Link to this comparison view
Next revision
Previous revision
indigo_2025.1_documentation:events_data_passing [2025/09/23 10:16] – created davel17indigo_2025.1_documentation:events_data_passing [2025/12/14 20:10] (current) – [How do you pass data through?] jay
Line 1: Line 1:
 ==== Events Data Passing ==== ==== Events Data Passing ====
 +Many users ask, "How do I know what caused an action to fire?" Our server architecture never passed through any source data before. But, now we do! All built-in triggers and schedules now pass through data that's specific to the event. Here are the basics.
 +Events now pass an //''indigo.Dict''// that contains data about the firing event, be it a trigger, schedule, or plugin provided event that your plugin may provide. By default, every event dictionary will contain the following:
 +<code>
 +    "event-indigo-id": 1214985350,  # the ID of the trigger, schedule, action group, etc
 +    "event-type": "Trigger",  # the event type - trigger, schedule, action group, etc.
 +    "source": "server",  # the source of the event (see description below)
 +    "timestamp": "2025-08-07T14:32:21",  # ISO formatted datetime string
 +</code>
 +The ID is the //''event-indigo-id''// for the instance passing the data - it could be a Trigger, a Schedule, an Action Group (more on this later). The //''event-type''// is just the IOM class name. The //''timestamp''// is an ISO formatted datetime that the event fired, so you can use //''datetime.fromisoformat()''// to convert it into a native //''datetime''// instance.
 +The //''source''// item is a little more tricky. Here are the possible values:
 +  - //''server''// - this is what will show if the server performed the event on it's own during the normal course of operations. A device state change trigger, a schedule fires, etc.
 +  - //''python''// - this is what the source would be if the operation was started via an IOM command. So if you did a //''indigo.actionGroup.execute(12345)''// this is what the source would be.
 +  - //''api-http''// - similar to //''python''// above, but if the command came in through the HTTP API.
 +  - //''api-websocket''// - similar to //''api-http''//, but the command would have come through a websocket.
 +Plugin supplied events (for instance, the Z-Wave Command Received event, email received event, or any event that your plugin may provide) will **add** the following plugin specific information:
 +<code>
 +    "event-plugin-event-id": "zwaveCommand",  # ID of the plugin supplied event
 +    "event-plugin-id": "com.perceptiveautomation.indigoplugin.zwave",  # plugin id
 +    "event-plugin-name": "Z-Wave",  # plugin name
 +    "event-type": "PluginEventTrigger", # will always be this class name
 +</code>
 +Plugin events have more data that's specific to the plugin: the event id (from your Events.xml file), your plugin ID, the name. The //''event-type''// for a plugin event will always be //''PluginEventTrigger''//.
 +=== How do you pass data through? ===
 +If your plugin supplies events, then you are aware that in your event handling code you eventually will call the //''execute()''// method on the event that the user configures, something like this:
 +<code>
 +indigo.trigger.execute(trigger_instance)
 +</code>
 +To pass through any extra triggering data that you might want to add, just add it:
 +<code>
 +message = {"somekey": "some value"}
 +indigo.trigger.execute(trigger_instance, trigger_data=message)
 +</code>
 +`message` can be either an `indigo.Dict` or a normal python //''dict''// instance, the server will convert it to an //''indigo.Dict''// before passing it along. It's just that simple.
 +Some notes on standards for your data:
 +  * You won't want to duplicate any of the above built-in names as it would get overwritten.
 +  * You probably want to name your keys with something that's easily identified with your plugin. For instance, the Z-Wave plugin uses the prefix `zwavecmd-` for it's keys that describe the event data that it passes through.
 +  * We tried to use dashes `-` as separators rather than underscores - we think that's a better option for string keys.
 +  * Keys should follow the restrictions on `indigo.Dict` keys (alphanumeric, dash, underscore, starting with a letter).
 +FYI, you can pass arbitrary data around using the IOM and the various `.execute()` actions on Triggers, Schedules, and Action Groups. Just pass through //''trigger_data''//, //''schedule_data''//, //''event_data''// respectively to those function calls when performing them through the IOM.
