Link to this comparison view
Next revision
Previous revision
indigo_2025.1_documentation:events_data_path_specifiers [2025/10/21 22:37] davel17indigo_2025.1_documentation:events_data_path_specifiers [2025/10/22 20:50] (current) – [Indigo-Supplied Event Data] jay
Line 1: Line 1:
-==== Path Specifiers ==== +==== Path Strings ====
-Path specifiers use a specific syntax and require knowledge about the data you'll be working with. For example, given this Indigo event data:+Path strings use a specific syntax and require knowledge about the data you'll be working with. For example, given this Indigo event data:
 <code> <code>
Line 11: Line 11:
 </code> </code>
-You could use path specifiers like these to retrieve the associated data:+You could use path strings like these to retrieve the associated data:
-Specifier ^ Result^+Path String ^ Result^
 | //''bar''// | "Baz" | | //''bar''// | "Baz" |
 | //''data''// | ["Thing 1", "Thing 2"] | | //''data''// | ["Thing 1", "Thing 2"] |
 | //''more_data['b']''// | 2 | | //''more_data['b']''// | 2 |
-If you want to go deeper into the payload, specifiers can be chained together like this:+If you want to go deeper into the payload, path strings can be chained together like this:
 <code> <code>
Line 49: Line 49:
 You can go deeper like this: You can go deeper like this:
-Specifier ^ Result ^+Path String ^ Result ^
 | //''data[0]''// | "Thing 1"  (The index of the list element, the index starts at zero) | | //''data[0]''// | "Thing 1"  (The index of the list element, the index starts at zero) |
 | //''data[1][2]''// | "Thing C" # The second element (index 1) of "data" is a list and the third element (index 2) of that list is "Thing C" | | //''data[1][2]''// | "Thing C" # The second element (index 1) of "data" is a list and the third element (index 2) of that list is "Thing C" |
Line 55: Line 55:
 | //''more_data.c[3]''// | 4  # The value of key "c" is a list and the fourth element (index 3) of that list is 4 | | //''more_data.c[3]''// | 4  # The value of key "c" is a list and the fourth element (index 3) of that list is 4 |
-You can chain these path specifiers as needed, such as //''some_json[3].a.foo[9]''//. NOTE: if a path specifier is not provided, Indigo will return the entire payload. Any path that includes a collection (like the lists and dicts above), Indigo will convert it to JSON and respond with that data.+You can chain these path strings as needed, such as //''some_json[3].a.foo[9]''//. NOTE: if a path string is not provided, Indigo will return the entire payload. Any path that includes a collection (like the lists and dicts above), Indigo will convert it to JSON and respond with that data.
 +==== Indigo-Supplied Event Data ====
 +We updated most of the built-in events (Triggers, Schedules, etc) to pass through the event data that's specific to those events. All events, regardless of what they are, will contain the following values:
 +<code>
 +  "event-indigo-id": 127375748,
 +  "event-type": "VariableValueChangeTrigger",
 +  "source": "server",
 +  "timestamp": "2025-08-07T14:13:54"
 +</code>
 +The ''event-indigo-id'' is the Indigo ID for the trigger, schedule, or action group. The ''event-type'' is the IOM event type. ''source'' is how the trigger was fired, and ''timestamp'' is an ISO formatted ''datetime'' of the event.
 +Each specific trigger/schedule/action group may add additional data that will assist you later in the event processing chain. The following blocks provide samples of event data that Indigo supplies for various events.
 +=== Action Groups ===
 +<code>
 +    "_comment": "This is what you get when you execute an action group from the http api",
 +    "event-indigo-id": 1893263747,
 +    "event-type": "ActionGroup",
 +    "source": "api-http",
 +    "timestamp": "2025-10-16T14:59:05",
 +    "unique-id": "1dd66fc1-ce8c-43f7-996f-5b29278c1b90"
 +    "_comment": "When a webhook is called with a JSON dictionary (in data param)",
 +    "data":
 +      "id": "ShortcutWithJsonInputTests.test_webhook_json_input_var_output",
 +      "message": "something-happened",
 +      "some-data":
 +        "some-key":
 +          "some-value",
 +          "some-other-value"
 +        "unique-id": "9d34e21b-9926-4023-ab94-c0cc52ecedd5"
 +    "event-indigo-id": 879507411,
 +    "event-plugin-event-id": "simpleWebhook",
 +    "event-plugin-id": "com.indigodomo.webserver",
 +    "event-plugin-name": "Web Server",
 +    "event-type": "PluginEventTrigger",
 +    "http-method": "POST",
 +    "http-post-content": "JSON",
 +    "request-url": "https://localhost:8176/webhook/shortcut-json-input-var-output",
 +    "source": "python",
 +    "status-code": 200,
 +    "timestamp": "2025-10-16T14:58:55",
 +    "webhook-id": "shortcut-json-input-var-output"
 +</code>
 +=== Control Page Clicks ===
 +<code>
 +  "client-ip": "127.0.0.1",
 +  "client-is-private": true,
 +  "control-id": 0,
 +  "event-indigo-id": 120091806,
 +  "event-type": "ControlPage",
 +  "timestamp": "2025-10-16T16:10:54"
 +</code>
 +=== Device State Change Trigger ===
 +If a device state has any change.
