Link to this comparison view
indigo_2025.1_documentation:variable_class [2026/02/17 23:26] – [Get Dependencies] davel17indigo_2025.1_documentation:variable_class [2026/03/03 19:26] (current) davel17
Line 8: Line 8:
 |//''id''// integer  |the unique id of the variable, assigned on creation by IndigoServer| |//''id''// integer  |the unique id of the variable, assigned on creation by IndigoServer|
 |//''folderId''// integer  |the unique id of the folder this variable is in (0 if it's not in a folder) - use //''moveToFolder()''// method to change| |//''folderId''// integer  |the unique id of the folder this variable is in (0 if it's not in a folder) - use //''moveToFolder()''// method to change|
-|//''name''// string  |the name of the variable - no two variable can have the same name|+|//''name''// string  |the name of the variable - no two variable can have the same name and the name cannot contain whitespace|
 |//''readOnly''// string  |is the variable read only - currently only the //''isDaylight''// variable is read only| |//''readOnly''// string  |is the variable read only - currently only the //''isDaylight''// variable is read only|
 |//''remoteDisplay''// boolean  |should this variable be displayed in remote clients (IWS, Indigo Touch, etc)| |//''remoteDisplay''// boolean  |should this variable be displayed in remote clients (IWS, Indigo Touch, etc)|
  • /www/perceptive/wiki/data/attic/indigo_2025.1_documentation/variable_class.1771370769.txt.gz
  • Last modified: 2026/02/17 23:26
  • by davel17
