| indigo_2025.1_documentation:python_packages [2025/09/24 14:29] – [Python Box] davel17 | indigo_2025.1_documentation:python_packages [2026/02/11 22:53] (current) – [Python 3.11.6 Packages Installed by Indigo] davel17 | ||
| Line 3: | Line 3: | ||
| This page describes how **Indigo 2025.1.0** works with Python, specifically with respect to packages/ | This page describes how **Indigo 2025.1.0** works with Python, specifically with respect to packages/ | ||
| - | Indigo 2025.1 shipped with [[api_release_notes: | + | Indigo 2025.1 shipped with [[api_release_notes: |
| **All embedded and external Python scripts are run in Python 3** - so you will need to update your scripts if they aren't working (we can't automatically tell if they will work or not unfortunately). We believe that simple scripts will most likely work without change, but if not, you can walk through [[https:// | **All embedded and external Python scripts are run in Python 3** - so you will need to update your scripts if they aren't working (we can't automatically tell if they will work or not unfortunately). We believe that simple scripts will most likely work without change, but if not, you can walk through [[https:// | ||
| Line 180: | Line 180: | ||
| === Python 3.11.6 Packages Installed by Indigo === | === Python 3.11.6 Packages Installed by Indigo === | ||
| - | Indigo 2025.1 ships with support for the following Python 3 packages in addition to the packages installed with the standard Python framework. Generally, if earlier versions of the listed packages are installed at the location Indigo uses, they will be upgraded to the version numbers below. The //''> | + | Indigo 2025.1 ships with support for the following Python 3 packages in addition to the packages installed with the standard Python framework. Generally, if earlier versions of the listed packages are installed at the location Indigo uses, they will be upgraded to the version numbers below. The //''> |
| ^ PIP installed by Indigo\\ PIP Modifiable (but not recommended) | ^ PIP installed by Indigo\\ PIP Modifiable (but not recommended) | ||
| ^ Package | ^ Package | ||
| - | | certifi | + | | * aiofiles |
| - | | charset_normalizer | + | | * anyio | >=4.8.0 | |
| - | | cryptography | + | | certifi |
| - | | - cffi | >= 1.16.0 | | + | | * cffi | >=1.17.1 | |
| - | | - pycparser | + | | charset_normalizer |
| - | | cycler | + | | * contourpy |
| - | | dictdiffer | + | | cryptography |
| - | | future | + | | * cycler |
| - | | httpx | >= 0.25.2 | | + | | dictdiffer |
| - | | - anyio | | + | | * fonttools |
| - | | - certifi | + | | future |
| - | | - h11 | + | | * h11 |
| - | | - httpcore | + | | * html5tagger |
| - | | - idna | + | | * httpcore |
| - | | - sniffio | + | | * httptools |
| - | | idna | >= 3.6 | | + | | httpx | ==0.25.2 | |
| - | | janus | + | | idna | ==3.6 | |
| - | | - typing_extensions | + | | janus |
| - | | Jinja2 | + | | * jedi |
| - | | kiwisolver | + | | Jinja2 |
| - | | MarkupSafe | + | | * kiwisolver |
| - | | matplotlib | + | | MarkupSafe |
| - | | - fonttools | + | | matplotlib |
| - | | - contourpy | + | | * multidict |
| - | | numpy | + | | * numpy |
| - | | oauthlib | + | | oauthlib |
| - | | Pillow | + | | * packaging |
| - | | pudb | + | | * parso | |
| - | | - jedi | + | | Pillow |
| - | | - packaging | + | | pudb |
| - | | - parso | >= 0.8.3 | | + | | py-applescript |
| - | | - pygments | + | | pyaes | ==1.6.1 | |
| - | | - urwid | >= 2.3.4 | | + | | * pycparser |
| - | | - urwid-readline | + | | * Pygments |
| - | | py-applescript | + | | pyobjc |
| - | | pyaes | + | | pyparsing |
| - | | pyobjc | + | | python-box |
| - | | pyparsing | + | | python-dateutil |
| - | | python-box | + | | requests |
| - | | python-dateutil | + | | requests-oauthlib |
| - | | requests | + | | sanic |
| - | | requests-oauthlib | + | | * sanic-routing |
| - | | sanic | + | | sanic-session |
| - | | - aiofiles | + | | scipy | ==1.11.4 | |
| - | | - httptools | + | | six | ==1.16.0 | |
| - | | - html5tagger | + | | * sniffio |
| - | | - multidict | + | | * tracerite |
| - | | - sanic-routing | + | | * typing_extensions | >=4.12.2 | |
| - | | - sanic-session | + | | * ujson |
| - | | - tracerite | + | | urllib3 |
| - | | - ujson | + | | * urwid | >=2.6.16 | |
| - | | - uvloop | + | | * urwid-readline |
| - | | - websockets | + | | * uvloop |
| - | | scipy | >= 1.11.4 | | + | | * wcwidth |
| - | | six | >= 1.16.0 | | + | | websockets |
| - | | urllib3 | + | | xmljson |
| - | | xmljson | + | ^ |
| - | ^ | + | | pyserial |
| - | | pyserial | + | |
| ===== Special Packages ===== | ===== Special Packages ===== | ||
| This section contains notes and examples about some library features that may be of particular help to developers. | This section contains notes and examples about some library features that may be of particular help to developers. | ||
| Line 257: | Line 255: | ||
| - | some_element = my_box(" | + | some_element = my_box[" |
| Line 271: | Line 269: | ||
| - | my_box = box.Box(my_dict, | + | my_box = box.Box(my_dict, |
| dict_in_list = my_box[" | dict_in_list = my_box[" | ||
