| indigo_2025.1_documentation:webhooks [2025/10/21 19:46] – [Advanced Scripting Example] davel17 | indigo_2025.1_documentation:webhooks [2026/02/03 19:45] (current) – [Test Your Webhook] davel17 | ||
| Line 13: | Line 13: | ||
| - | https:// | + | https:// |
| Line 19: | Line 19: | ||
| Line 52: | Line 52: | ||
| Here's what each of those fields represent: | Here's what each of those fields represent: | ||
| === Payloads === | === Payloads === | ||
| Line 95: | Line 95: | ||
| - Configure a new Webhook Trigger action (select Web Server Event from Type and Webhook from Event). | - Configure a new Webhook Trigger action (select Web Server Event from Type and Webhook from Event). | ||
| The Webhook ID field specifies the name of the webhook that you'll use on your URL. The Method is POST and the processing is JSON. Next, switch to the Actions tab and select //'' | The Webhook ID field specifies the name of the webhook that you'll use on your URL. The Method is POST and the processing is JSON. Next, switch to the Actions tab and select //'' | ||
| Select the Variable you created in step 1 above, then enter //'' | Select the Variable you created in step 1 above, then enter //'' | ||
| Line 205: | Line 205: | ||
| First, let's create the Indigo webhook. Here's the trigger definition: | First, let's create the Indigo webhook. Here's the trigger definition: | ||
| It's a straight-forward JSON POST webhook named //'' | It's a straight-forward JSON POST webhook named //'' | ||
| Line 243: | Line 243: | ||
| == Summary == | == Summary == | ||
| We created a single Indigo webhook that catches a JSON payload and in an embedded script it uses data from the payloads to determine where Joe is. We also created two locations in Locative that represent home and work, and configured the webhooks for both locations to hit our single webhook trigger and pass through their data. | We created a single Indigo webhook that catches a JSON payload and in an embedded script it uses data from the payloads to determine where Joe is. We also created two locations in Locative that represent home and work, and configured the webhooks for both locations to hit our single webhook trigger and pass through their data. | ||
| + | ==== Synology NAS Webhook Example ==== | ||
| + | Synology DSM supports webhook events and they work great with Indigo' | ||
| + | === Setting Up Indigo Webhooks === | ||
| + | - In Indigo, create a new Trigger. | ||
| + | - Under Type, select Web Server Event. | ||
| + | - Under Event, select Webhook. | ||
| + | - Under the Configure Webhook dialog, copy the Webhook ID and paste it somewhere safe. If you want, you can change the ID to something else -- it must be unique. | ||
| + | - Under Webhook Method, ensure it's set to POST. | ||
| + | - Under Processing, ensure it's set to JSON. | ||
| + | - Set up the Action for your Indigo Trigger (send an email, write to the event log, etc.) | ||
| + | - Save your Trigger. | ||
| + | === Setting Up Synology DSM Webhooks === | ||
| + | - Log into the Synology NAS administrative dashboard. | ||
| + | - Open the Control Panel app. | ||
| + | - Select Notification. | ||
| + | - Select Webhooks | ||
| + | - Click the " | ||
| + | - Choose a Notification Rule, enter a Provider Name, and Subject | ||
| + | - Enter the configured webhook URL which should have a form similar to this: **'' | ||
| + | - Click Next (or switch to the HTTP Request tab). | ||
| + | - Adjust the request as needed -- can leave at defaults for your first webhook. | ||
| + | - Save your webhook. | ||
| + | === Test Your Webhook === | ||
| + | - Select your new Synology web hook if it's not already selected. | ||
| + | - Press the "Send Test Message" | ||
| + | - Confirm the webhook worked (depends on the Action options you chose above.) | ||
| + | An example event log success message: | ||
| + | <code bash> | ||
| + | Trigger | ||
| + | Email+ | ||
| + | And the notification! | ||
| + | === Customize Your Webhook Event === | ||
| + | Now that you've confirmed that your Indigo Webhook event is working properly, you can customize it to make it even more useful. Because we've selected a POST event, the Synology DSM webhook will pass DSM event data to Indigo. You can use that payload to take different actions. When an Indigo POST web hook is triggered, it includes the payload that was POSTed. You can access this payload with a Python script. The payload is sent as JSON, so you can access the DSM event information by working with the `event_data` payload that's sent to the trigger. See the [[indigo_2025.1_documentation: | ||
