| Next revision | Previous revision |
| indigo_2025.1_documentation:events_data_path_specifiers [2025/10/21 22:19] – created davel17 | indigo_2025.1_documentation:events_data_path_specifiers [2025/10/22 20:50] (current) – [Indigo-Supplied Event Data] jay |
| | ==== Path Strings ==== |
| | Path strings use a specific syntax and require knowledge about the data you'll be working with. For example, given this Indigo event data: |
| Path specifiers use a specific syntax and require knowledge of the event data you'll be receiving from the event. For example, given this Indigo event data: | |
| <code> | <code> |
| </code> | </code> |
| You could use path specifiers like these to have the associated data inserted into the variable you chose (leave off the quotes): | You could use path strings like these to retrieve the associated data: |
| <code> | ^ Path String ^ Result^ |
| "source" equals "server" | | //''bar''// | "Baz" | |
| "data" equals ["Thing 1", "Thing 2"] | | //''data''// | ["Thing 1", "Thing 2"] | |
| "more_data['b'] equals {'a': 1, 'b': 2} | | //''more_data['b']''// | 2 | |
| </code> | |
| If you want to go deeper into the payload, the path specifiers can be chained together like this: | If you want to go deeper into the payload, path strings can be chained together like this: |
| <code> | <code> |
| </code> | </code> |
| You can go deeper like this (again, leave off the quotes): | You can go deeper like this: |
| | ^ Path String ^ Result ^ |
| | | //''data[0]''// | "Thing 1" (The index of the list element, the index starts at zero) | |
| | | //''data[1][2]''// | "Thing C" # The second element (index 1) of "data" is a list and the third element (index 2) of that list is "Thing C" | |
| | | //''more_data.a''// | 1 # The value of key "a" is 1 | |
| | | //''more_data.c[3]''// | 4 # The value of key "c" is a list and the fourth element (index 3) of that list is 4 | |
| | You can chain these path strings as needed, such as //''some_json[3].a.foo[9]''//. NOTE: if a path string is not provided, Indigo will return the entire payload. Any path that includes a collection (like the lists and dicts above), Indigo will convert it to JSON and respond with that data. |
| | ==== Indigo-Supplied Event Data ==== |
| | We updated most of the built-in events (Triggers, Schedules, etc) to pass through the event data that's specific to those events. All events, regardless of what they are, will contain the following values: |
| <code> | <code> |
| "data[0]" equals "Thing 1" # The index of the list element, the index starts at zero | { |
| "data[1][2]" equals "Thing C" # The second element (index 1) of "data" is a list and the third element (index 2) of that list is "Thing C" | "event-indigo-id": 127375748, |
| "more_data.a" equals 1 # The value of key "a" is 1 | "event-type": "VariableValueChangeTrigger", |
| "more_data.c[3] equals 4 # The value of key "c" is a list and the fourth element (index 3) of that list is 4 | "source": "server", |
| | "timestamp": "2025-08-07T14:13:54" |
| | </code> |
| | The ''event-indigo-id'' is the Indigo ID for the trigger, schedule, or action group. The ''event-type'' is the IOM event type. ''source'' is how the trigger was fired, and ''timestamp'' is an ISO formatted ''datetime'' of the event. |
| | Each specific trigger/schedule/action group may add additional data that will assist you later in the event processing chain. The following blocks provide samples of event data that Indigo supplies for various events. |
| | === Action Groups === |
| | <code> |
| | "_comment": "This is what you get when you execute an action group from the http api", |
| | "event-indigo-id": 1893263747, |
| | "event-type": "ActionGroup", |
| | "source": "api-http", |
| | "timestamp": "2025-10-16T14:59:05", |
| | "unique-id": "1dd66fc1-ce8c-43f7-996f-5b29278c1b90" |
| | "_comment": "When a webhook is called with a JSON dictionary (in data param)", |
| | "data": { |
| | "id": "ShortcutWithJsonInputTests.test_webhook_json_input_var_output", |
| | "message": "something-happened", |
| | "some-data": { |
| | "some-key": [ |
| | "some-value", |
| | "some-other-value" |
| | "unique-id": "9d34e21b-9926-4023-ab94-c0cc52ecedd5" |
| | "event-indigo-id": 879507411, |
| | "event-plugin-event-id": "simpleWebhook", |
| | "event-plugin-id": "com.indigodomo.webserver", |
| | "event-plugin-name": "Web Server", |
| | "event-type": "PluginEventTrigger", |
| | "http-method": "POST", |
| | "http-post-content": "JSON", |
| | "request-url": "https://localhost:8176/webhook/shortcut-json-input-var-output", |
| | "source": "python", |
| | "status-code": 200, |
| | "timestamp": "2025-10-16T14:58:55", |
| | "webhook-id": "shortcut-json-input-var-output" |
| | </code> |
| | === Control Page Clicks === |
| | <code> |
| | "client-ip": "127.0.0.1", |
| | "client-is-private": true, |
| | "control-id": 0, |
| | "event-indigo-id": 120091806, |
| | "event-type": "ControlPage", |
| | "timestamp": "2025-10-16T16:10:54" |
