Link to this comparison view
Next revision
Previous revision
indigo_2025.1_documentation:trigger_class [2026/02/17 23:14] – [Enable/Disable Trigger] davel17indigo_2025.1_documentation:trigger_class [2026/04/07 18:27] (current) – external edit 127.0.0.1
Line 31: Line 31:
 ^  Property  ^  Type  ^  Writable  ^  Description  ^ ^  Property  ^  Type  ^  Writable  ^  Description  ^
-|//''actions''// list of [[action_class|Action]]  |  Yes  |a list of Action objects (action steps in AS) that are executed for this trigger **Not yet implemented**|
 |//''description''// string  |  Yes  |description of the trigger| |//''description''// string  |  Yes  |description of the trigger|
 |//''enabled''// boolean  |  Yes  |true if this trigger is enabled| |//''enabled''// boolean  |  Yes  |true if this trigger is enabled|
Line 143: Line 142:
 ^  Command Syntax Examples  ^ ^  Command Syntax Examples  ^
-|<code>depDict = indigo.trigger.getDependencies(123)</code>|+|<code>indigo.trigger.getDependencies(123)</code>|
 ^  Parameters  ^^^^ ^  Parameters  ^^^^
  • /www/perceptive/wiki/data/attic/indigo_2025.1_documentation/trigger_class.1771370065.txt.gz
  • Last modified: 2026/02/17 23:14
  • by davel17