 +<code>
 +  "_comment": "When the server executes a has any change device state change trigge"
 +  "change-type": "any change",
 +  "change-type-iom": "indigo.kStateChange.Changes",
 +  "device-id": 1167180255,
 +  "event-indigo-id": 625370601,
 +  "event-type": "DeviceStateChangeTrigger",
 +  "new-value": "on",
 +  "old-value": "off",
 +  "state-key": "onOffState",
 +  "timestamp": "2025-10-16T17:07:23"
 +</code>
 +=== Insteon Command Received ===
 +<code>
 +    "_comment": "when any insteon command is received",
 +    "event-indigo-id": 1086420814,
 +    "event-type": "InsteonCommandReceivedTrigger",
 +    "insteon-cmd-rcvd":
 +      "Address": 1652724,
 +      "AddressStr": "19.37.F4",
 +      "CommandDetails": 0,
 +      "CommandName": "on",
 +      "CommandVal": 0,
 +      "GroupBroadcastNum": 1,
 +      "IsGroupBroadcast": true,
 +      "SendCleanups": false
 +    "timestamp": "2025-09-24T15:00:12"
 +    "_comment": "when a double-tap off command is received"
 +    "event-indigo-id": 1398699236,
 +      "CommandName": "off (instant)",
 +      "CommandVal": 0,
 +    "timestamp": "2025-08-12T17:39:49"
 +</code>
 +=== Server Executed Schedules ===
 +When the server executes a schedule during normal operation.
 +<code>
 +  "event-indigo-id": 485722026,
 +  "event-type": "Schedule",
 +  "timestamp": "2025-10-16T13:55:02"
 +</code>
 +=== Variable Changes ===
 +<code>
 +    "change-type": "becomes equal",
 +    "change-type-iom": "indigo.kVarChange.BecomesEqual",
 +    "event-indigo-id": 1533121690,
 +    "new-val": "var_becomes_equal_to",
 +    "old-val": "",
 +    "test-val": "var_becomes_equal_to",
 +    "timestamp": "2025-10-16T13:56:23",
 +    "var-id": 54247914
 +    "change-type": "becomes false",
 +    "change-type-iom": "indigo.kVarChange.BecomesFalse",
 +    "event-indigo-id": 1202935007,
 +    "new-val": "false",
 +    "old-val": "true",
 +    "timestamp": "2025-10-16T13:56:24",
 +    "var-id": 24284935
 +    "change-type": "becomes greater than",
 +    "change-type-iom": "indigo.kVarChange.BecomesGreaterThan",
 +    "event-indigo-id": 1952491014,
 +    "new-val": "11",
 +    "old-val": "9",
 +    "test-val": "10",
 +    "timestamp": "2025-10-16T13:56:25",
 +    "var-id": 738010762
 +    "change-type": "becomes less than",
 +    "change-type-iom": "indigo.kVarChange.BecomesLessThan",
 +    "event-indigo-id": 1574402918,
 +    "new-val": "9",
 +    "old-val": "11",
 +    "test-val": "10",
 +    "timestamp": "2025-10-16T13:56:26",
 +    "var-id": 1177127882
 +    "change-type": "becomes not equal",
 +    "change-type-iom": "indigo.kVarChange.BecomesNotEqual",
 +    "event-indigo-id": 986473566,
 +    "new-val": "",
 +    "old-val": "var_becomes_not_equal_to",
 +    "test-val": "var_becomes_not_equal_to",
 +    "timestamp": "2025-10-16T13:56:28",
 +    "var-id": 127994353
 +    "change-type": "becomes true",
 +    "change-type-iom": "indigo.kVarChange.BecomesTrue",
 +    "event-indigo-id": 184109916,
 +    "new-val": "true",
 +    "old-val": "false",
 +    "timestamp": "2025-10-16T13:56:29",
 +    "var-id": 836393156
 +    "change-type-iom": "indigo.kVarChange.Changes",
 +    "new-val": "2025-10-16T13:56:30.146312",
 +    "old-val": "",
 +    "timestamp": "2025-10-16T13:56:30",
 +    "var-id": 908899214
 +</code>
 +=== Z-Wave ===
 +<code>
 +    "_comment": "This is an example of the event_data from a Z-Wave command received, all event types except match raw (see below)",
 +    "event-indigo-id": 886317539,
 +    "event-plugin-event-id": "zwaveCommand",
 +    "event-plugin-id": "com.perceptiveautomation.indigoplugin.zwave",
 +    "event-plugin-name": "Z-Wave",
 +    "timestamp": "2025-07-25T15:37:14",
 +    "zwavecmd-device-id": 1191650674,
 +    "zwavecmd-node-id": 2,
 +    "zwavecmd-scene-id": 255
 +    "_comment": "This is an example of the event_data from a Z-Wave command received, Match Raw Packet",
 +    "event-indigo-id": 572444380,
 +    "timestamp": "2025-07-25T16:44:40",
 +    "zwavecmd-packet":
 +      1,
 +      9,
 +      0,
 +      4,
 +      0,
 +      2,
 +      3,
 +      38,
 +      3,
 +      58,
 +      242
 +    "zwavecmd-packet-str": "01 09 00 04 00 02 03 26 03 3A F2"
 +  "If you want to get the match string from the trigger, then you can do this:",
 +  "    trigger_id = event_data['event-indigo-id' # get the trigger id",
 +  "    firing_trigger = indigo.triggers[trigger_id]  # get the trigger instance",
 +  "    zwave_plugin_id = event_data['event-plugin-id' # get the z-wave plugin id",
 +  "    zwave_props = firing_trigger.globalProps[zwave_plugin_id]  # get the properties",
 +  "    match_string = zwave_props['matchBytes' # get the match string from properties"
 +</code>
  • /www/perceptive/wiki/data/attic/indigo_2025.1_documentation/events_data_path_specifiers.1761086240.txt.gz
  • Last modified: 2025/10/21 22:37
  • by davel17
