| indigo_2025.1_documentation:indigo_touch_web [2025/10/24 11:57] – [In Folder] davel17 | indigo_2025.1_documentation:indigo_touch_web [2025/10/24 12:00] (current) – [Tile View / List View] davel17 | ||
| Line 78: | Line 78: | ||
| ==== Search Tools ==== | ==== Search Tools ==== | ||
| - | ==== Light Mode and Dark Mode ==== | + | === In Folder |
| - | ITW currently supports two views -- light mode and dark mode. You can toggle between the two using the button at the top right of the screen. Your choice is saved locally via your browser' | + | This dropdown list will list the folders appropriate to the tab selected. For example, the Actions tab will only display folders in your actions list in Indigo. Selecting a folder will filter the object list as it does in the Indigo client. |
| + | === Name Contains === | ||
| + | This text field allows you to filter the object list based on the object' | ||
| + | ==== Themes | ||
| + | ITW currently supports two themes | ||
| | Light Mode | Dark Mode | | | Light Mode | Dark Mode | | ||
| - | ==== Tile View / List View ==== | + | ==== Views ==== |
| Indigo Touch Web supports two views--Tile view and List view. You can toggle between the two views using the view button located in the upper right corner. | Indigo Touch Web supports two views--Tile view and List view. You can toggle between the two views using the view button located in the upper right corner. | ||