 +=== How will users use the data? ===
 +The data is passed first to any **conditional scripts**. The data can be accessed like this:
 +<code>
 +# event_data is prepopulated with the indigo.Dict from the originating event
 +if event_data["source"] == "api-http":
 +    # the triggering event came from the HTTP API, so you may want to look at something
 +    # here.
 +    pass
 +</code>
 +Regardless of where the data came from (trigger, schedule, etc), the variable name will be //''event_data''//
 +Then once the conditions have been evaulated, the //''event_data''// will become available to actions. We've updated the built-in actions where appropriate to use the data.
 +We've added a new **Insert Event Data into Variable** action which will allow the user to insert all or part of the event data into the specified variable. If they specify a path (see the **box** library description above) and the result of the path is a simple type (string, bool, int, float) then that value will be inserted into the variable. If the result of the path is a collection (dict or list) or the user doesn't specify the path, then the collection will be converted to JSON and the JSON string will be inserted into the variable.
 +There is also a new substitution, //''%%e:"path"%%''// that can be used anywhere a substitution is valid. If the user wants the whole thing, they would just use the empty string //''%%e:""%%''// and the entire string will be inserted. Again, simple types will be inserted directly, complex types will be inserted as JSON.
 +Embedded script actions will also receive the data in the same way that conditional scripts do. **Note**: external (linked) scripts will not get the data in this release. We will gauge demand moving forward to determine if and when to add it there.
 +=== How will you get the data in your actions? ===
 +You can get the data directly in your actions as well. Event data will be passed to the action method handler  if you modify your method signature:
 +<code>
 +def run_shortcut(self: indigo.PluginBase,
 +                 action: any,
 +                 dev: any,
 +                 caller_waiting_for_result: bool,
 +                 event_data: Optional[indigo.Dict]) -> Optional[indigo.Dict]:
 +</code>
 +This is a complete action handler with type hints. While we don't envision a scenario where //''event_data''// is passed `None`, it's possible that it may happen or could be optional at some point in the future, so your code should make sure that the data is present before assuming anything.
 +=== Examples of How Events Data Can Be Used ===
 +There are likely a lot of different scenarios where //''event_data''// is useful, but it may be helpful to see a complete working example all in one place. Here is a simple example just to show how straightforward the mechanism can be.
 +Create an Action:
 +  * Create an Action Group called "Log Event Data"
 +  * Select **Server Actions** > **Script and File Actions** > **Execute Script**
 +  * Select Embedded Python and enter the following short script into the code block. Notice that we didn't do anything special to access the //''event_data''// payload. It's automatically supplied by the host process when the script is called __due to an event__.
 +<code>
 +indigo.server.log(f"{event_data}")
 +</code>
 +  * Select OK
 +Create a Trigger to fire the action:
 +  * Create a Trigger called "Log Event Data"
 +  * You can link it to an event, but for this example the event type doesn't matter
 +  * You can also set a Condition, but for this example the condition doesn't matter either
 +  * On the Actions tab, select **Server Actions** > **Execute Actions Group**
 +  * Select the "Log Event Data" Action you created above
 +  * Select OK
 +Now, from the Actions list in Indigo, highlight the "Log Event Data" Trigger and select **Execute Actions Only**. When your Trigger fires the script, something similar to the following should appear in the Events log:
 +<code>
 +   Trigger                         Event Data Trigger
 +   Action Group                    Event Data Example
 +   Script                          EventDataDict : (dict)
 +     event-indigo-id : 553162605 (integer)
 +     event-type : DeviceStateChangeTrigger (string)
 +     source : server (string)
 +     timestamp : 2025-10-31T10:18:37 (string)
 +</code>
 +It's that simple.
 +=== Get Creative ===
 +The new //''event_data''// mechanism opens up a lot of possibilities for plugin developers. One thing that comes to mind almost immediately would be for plugins that provide virtual devices/wrappers/shims to allow the user to specify a path in the data then map that into either a custom state or a property (onState, etc). Combine this functionality with [[indigo_2025.1_documentation:webhooks|Webhook functionality]] and it would be possible to have a webhook directly update a virtual device. This would reduce a lot of glue code necessary now in handling those types of things.
  • /www/perceptive/wiki/data/attic/indigo_2025.1_documentation/events_data_passing.1758622575.txt.gz
  • Last modified: 2025/09/23 10:16
  • by davel17
