| indigo_2025.1_documentation:managing_z-wave_devices [2025/09/22 19:58] – created - external edit 127.0.0.1 | indigo_2025.1_documentation:managing_z-wave_devices [2025/10/24 12:47] (current) – davel17 | ||
| Line 124: | Line 124: | ||
| - Find the device in the device table and double click it (or select it and click the '' | - Find the device in the device table and double click it (or select it and click the '' | ||
| - Click the '' | - Click the '' | ||
| - | - Follow the instructions on the dialog to use your interface | + | - Follow the instructions on the dialog to use your controller |
| - | - Select the new device in the '' | + | - Select the new device in the '' |
| - Click on the " | - Click on the " | ||
| - When the '' | - When the '' | ||
| Line 249: | Line 249: | ||
| === Report Failed Modules to Event Log === | === Report Failed Modules to Event Log === | ||
| - | This menu item will write any devices that the Z-Wave interface believes may have failed to | + | This menu item will write any devices that the Z-Wave interface believes may have failed to the Indigo Events Log. This list is managed by the Z-Wave interface (not by Indigo) and it's important to note that **the listed devices may not have actually failed** (the interface may list a device that it hasn't received a transmission from for a while, for example). It's recommended that you use this menu item from time to time to ensure that the interface has the correct information for your devices. |
| - | the Indigo Events Log. This list is managed by the Z-Wave interface (not by Indigo) and it's | + | |
| - | important to note that **the listed devices may not have actually failed** (the interface | + | |
| - | may list a device that it hasn't received a transmission from for a while, for example). It's | + | |
| - | recommended that you use this menu item from time to time to ensure that the interface has | + | |
| - | the correct information for your devices. | + | |
| Line 262: | Line 257: | ||
| - | If you see a device listed that you believe should not be listed, it is often enough to simply | + | If you see a device listed that you believe should not be listed, it is often enough to simply browse to that device in the Indigo UI, open the Edit Device dialog, and perform a **Define and Sync** operation. Indigo will attempt to refresh the device' |
| - | browse to that device in the Indigo UI, open the Edit Device dialog, and perform a **Define | + | |
| - | and Sync** operation. Indigo will attempt to refresh the device' | + | |
| - | the Z-Wave interface to remove the device from the failed devices list. After performing this | + | |
| - | operation, you can confirm the device has been removed from the list by rerunning the | + | |
| - | **Report Failed Modules to Event Log** step. | + | |
| If the interface doesn' | If the interface doesn' | ||
