Link to this comparison view
Next revision
Previous revision
indigo_2025.2_documentation:device_class [2026/05/04 11:05] – [Decrease Heat Setpoint] davel17indigo_2025.2_documentation:device_class [2026/05/04 11:09] (current) – [Set Heat Setpoint] davel17
Line 1515: Line 1515:
 ^  Parameters  ^^^^ ^  Parameters  ^^^^
 ^  Parameter  ^  Required  ^  Type  ^  Description  ^ ^  Parameter  ^  Required  ^  Type  ^  Description  ^
-|direct parameter|  Yes  |  integer  |id or instance of the device|+|direct parameter|  Yes  |  float  |id or instance of the device|
 |''//delta//'' No  |  float  |Number of degrees to increase the cool setpoint.  If unspecified, the change will be equal to one degree.| |''//delta//'' No  |  float  |Number of degrees to increase the cool setpoint.  If unspecified, the change will be equal to one degree.|
Line 1527: Line 1527:
 |''//delta//'' No  |  float  |Number of degrees to increase the heat setpoint. If unspecified, the change will be equal to one degree.| |''//delta//'' No  |  float  |Number of degrees to increase the heat setpoint. If unspecified, the change will be equal to one degree.|
Line 1539: Line 1539:
 |direct parameter|  Yes  |  integer  |id or instance of the device| |direct parameter|  Yes  |  integer  |id or instance of the device|
-|''//value//'' Yes  |  integer  |the absolute temperature of the setpoint|+|''//value//'' Yes  |  float  |the absolute temperature of the setpoint|
 === Set Fan Mode === === Set Fan Mode ===
Line 1561: Line 1561:
 === Set HVAC Mode === === Set HVAC Mode ===
  • /www/perceptive/wiki/data/attic/indigo_2025.2_documentation/device_class.1777892740.txt.gz
  • Last modified: 2026/05/04 11:05
  • by davel17