| | </code> |
| | === Device State Change Trigger === |
| | If a device state has any change. |
| | <code> |
| | "_comment": "When the server executes a has any change device state change trigge" |
| | "change-type": "any change", |
| | "change-type-iom": "indigo.kStateChange.Changes", |
| | "device-id": 1167180255, |
| | "event-indigo-id": 625370601, |
| | "event-type": "DeviceStateChangeTrigger", |
| | "new-value": "on", |
| | "old-value": "off", |
| | "state-key": "onOffState", |
| | "timestamp": "2025-10-16T17:07:23" |
| | </code> |
| | === Insteon Command Received === |
| | <code> |
| | "_comment": "when any insteon command is received", |
| | "event-indigo-id": 1086420814, |
| | "event-type": "InsteonCommandReceivedTrigger", |
| | "insteon-cmd-rcvd": { |
| | "Address": 1652724, |
| | "AddressStr": "19.37.F4", |
| | "CommandDetails": 0, |
| | "CommandName": "on", |
| | "CommandVal": 0, |
| | "GroupBroadcastNum": 1, |
| | "IsGroupBroadcast": true, |
| | "SendCleanups": false |
| | "timestamp": "2025-09-24T15:00:12" |
| | "_comment": "when a double-tap off command is received" |
| | "event-indigo-id": 1398699236, |
| | "CommandName": "off (instant)", |
| | "CommandVal": 0, |
| | "timestamp": "2025-08-12T17:39:49" |
| | </code> |
| | === Server Executed Schedules === |
| | When the server executes a schedule during normal operation. |
| | <code> |
| | "event-indigo-id": 485722026, |
| | "event-type": "Schedule", |
| | "timestamp": "2025-10-16T13:55:02" |
| | </code> |
| | === Variable Changes === |
| | <code> |
| | "change-type": "becomes equal", |
| | "change-type-iom": "indigo.kVarChange.BecomesEqual", |
| | "event-indigo-id": 1533121690, |
| | "new-val": "var_becomes_equal_to", |
| | "old-val": "", |
| | "test-val": "var_becomes_equal_to", |
| | "timestamp": "2025-10-16T13:56:23", |
| | "var-id": 54247914 |
| | "change-type": "becomes false", |
| | "change-type-iom": "indigo.kVarChange.BecomesFalse", |
| | "event-indigo-id": 1202935007, |
| | "new-val": "false", |
| | "old-val": "true", |
| | "timestamp": "2025-10-16T13:56:24", |
| | "var-id": 24284935 |
| | "change-type": "becomes greater than", |
| | "change-type-iom": "indigo.kVarChange.BecomesGreaterThan", |
| | "event-indigo-id": 1952491014, |
| | "new-val": "11", |
| | "old-val": "9", |
| | "test-val": "10", |
| | "timestamp": "2025-10-16T13:56:25", |
| | "var-id": 738010762 |
| | "change-type": "becomes less than", |
| | "change-type-iom": "indigo.kVarChange.BecomesLessThan", |
| | "event-indigo-id": 1574402918, |
| | "new-val": "9", |
| | "old-val": "11", |
| | "test-val": "10", |
| | "timestamp": "2025-10-16T13:56:26", |
| | "var-id": 1177127882 |
| | "change-type": "becomes not equal", |
| | "change-type-iom": "indigo.kVarChange.BecomesNotEqual", |
| | "event-indigo-id": 986473566, |
| | "new-val": "", |
| | "old-val": "var_becomes_not_equal_to", |
| | "test-val": "var_becomes_not_equal_to", |
| | "timestamp": "2025-10-16T13:56:28", |
| | "var-id": 127994353 |
| | "change-type": "becomes true", |
| | "change-type-iom": "indigo.kVarChange.BecomesTrue", |
| | "event-indigo-id": 184109916, |
| | "new-val": "true", |
| | "old-val": "false", |
| | "timestamp": "2025-10-16T13:56:29", |
| | "var-id": 836393156 |
| | "change-type-iom": "indigo.kVarChange.Changes", |
| | "new-val": "2025-10-16T13:56:30.146312", |
| | "old-val": "", |
| | "timestamp": "2025-10-16T13:56:30", |
| | "var-id": 908899214 |
| | </code> |
| | === Z-Wave === |
| | <code> |
| | "_comment": "This is an example of the event_data from a Z-Wave command received, all event types except match raw (see below)", |
| | "event-indigo-id": 886317539, |
| | "event-plugin-event-id": "zwaveCommand", |
| | "event-plugin-id": "com.perceptiveautomation.indigoplugin.zwave", |
| | "event-plugin-name": "Z-Wave", |
| | "timestamp": "2025-07-25T15:37:14", |
| | "zwavecmd-device-id": 1191650674, |
| | "zwavecmd-node-id": 2, |
| | "zwavecmd-scene-id": 255 |
| | "_comment": "This is an example of the event_data from a Z-Wave command received, Match Raw Packet", |
| | "event-indigo-id": 572444380, |
| | "timestamp": "2025-07-25T16:44:40", |
| | "zwavecmd-packet": [ |
| | 1, |
| | 9, |
| | 0, |
| | 4, |
| | 0, |
| | 2, |
| | 3, |
| | 38, |
| | 3, |
| | 58, |
| | 242 |
| | "zwavecmd-packet-str": "01 09 00 04 00 02 03 26 03 3A F2" |
| | "If you want to get the match string from the trigger, then you can do this:", |
| | " trigger_id = event_data['event-indigo-id'] # get the trigger id", |
| | " firing_trigger = indigo.triggers[trigger_id] # get the trigger instance", |
| | " zwave_plugin_id = event_data['event-plugin-id'] # get the z-wave plugin id", |
| | " zwave_props = firing_trigger.globalProps[zwave_plugin_id] # get the properties", |
| | " match_string = zwave_props['matchBytes'] # get the match string from properties" |
| </code> | </code> |
| You can chain these path specifiers as needed, such as //''some_json[3].a.foo[9]''// | |
