Link to this comparison view
Next revision
Previous revision
indigo_2025.1_documentation:plugin_guide [2026/01/23 16:26] – [getDeviceConfigUiValues Example] davel17indigo_2025.1_documentation:plugin_guide [2026/03/13 01:46] (current) – [Color Picker] davel17
Line 623: Line 623:
 {{:indigo_2025.1_documentation:color_picker.png?200|}} {{:indigo_2025.1_documentation:color_picker.png?200|}}
-<code><Field id="exampleColorPicker" +<code><Field id="exampleColorPicker" type="colorpicker" tooltip="Click this button to select a color.">
-       type="button" +
-       tooltip="Click this button to select a color.">+
     <Label>Color:</Label>     <Label>Color:</Label>
     <CallbackMethod>ColorPickerPressed</CallbackMethod>     <CallbackMethod>ColorPickerPressed</CallbackMethod>
Line 649: Line 647:
 |//''enabledBindingNegate''// No  |  1.9  |Set this to "true" to negate the binding. So if the target binding field's value is true then the binding will be false.  | |//''enabledBindingNegate''// No  |  1.9  |Set this to "true" to negate the binding. So if the target binding field's value is true then the binding will be false.  |
 |//''id''// Yes  |  1.0  |This is a unique identifier for this Field within the context of this //''ConfigUI''// element.| |//''id''// Yes  |  1.0  |This is a unique identifier for this Field within the context of this //''ConfigUI''// element.|
-|//''type''// Yes  |  2.0  |This must be //''colorPicker''//.|+|//''type''// Yes  |  2.0  |This must be //''colorpicker''//.|
 |//''visibleBindingId''// No  |  1.0  |If you want to conditionally show/hide this field based on the value of another field, set this value to the //''id''// of another field. If you set this, you must also include a //''visibleBindingValue''//| |//''visibleBindingId''// No  |  1.0  |If you want to conditionally show/hide this field based on the value of another field, set this value to the //''id''// of another field. If you set this, you must also include a //''visibleBindingValue''//|
 |//''visibleBindingValue''// No  |  1.0  |If you specify a //''visibleBindingId''//, you must specify the value(s) here. For instance, if you are binding to a checkbox, setting this to //''false''// will mean the menu field is visible only when the checkbox is unchecked, and a //''true''// means the opposite. To make the field dependent on another list or menu, set this value to a comma separated list of option values (//''item1, item2''//). You can even bind it to the value in a text field, but that’s probably of limited use. **Note**: the string comparison is a contains - so if any option contains the specified string it will match. This offers some extra flexibility in defining dependency groups.| |//''visibleBindingValue''// No  |  1.0  |If you specify a //''visibleBindingId''//, you must specify the value(s) here. For instance, if you are binding to a checkbox, setting this to //''false''// will mean the menu field is visible only when the checkbox is unchecked, and a //''true''// means the opposite. To make the field dependent on another list or menu, set this value to a comma separated list of option values (//''item1, item2''//). You can even bind it to the value in a text field, but that’s probably of limited use. **Note**: the string comparison is a contains - so if any option contains the specified string it will match. This offers some extra flexibility in defining dependency groups.|
  • /www/perceptive/wiki/data/attic/indigo_2025.1_documentation/plugin_guide.1769185616.txt.gz
  • Last modified: 2026/01/23 16:26
  • by davel17
