Command Syntax Examples  ^
Line 856: Line 856:
 === Ungroup With Device === === Ungroup With Device ===
-If you want to remove a device from a group, use the ''//indigo.device.ungroupDevice()//'' command. Use this command with the ID of the device you want removed from the group.+If you want to remove a device from a group, use the ''//indigo.device.ungroupDevice()//'' command. Use this command with the ID of the device you want removed from the group.**Note if you have the device dialog UI open, it will not dynamically update, and you shouldn’t call either method if the device factory UI is open.**
 <code> <code>
Line 865: Line 866:
 ^  Parameter  ^  Required  ^  Type  ^  Description  ^ ^  Parameter  ^  Required  ^  Type  ^  Description  ^
 |direct parameter|  Yes  |  integer  |id, name or instance of the device to be removed from the group.| |direct parameter|  Yes  |  integer  |id, name or instance of the device to be removed from the group.|
- +If successful, nothing will be printed to the events log. See also ''//indigo.device.groupWithDevice()//'' and ''//indigo.device.getGroupList()//''.
-See also ''//indigo.device.groupWithDevice()//'' and ''//indigo.device.getGroupList()//''.+
 === Unlock === === Unlock ===
  • /www/perceptive/wiki/data/attic/indigo_2025.1_documentation/device_class.1773182335.txt.gz
  • Last modified: 2026/03/10 22:38
  • by davel17
